a variant of list reversal using sequences instead of lists
parent e8d1217c
...@@ -168,10 +168,178 @@ module InPlaceRev ...@@ -168,10 +168,178 @@ module InPlaceRev
end end
(** Using sequences instead of lists *)
module InPlaceRevSeq
use import int.Int
use map.Map
use import seq.Seq
use import ref.Ref
predicate mem (x: 'a) (s: seq 'a) =
exists i. 0 <= i < length s /\ s[i] = x
predicate disjoint (s1: seq 'a) (s2: seq 'a) =
forall x:'a. not (mem x s1 /\ mem x s2)
predicate no_repet (s: seq 'a) =
forall i. 0 <= i < length s -> not (mem s[i] s[i+1 ..])
let rec ghost mem_decomp (x: 'a) (s: seq 'a) : (seq 'a, seq 'a)
requires { mem x s }
variant { length s }
returns { (s1,s2) -> s == s1 ++ cons x s2 }
= if length s = 0 then
absurd
else
let h = s[0] in
let t = s[1 .. ] in
if h = x then (empty, t)
else let (r1, r2) = mem_decomp x t in (cons h r1, r2)
type loc
function null: loc
type memory 'a = ref (Map.map loc 'a)
val acc (field: memory 'a) (l:loc) : 'a
requires { l <> null }
reads { field }
ensures { result = Map.get !field l }
val upd (field: memory 'a) (l: loc) (v: 'a) : unit
writes { field }
ensures { !field = Map.set (old !field) l v }
type next = Map.map loc loc
predicate list_seg (next: next) (p: loc) (s: seq loc) (q: loc) =
let n = length s in
(forall i. 0 <= i < n -> s[i] <> null) /\
( (p = q /\ n = 0)
\/ (1 <= n /\ s[0] = p /\ Map.get next s[n-1] = q /\
forall i. 0 <= i < n-1 -> Map.get next s[i] = s[i+1]))
lemma list_seg_frame_ext:
forall next1 next2: next, p q r v: loc, pM: seq loc.
list_seg next1 p pM r ->
next2 = Map.set next1 q v ->
not (mem q pM) ->
list_seg next2 p pM r
lemma non_empty_seq:
forall s: seq 'a. length s > 0 ->
s == cons s[0] s[1 .. ]
let rec lemma list_seg_functional (next: next) (l1 l2: seq loc) (p: loc)
requires { list_seg next p l1 null }
requires { list_seg next p l2 null }
variant { length l1 }
ensures { l1 == l2 }
= if length l1 > 0 && length l2 > 0 then begin
assert { l1[0] = l2[0] = p };
list_seg_functional next l1[1 ..] l2[1 ..] (Map.get next p)
let rec lemma list_seg_tail (next: next) (l1: seq loc) (p q: loc)
requires { list_seg next p l1 q }
requires { length l1 > 0 }
ensures { list_seg next (Map.get next p)l1[1 .. ] q }
= if length l1 > 1 then
list_seg_tail next l1[1 ..] (Map.get next p) q
let rec lemma list_seg_append (next: next) (p q r: loc) (pM qM: seq loc)
requires { list_seg next p pM q }
requires { list_seg next q qM r }
variant { length pM }
ensures { list_seg next p (pM ++ qM) r }
= if length pM > 0 then
list_seg_append next (Map.get next p) q r pM[1 .. ] qM
lemma seq_tail_append:
forall l1 l2: seq 'a.
length l1 > 0 -> (l1 ++ l2)[1 .. ] == l1[1 .. ] ++ l2
let rec lemma list_seg_prefix (next: next) (l1 l2: seq loc) (p q: loc)
requires { list_seg next p (l1 ++ cons q l2) null }
ensures { list_seg next p l1 q }
= if length l1 > 0 then begin
list_seg_tail next (l1 ++ cons q l2) p null;
list_seg_prefix next l1[1 ..] l2 (Map.get next p) q
let rec lemma list_seg_sublistl (next: next) (l1 l2: seq loc) (p q: loc)
ensures { list_seg next q (cons q l2) null }
= assert { list_seg next p l1 q };
list_seg_tail next l1 p q;
list_seg_sublistl next l1[1 ..] l2 (Map.get next p) q
lemma get_tail:
forall i: int, s: seq 'a. 0 <= i < length s - 1 -> s[1 .. ][i] = s[i+1]
lemma tail_suffix:
forall i: int, s: seq 'a. 0 <= i < length s -> s[1 .. ][i .. ] == s[i+1 ..]
let rec lemma list_seg_no_repet (next: next) (p: loc) (pM: seq loc)
requires { list_seg next p pM null }
ensures { no_repet pM }
= if length pM > 0 then begin
let h = pM[0] in
let t = pM[1 .. ] in
if mem h t then
(* absurd case *)
let (l1,l2) = mem_decomp h t in
list_seg_sublistl next (cons h l1) l2 p h;
list_seg_functional next pM (cons h l2) p;
assert { length pM > length (cons h l2) }
else begin
assert { not (mem pM[0] pM[0+1 .. ]) };
list_seg_no_repet next (Map.get next p) t;
assert { forall i. 1 <= i < length pM -> not (mem pM[i] pM[i+1 .. ]) }
val next : ref next
let app (l1 l2: loc) (ghost l1M l2M: seq loc) : loc
requires { list_seg !next l1 l1M null }
requires { list_seg !next l2 l2M null }
requires { disjoint l1M l2M }
ensures { list_seg !next result (l1M ++ l2M) null }
if l1 = null then l2 else
let p = ref l1 in
let ghost pM = ref l1M in
let ghost l1pM = ref (empty : seq loc) in
while acc next !p <> null do
invariant { !p <> null }
invariant { list_seg !next l1 !l1pM !p }
invariant { list_seg !next !p !pM null }
invariant { !l1pM ++ !pM == l1M }
invariant { disjoint !l1pM !pM }
variant { length !pM }
assert { length !pM > 0 };
let t = !pM[ 1 .. ] in
l1pM := !l1pM ++ cons !p empty;
pM := t;
p := acc next !p
done;
upd next !p l2;
assert { list_seg !next l1 !l1pM !p };
assert { list_seg !next !p (cons !p empty) l2 };
assert { list_seg !next l2 l2M null };
l1
Local Variables: Local Variables:
This diff is collapsed.
