make bench
parent 761b06a8
theory A end theory A end
theory B end theory B end
theory C use A use A:B end theory C use A use B as A end
(* test file *)
theory A
type t
axiom Ax : forall x:t. true
theory B
use export A
axiom Ax : true
(* test file *)
theory A
type t
theory B
use A
use A
...@@ -145,10 +145,15 @@ let close_namespace uc n ~import = ...@@ -145,10 +145,15 @@ let close_namespace uc n ~import =
match uc.uc_visible, uc.uc_import, uc.uc_export with match uc.uc_visible, uc.uc_import, uc.uc_export with
| v0 :: v1 :: stv, i0 :: i1 :: sti, e0 :: e1 :: ste -> | v0 :: v1 :: stv, i0 :: i1 :: sti, e0 :: e1 :: ste ->
let s = n.id_short in let s = n.id_short in
let add ns1 ns2 = { ns2 with namespace = M.add s ns1 ns2.namespace } in let add ~check ns1 ns2 =
let v1 = add v0 v1 and i1 = add i0 i1 and e1 = add e0 e1 in if check && M.mem s ns2.namespace then raise (ClashSymbol s);
in
let v1 = add ~check:false v0 v1 in
let i1 = add ~check:true i0 i1 in
let e1 = add ~check:false e0 e1 in
let v1 = if import then fusion ~check:false v0 v1 else v1 in let v1 = if import then fusion ~check:false v0 v1 else v1 in
let i1 = if import then fusion ~check:true i0 i1 else i1 in let i1 = if import then fusion ~check:true i0 i1 else i1 in
add_known n add_known n
{ uc with { uc with
uc_visible = v1 :: stv; uc_visible = v1 :: stv;
...@@ -200,6 +205,9 @@ let clone_export th t i = ...@@ -200,6 +205,9 @@ let clone_export th t i =
Mps.iter check_ps i.inst_ps; Mps.iter check_ps i.inst_ps;
assert false (* TODO *) assert false (* TODO *)
let check_fmla k f =
() (* TODO *)
let generic_add ~check x v m = let generic_add ~check x v m =
if check && M.mem x m then raise (ClashSymbol x); if check && M.mem x m then raise (ClashSymbol x);
M.add x v m M.add x v m
...@@ -210,6 +218,8 @@ let add_fsymbol ~check x ty ns = ...@@ -210,6 +218,8 @@ let add_fsymbol ~check x ty ns =
{ ns with fsymbols = generic_add ~check x ty ns.fsymbols } { ns with fsymbols = generic_add ~check x ty ns.fsymbols }
let add_psymbol ~check x ty ns = let add_psymbol ~check x ty ns =
{ ns with psymbols = generic_add ~check x ty ns.psymbols } { ns with psymbols = generic_add ~check x ty ns.psymbols }
let add_prop ~check x v ns =
{ ns with props = generic_add ~check x v ns.props }
let add_symbol add x v uc = let add_symbol add x v uc =
...@@ -238,6 +248,10 @@ let add_decl uc d = ...@@ -238,6 +248,10 @@ let add_decl uc d =
| Dlogic [Lpredicate (ps, None)] -> | Dlogic [Lpredicate (ps, None)] ->
let uc = add_param ps.ps_name uc in let uc = add_param ps.ps_name uc in
add_symbol add_psymbol ps.ps_name ps uc add_symbol add_psymbol ps.ps_name ps uc
| Dprop (k, id, f) ->
check_fmla uc.uc_known f;
let uc = add_known id uc in
add_symbol add_prop id f uc
| _ -> | _ ->
in in
...@@ -512,9 +512,12 @@ let term env t = ...@@ -512,9 +512,12 @@ let term env t =
let t = dterm denv t in let t = dterm denv t in
term M.empty t term M.empty t
let axiom loc s f env = let add_prop k loc s f th =
ignore (fmla env f); let f = fmla th f in
env try
add_decl th (Dprop (k, id_user s.id s.id loc, f))
with ClashSymbol _ ->
error ~loc (Clash s.id)
let find_in_loadpath env f = let find_in_loadpath env f =
let rec find c lp = match lp, c with let rec find c lp = match lp, c with
...@@ -606,7 +609,7 @@ and add_decl env th = function ...@@ -606,7 +609,7 @@ and add_decl env th = function
| Logic (loc, ids, PFunction (pl, t)) -> | Logic (loc, ids, PFunction (pl, t)) ->
List.fold_left (add_function loc pl t) th ids List.fold_left (add_function loc pl t) th ids
| Axiom (loc, s, f) -> | Axiom (loc, s, f) ->
axiom loc s f th add_prop Theory.Axiom loc s f th
| Use (loc, use) -> | Use (loc, use) ->
let t = find_theory env use.use_theory in let t = find_theory env use.use_theory in
let n = match use.use_as with let n = match use.use_as with
...@@ -3,9 +3,11 @@ ...@@ -3,9 +3,11 @@
theory A theory A
type t type t
end end
theory B theory B
type t use A
use A use A
end end
