Commit 50c49ee1 authored by Andrei Paskevich's avatar Andrei Paskevich
optimisaton in [tf]_abst
parent 88b10949
...@@ -651,12 +651,10 @@ let f_any_unsafe prT prF f = ...@@ -651,12 +651,10 @@ let f_any_unsafe prT prF f =
(* replaces variables with de Bruijn indices in term [t] using map [m] *) (* replaces variables with de Bruijn indices in term [t] using map [m] *)
let bnd_add i (lvl,rb) = rb := Sint.add (i + lvl) !rb
let rec t_abst m l lvl t = t_label_copy t (match t.t_node with let rec t_abst m l lvl t = t_label_copy t (match t.t_node with
| Tvar u -> begin try | Tvar u -> begin try
let i = Mvs.find u m in let i = Mvs.find u m in
List.iter (bnd_add i) l; l := Sint.add i !l;
t_bvar (i + lvl) t.t_ty t_bvar (i + lvl) t.t_ty
with Not_found -> t end with Not_found -> t end
| Tlet (e, (u,b,t1)) -> | Tlet (e, (u,b,t1)) ->
...@@ -684,27 +682,32 @@ and f_abst m l lvl f = f_label_copy f (match f.f_node with ...@@ -684,27 +682,32 @@ and f_abst m l lvl f = f_label_copy f (match f.f_node with
f_map_unsafe (t_abst m l lvl) (f_abst m l lvl) f) f_map_unsafe (t_abst m l lvl) (f_abst m l lvl) f)
and bnd_t_abst m l lvl bv t = and bnd_t_abst m l lvl bv t =
let rb = ref bv.bv_open in let l' = ref Sint.empty in
let bv = bnd_map (t_abst m l lvl) bv in let bv = bnd_map (t_abst m l lvl) bv in
let t = t_abst m ((lvl,rb) :: l) (lvl + bv.bv_bound) t in let t = t_abst m l' (lvl + bv.bv_bound) t in
{ bv with bv_open = !rb }, t update_open lvl l l' bv, t
and bnd_f_abst m l lvl bv f = and bnd_f_abst m l lvl bv f =
let f = f_abst m ((lvl,rb) :: l) (lvl + bv.bv_bound) f in let f = f_abst m l' (lvl + bv.bv_bound) f in
{ bv with bv_open = !rb }, f update_open lvl l l' bv, f
and bnd_q_abst m l lvl (vl,bv,tl,f) = and bnd_q_abst m l lvl (vl,bv,tl,f) =
let lvl' = lvl + bv.bv_bound in
let l = (lvl,rb) :: l in let lvl = lvl + bv.bv_bound in let tl = tr_map (t_abst m l' lvl') (f_abst m l' lvl') tl in
let tl = tr_map (t_abst m l lvl) (f_abst m l lvl) tl in let f = f_abst m l' lvl' f in
let f = f_abst m l lvl f in vl, update_open lvl l l' bv, tl, f
vl, { bv with bv_open = !rb }, tl, f
and update_open lvl l l' bv =
l := Sint.union !l' !l;
let add i acc = Sint.add (i + lvl) acc in
{ bv with bv_open = Sint.fold add !l' bv.bv_open }
let t_abst m t = t_abst m [] 0 t let t_abst m t = t_abst m (ref Sint.empty) 0 t
let f_abst m f = f_abst m [] 0 f let f_abst m f = f_abst m (ref Sint.empty) 0 f
(* replaces de Bruijn indices with variables in term [t] using map [m] *) (* replaces de Bruijn indices with variables in term [t] using map [m] *)
