Commit 559e03ee authored by MARCHE Claude's avatar MARCHE Claude
why3-cpulimit: nicer message when wallclocj timelimit reached
parent 3e3bb6a5
...@@ -22,7 +22,26 @@ ...@@ -22,7 +22,26 @@
#include <string.h> #include <string.h>
#include <sys/wait.h> #include <sys/wait.h>
void do_nothing() {} static int wallclock_timelimit = 60;
static int showtime = 0, hidetime = 0;
void show_time() {
struct tms tms;
double time;
if (showtime) {
times(&tms);
time = (double)((tms.tms_cutime + tms.tms_cstime + 0.0)
/ sysconf(_SC_CLK_TCK));
fprintf(stderr, "why3cpulimit time : %f s\n", time);
void wallclock_timelimit_reached() {
fprintf(stderr,
"Why3cpulimit: wallclock timelimit %d reached, killing command\n",
wallclock_timelimit);
void usage(char *argv0) { void usage(char *argv0) {
fprintf(stderr, fprintf(stderr,
...@@ -34,7 +53,6 @@ void usage(char *argv0) { ...@@ -34,7 +53,6 @@ void usage(char *argv0) {
int main(int argc, char *argv[]) { int main(int argc, char *argv[]) {
long timelimit, memlimit; long timelimit, memlimit;
int showtime, hidetime;
struct rlimit res; struct rlimit res;
if (argc < 5) usage(argv[0]); if (argc < 5) usage(argv[0]);
...@@ -63,18 +81,18 @@ int main(int argc, char *argv[]) { ...@@ -63,18 +81,18 @@ int main(int argc, char *argv[]) {
if (pid > 0) { if (pid > 0) {
int status; int status;
struct tms tms;
double time;
pid_t p; pid_t p;
struct sigaction sa; struct sigaction sa;
sa.sa_handler = &do_nothing; /* set a wallclock time limit as last resort */
sa.sa_handler = &wallclock_timelimit_reached;
sigemptyset(&sa.sa_mask); sigemptyset(&sa.sa_mask);
sa.sa_flags = 0; sa.sa_flags = 0;
sigaction(SIGALRM, &sa, NULL); sigaction(SIGALRM, &sa, NULL);
wallclock_timelimit = 2*timelimit + 60;
alarm(wallclock_timelimit);
alarm(timelimit + 60); /* wait for the subprocess */
p = waitpid(pid, &status, 0); p = waitpid(pid, &status, 0);
if (p <= 0) { if (p <= 0) {
...@@ -86,12 +104,7 @@ int main(int argc, char *argv[]) { ...@@ -86,12 +104,7 @@ int main(int argc, char *argv[]) {
if (showtime) { show_time();
times(&tms);
if (WIFEXITED(status)) return WEXITSTATUS(status); if (WIFEXITED(status)) return WEXITSTATUS(status);
if (WIFSIGNALED(status)) kill(getpid(), WTERMSIG(status)); if (WIFSIGNALED(status)) kill(getpid(), WTERMSIG(status));
...@@ -130,4 +143,3 @@ int main(int argc, char *argv[]) { ...@@ -130,4 +143,3 @@ int main(int argc, char *argv[]) {
return EXIT_FAILURE; return EXIT_FAILURE;
