GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
54fdf578
54fdf578
MARCHE Claude
Fix problems with expanded status of rows in IDE
cfb687f8
src/ide/gmain.ml
54fdf578
@@ -445,6 +445,8 @@ let fan n =
module
S
Session
module
S
Session
let
session_needs_saving
ref
false
let
set_row_status
row
b
let
set_row_status
row
b
if
b
then
if
b
then
goals_model
set
row
row
iter
column
status_column
image_yes
goals_model
set
row
row
iter
column
status_column
image_yes
@@ -516,7 +518,6 @@ let (_:GtkSignal.id) =
let
_
GtkSignal
id
let
_
GtkSignal
id
goals_view
connect
row_expanded
callback
row_expanded
true
goals_view
connect
row_expanded
callback
row_expanded
true
let
ref
false
let
current_selected_row
ref
None
let
ref
None
let
current_env_session
ref
None
let
current_env_session
ref
None
let
env_session
let
env_session
