Commit 5266b967 authored by Sylvain Dailler's avatar Sylvain Dailler
minor use constant strings for column names
parent 6b4fa6f2
...@@ -502,9 +502,13 @@ let status_column = cols#add Gobject.Data.gobject ...@@ -502,9 +502,13 @@ let status_column = cols#add Gobject.Data.gobject
(* fifth column: extra status info: time, obsolete status, limits *) (* fifth column: extra status info: time, obsolete status, limits *)
let time_column = cols#add Gobject.Data.string let time_column = cols#add Gobject.Data.string
let column_status_title = "Status"
let column_time_title = "Time"
let column_goals_title = "Theories/Goals"
(* first view column: icon and name *) (* first view column: icon and name *)
let view_name_column = let view_name_column =
let v = GTree.view_column ~title:"Theories/Goals" () in let v = GTree.view_column ~title:column_goals_title () in
(* icon attribute *) (* icon attribute *)
let icon_renderer = GTree.cell_renderer_pixbuf [ ] in let icon_renderer = GTree.cell_renderer_pixbuf [ ] in
v#pack icon_renderer ~expand:false; v#pack icon_renderer ~expand:false;
...@@ -520,7 +524,7 @@ let view_name_column = ...@@ -520,7 +524,7 @@ let view_name_column =
(* second view column: status *) (* second view column: status *)
let view_status_column = let view_status_column =
let status_renderer = GTree.cell_renderer_pixbuf [ ] in let status_renderer = GTree.cell_renderer_pixbuf [ ] in
let v = GTree.view_column ~title:"Status" let v = GTree.view_column ~title:column_status_title
~renderer:(status_renderer, ["pixbuf", status_column]) ~renderer:(status_renderer, ["pixbuf", status_column])
in in
...@@ -530,7 +534,7 @@ let view_status_column = ...@@ -530,7 +534,7 @@ let view_status_column =
let view_time_column = let view_time_column =
let renderer = GTree.cell_renderer_text [`XALIGN 0.] in let renderer = GTree.cell_renderer_text [`XALIGN 0.] in
let v = GTree.view_column ~title:"Time" let v = GTree.view_column ~title:column_time_title
~renderer:(renderer, ["text", time_column]) () ~renderer:(renderer, ["text", time_column]) ()
in in
v#set_resizable false; v#set_resizable false;
...@@ -1631,9 +1635,9 @@ let set_status_and_time_column ?limit row = ...@@ -1631,9 +1635,9 @@ let set_status_and_time_column ?limit row =
Format.sprintf "%.2f" time Format.sprintf "%.2f" time
in in
if steps >= 0 then if steps >= 0 then
Format.sprintf "%s (steps: %d)" s steps Format.sprintf "%s (steps: %d)" s steps
else else
s s
| C.InternalFailure _ -> "(internal failure)" | C.InternalFailure _ -> "(internal failure)"
| C.Interrupted -> "(interrupted)" | C.Interrupted -> "(interrupted)"
| C.Undone -> "(undone)" | C.Undone -> "(undone)"
