Commit 535c0533 authored by Benedikt Becker's avatar Benedikt Becker
Destruct conditionals and match expressions
Fixes #264
parent 6dc5b0d6
constant x: int
predicate p int
axiom H: if x = 42 then p 1 else p 2
goal g: p 3
use list.List
use list.Length
use int.Int
constant l: list int
axiom H': match l with
| Nil -> p 4
| Cons x y -> p (x+length y)
| Cons _ (Cons y Nil) -> p y
| Cons x (Cons y z) -> p (x+y+length z)
| Cons _ (Cons _ (Cons _ _)) -> p 5
goal g': p 6
axiom H'': match l with
| Nil -> p 1
| Cons x Nil | Cons _ (Cons x Nil) -> p x
| Cons _ (Cons _ _ as l') -> p (length l')
goal g'': p 7
axiom H''': match l with
| Cons _ (Cons _ _ as l') as l'' -> p (length l'+length l'')
| _ -> p 0
goal g''': p 8
\ No newline at end of file
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE why3session PUBLIC "-//Why3//proof session v5//EN"
"http://why3.lri.fr/why3session.dtd">
<why3session shape_version="5">
<file>
<path name=".."/>
<path name="264_destruct_if.mlw"/>
<theory name="Top">
<goal name="g">
<transf name="destruct" arg1="H">
<goal name="g.0">
</goal>
<goal name="g.1">
</goal>
</transf>
</goal>
<goal name="g&#39;">
<transf name="destruct" arg1="H&#39;">
<goal name="g&#39;.0">
</goal>
<goal name="g&#39;.1">
</goal>
<goal name="g&#39;.2">
</goal>
<goal name="g&#39;.3">
</goal>
<goal name="g&#39;.4">
</goal>
</transf>
</goal>
<goal name="g&#39;&#39;">
<transf name="destruct" arg1="H&#39;&#39;">
<goal name="g&#39;&#39;.0">
</goal>
<goal name="g&#39;&#39;.1">
</goal>
<goal name="g&#39;&#39;.2">
</goal>
<goal name="g&#39;&#39;.3">
</goal>
</transf>
</goal>
<goal name="g&#39;&#39;&#39;">
<transf name="destruct" arg1="H&#39;&#39;&#39;">
<goal name="g&#39;&#39;&#39;.0">
</goal>
<goal name="g&#39;&#39;&#39;.1">
</goal>
</transf>
</goal>
</theory>
</file>
</why3session>
......@@ -268,6 +268,59 @@ let destruct_fmla ~recursive (t: term) =
else
(* The hypothesis is trivial because Cs1 <> Cs2 thus useless *)
| Tif (t1, t2, t3) -> [
[Axiom_term t1; Axiom_term t2];
[Axiom_term (t_not t1); Axiom_term t3];
| Tcase (t, tbs) ->
let for_case tb =
let p, t' = t_open_branch tb in
let rec expand p : ((vsymbol option * lsymbol) list * (vsymbol * lsymbol * term) list * term) list =
match p.pat_node with
| Pwild ->
let id = Ident.id_fresh "_" in
let ls = create_lsymbol id [] (Some p.pat_ty) in
[[None, ls], [], t_app ls [] ls.ls_value]
| Pvar v ->
let id = Ident.id_clone v.vs_name in
[[Some v, ls], [], t_app ls [] ls.ls_value]
| Papp (ls, args) ->
let rec aux args =
match args with
| [] -> [[], [], []] (* really. *)
| arg::args' ->
let l1 = expand arg in
let l2 = aux args' in
List.flatten
(List.map (fun (x, eqs, t) ->
List.map (fun (y, eqs', l) ->
x@y, eqs@eqs', t::l)
l2)
l1)
in
List.map (fun (bds, eqs, args) -> bds, eqs, t_app ls args (Some p.pat_ty)) (aux args)
| Por (p1, p2) ->
let l1 = expand p1 in
let l2 = expand p2 in
l1 @ l2
| Pas (p, v) ->
List.map (fun (bds, eqs, t) -> bds, eqs@[(v, ls, t)], t_app ls [] ls.ls_value) (expand p)
in
let for_expansion (bds, eqs, t'') =
let mvs = List.fold_left (fun acc vls -> match vls with Some v, ls -> Mvs.add v (t_app ls [] ls.ls_value) acc | None, _ -> acc) Mvs.empty bds in
let mvs = List.fold_left (fun acc (vs, ls, _) -> Mvs.add vs (t_app ls [] ls.ls_value) acc) mvs eqs in
List.map (fun (_, ls) -> Param (create_param_decl ls)) bds @
List.map (fun (_, ls, t) -> Param (create_logic_decl [make_ls_defn ls [] t])) eqs @
[Axiom_term (t_equ t t'');
Axiom_term (t_subst mvs t')]
in
List.map for_expansion (expand p)
in
List.flatten
(List.map for_case tbs)
| _ -> raise (Arg_trans ("destruct"))
in
destruct_fmla ~toplevel:true t
