same fringe: updated proof file
parent c2760492
...@@ -3,59 +3,59 @@ ...@@ -3,59 +3,59 @@
<why3session name="examples/programs/same_fringe/why3session.xml"> <why3session name="examples/programs/same_fringe/why3session.xml">
<file name="../same_fringe.mlw" verified="true" expanded="true"> <file name="../same_fringe.mlw" verified="true" expanded="true">
<theory name="SameFringe" verified="true" expanded="true"> <theory name="SameFringe" verified="true" expanded="true">
<goal name="leftlen_nonneg" sum="9e80575f6e2af3d97ea15e644db5db14" proved="true" expanded="true"> <goal name="leftlen_nonneg" sum="d2d87a3927713430311330ea3f872f8d" proved="true" expanded="true">
<proof prover="coq" timelimit="10" edited="same_fringe.mlw_SameFringe_leftlen_nonneg_1.v" obsolete="false"> <proof prover="coq" timelimit="10" edited="same_fringe.mlw_SameFringe_leftlen_nonneg_1.v" obsolete="false">
<result status="valid" time="0.59"/> <result status="valid" time="0.59"/>
</proof> </proof>
</goal> </goal>
<goal name="WP_parameter enum" expl="correctness of parameter enum" sum="400dbb18200455814ca6e566343047e6" proved="true" expanded="true"> <goal name="WP_parameter enum" expl="correctness of parameter enum" sum="2dde99e9e4d7639b161a3faf6e97bf47" proved="true" expanded="true">
<proof prover="alt-ergo" timelimit="10" edited="" obsolete="false"> <proof prover="alt-ergo" timelimit="10" edited="" obsolete="false">
<result status="valid" time="0.84"/> <result status="valid" time="0.87"/>
</proof> </proof>
</goal> </goal>
<goal name="WP_parameter eq_enum" expl="correctness of parameter eq_enum" sum="70b74c191411efdf762cca0c55ea9f7c" proved="true" expanded="true"> <goal name="WP_parameter eq_enum" expl="correctness of parameter eq_enum" sum="cb0dc47b965bccbbddec9afc19d506a6" proved="true" expanded="true">
<transf name="split_goal" proved="true" expanded="true"> <transf name="split_goal" proved="true" expanded="true">
<goal name="WP_parameter eq_enum.1" expl="correctness of parameter eq_enum" sum="8efd103daf9ddccb43746a8d352ad0e5" proved="true" expanded="true"> <goal name="WP_parameter eq_enum.1" expl="correctness of parameter eq_enum" sum="22293cfa748a377a7ef45ef9c269e46e" proved="true" expanded="true">
<proof prover="cvc3" timelimit="10" edited="" obsolete="false"> <proof prover="cvc3" timelimit="10" edited="" obsolete="false">
<result status="valid" time="0.03"/> <result status="valid" time="0.11"/>
</proof> </proof>
<result status="timeout" time="10.07"/> <result status="valid" time="0.04"/>
</proof> </proof>
<proof prover="z3" timelimit="10" edited="" obsolete="false"> <proof prover="z3" timelimit="10" edited="" obsolete="false">
<result status="valid" time="1.06"/> <result status="valid" time="3.11"/>
</proof> </proof>
</goal> </goal>
<goal name="WP_parameter eq_enum.2" expl="correctness of parameter eq_enum" sum="55ffebc1aea30da2b2cadc0dd6637f0c" proved="true" expanded="true"> <goal name="WP_parameter eq_enum.2" expl="correctness of parameter eq_enum" sum="026769b58a16abea86cafcb8c45b893d" proved="true" expanded="true">
<result status="valid" time="0.05"/> <result status="valid" time="0.07"/>
</proof> </proof>
</goal> </goal>
<goal name="WP_parameter eq_enum.3" expl="correctness of parameter eq_enum" sum="b53fbfedc75c5b5ec5ac70d08cf8b227" proved="true" expanded="true"> <goal name="WP_parameter eq_enum.3" expl="correctness of parameter eq_enum" sum="84a8181acf56c883f3115292701baf53" proved="true" expanded="true">
<result status="valid" time="0.02"/> <result status="valid" time="0.03"/>
</proof> </proof>
</goal> </goal>
<goal name="WP_parameter eq_enum.4" expl="correctness of parameter eq_enum" sum="6c0281f01c50610cb3cd19d653d1d708" proved="true" expanded="true"> <goal name="WP_parameter eq_enum.4" expl="correctness of parameter eq_enum" sum="e5c26d89e960ac60062a2bbf332f621f" proved="true" expanded="true">
<result status="valid" time="0.03"/> <result status="valid" time="0.03"/>
</proof> </proof>
</goal> </goal>
<goal name="WP_parameter eq_enum.5" expl="correctness of parameter eq_enum" sum="ccebd2695c718ca0752b3d797f508b10" proved="true" expanded="true"> <goal name="WP_parameter eq_enum.5" expl="correctness of parameter eq_enum" sum="72994225ed86ff50a7c92f47f77407a6" proved="true" expanded="true">
<result status="valid" time="0.02"/> <result status="valid" time="0.02"/>
</proof> </proof>
</goal> </goal>
<goal name="WP_parameter eq_enum.6" expl="correctness of parameter eq_enum" sum="36c65fbebc64ad2a8e593310f4a5bc27" proved="true" expanded="true"> <goal name="WP_parameter eq_enum.6" expl="correctness of parameter eq_enum" sum="79a1095a08a00d64512e15170f9d196b" proved="true" expanded="true">
<result status="valid" time="0.04"/> <result status="valid" time="0.03"/>
</proof> </proof>
</goal> </goal>
</transf> </transf>
</goal> </goal>
<goal name="WP_parameter same_fringe" expl="normal postcondition" sum="84928bdc563afca8c3391397c48ceba3" proved="true" expanded="true"> <goal name="WP_parameter same_fringe" expl="normal postcondition" sum="78714b83a0adc89473a2d8ca868bb95e" proved="true" expanded="true">
</proof> </proof>
</goal> </goal>
</theory> </theory>
