Commit 55a7e631 authored by Andrei Paskevich's avatar Andrei Paskevich
minor
parent 20df062c
......@@ -23,9 +23,9 @@ open Util
open Whyconf
let usage_msg =
sprintf "Usage: %s [options]\n\n
Environment variables WHY3LIB, WHY3DATA, and WHY3CONFIG\n
can be set to change the default paths\n@."
can be set to change the default paths.@."
(Filename.basename Sys.argv.(0))
let version_msg = sprintf
