GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
50b0727d
50b0727d
MARCHE Claude
Update some extraction examples of the bench
fb77f394
7
7 changed files
40 additions
20 deletions
+40
-20
bench/bench
bench/bench
+12
-9
examples/TODO
examples/TODO
+0
-2
examples/euler001/Makefile
+2
-3
examples/euler001/main.ml
+4
-2
examples/gcd.mlw
examples/gcd.mlw
+19
examples/gcd/Makefile
+2
-3
examples/gcd/main.ml
+1
-1
bench/bench
50b0727d
@@ -225,6 +225,18 @@ execute examples/vstte10_queens.mlw NQueens.test8
echo
echo
echo
"=== Extraction to Ocaml ==="
extract_and_run examples/euler001 euler001.ml 1000000
extract_and_run examples/gcd gcd.ml 6 15
echo
"TODO: update 4 more extraction examples"
# extract_and_run examples/vstte10_max_sum vstte10_max_sum__*.ml
# extract_and_run examples/vstte12_combinators vstte12_combinators__*.ml "((((K K) K) K) K)"
# extract_and_run examples/sudoku sudoku__*.ml 2,0,9,0,0,0,0,1,0,0,0,0,0,6,0,0,0,0,0,5,3,8,0,2,7,0,0,3,0,0,0,0,0,0,0,0,0,0,0,0,7,5,0,0,3,0,4,1,2,0,8,9,0,0,0,0,4,0,9,0,0,2,0,8,0,0,0,0,1,0,0,5,0,0,0,0,0,0,0,7,6
# extract_and_run examples/defunctionalization defunctionalization__*.ml
echo
echo
"=== Checking good files ==="
echo
goods bench/typing/good
goods bench/programs/good
@@ -244,15 +256,6 @@ goods examples/double_wp "-L examples/double_wp"
goods examples/in_progress
echo
echo
echo
extract_and_run examples/euler001 euler001__
.ml 1000000
extract_and_run examples/gcd gcd__
.ml 6 15
.ml
.ml
"((((K K) K) K) K)"
.ml
echo
echo
"=== Checking valid goals ==="
echo
valid_goals bench/valid
echo
echo
examples/TODO
50b0727d
@@ -4,11 +4,9 @@ bignum.mlw
counting_sort.mlw
counting_sort.mlw
cursor.mlw
cursor.mlw
dijkstra.mlw
dijkstra.mlw
fibonacci.mlw
find.mlw
find.mlw
gcd.mlw
gcd.mlw
hashtbl_impl.mlw
hashtbl_impl.mlw
ieee_float.mlw
kmp.mlw
kmp.mlw
knuth_prime_numbers.mlw
koda_ruskey.mlw
koda_ruskey.mlw
50b0727d
@@ -20,7 +20,7 @@ ifeq ($(BENCH),yes)
endif
endif
MAIN
main
MAIN
main
OBJ
euler001
__Euler001
OBJ
euler001
ML
addsuffix
.ml,
$(OBJ)
ML
addsuffix
.ml,
$(OBJ)
CMO
addsuffix
.cmo,
$(OBJ)
CMO
addsuffix
.cmo,
$(OBJ)
@@ -45,7 +45,7 @@ $(MAIN).opt: $(CMX) $(MAIN).cmx
$(MAIN).cmx
$(CMX)
$(MAIN).cmx
$(CMX)
$(ML)
../euler001.mlw
$(ML)
../euler001.mlw
$(WHY3)
extract
-D
ocaml
32 ../euler001.mlw
-o
$(WHY3)
extract
-D
ocaml
64
-o
%.cmx
%.ml
%.cmx
%.ml
$(OCAMLOPT)
$(INCLUDE)
-annot
-c
$(OCAMLOPT)
$(INCLUDE)
-annot
-c
@@ -59,4 +59,3 @@ $(ML): ../euler001.mlw
clean
clean
rm
-f
$(ML)
.cm[xio]
.o
.annot
$(MAIN)
.opt
$(MAIN)
.byte
rm
-f
$(ML)
.cm[xio]
.o
.annot
$(MAIN)
.opt
$(MAIN)
.byte
rm
-f
why3__
.ml
euler001__
.ml
int__
.ml
rm
-f
why3__
.ml
euler001__
.ml
int__
.ml
50b0727d
@@ -11,11 +11,13 @@ let input =
if
Array
length
Sys
argv
2
then
usage
if
Array
length
Sys
argv
2
then
usage
Sys
argv
Sys
argv
let () =
let () =
if input = "go" then begin
Euler001
__Euler001
go
Euler001.go ();
exit 0
exit 0
let
input_num
let
input_num
try
try
@@ -23,6 +25,6 @@ let input_num =
_
usage
_
usage
let
let
let
a
Euler001
__Euler001
solve
input_num
in
let
a
Euler001
solve
input_num
in
printf
"The sum of all the multiples of 3 or 5 below %s is %s@."
printf
Why3__BigInt
to_string
input_num
Why3__BigInt
to_string
a
Why3__BigInt
to_string
input_num
Why3__BigInt
to_string
a
examples/gcd.mlw
50b0727d
@@ -93,6 +93,7 @@ end
Note that we assume parameters u, v to be nonnegative.
Otherwise, for u = v = min_int, the gcd could not be represented. *)
(* does not work with extraction driver ocaml64
module EuclideanAlgorithm31
use import mach.int.Int31
@@ -109,3 +110,21 @@ module EuclideanAlgorithm31
euclid v (u % v)
euclid v (u % v)
module EuclideanAlgorithm63
use import mach.int.Int63
use import number.Gcd
let rec euclid (u v: int63) : int63
variant { to_int v }
requires { to_int u >= 0 /\ to_int v >= 0 }
ensures { to_int result = gcd (to_int u) (to_int v) }
if Int63.eq v (of_int 0) then
u
else
euclid v (u % v)
50b0727d
endif
endif
MAIN
main
MAIN
main
GEN
gcd__EuclideanAlgorithm31
GEN
euclideanAlgorithm63
OBJ
$(GEN)
OBJ
$(GEN)
GENML
addsuffix
.ml,
$(GEN)
GENML
addsuffix
.ml,
$(GEN)
@@ -44,7 +44,7 @@ $(MAIN).opt: $(CMX) $(MAIN).cmx
$(MAIN).cmx
$(CMX)
$(MAIN).cmx
$(CMX)
$(GENML)
../gcd.mlw
$(GENML)
../gcd.mlw
$(WHY3)
extract
-D
ocaml
32
-o
$(WHY3)
extract
-D
ocaml
64
-L
-o
gcd.EuclideanAlgorithm63
%.cmx
%.ml
%.cmx
%.ml
$(OCAMLOPT)
$(INCLUDE)
-annot
-c
$(OCAMLOPT)
$(INCLUDE)
-annot
-c
@@ -78,4 +78,3 @@ $(JSMAIN).byte: $(ML) jsmain.ml
clean
clean
rm
-f
.cm[io]
$(NAME)
.byte
$(NAME)
.js
rm
-f
.cm[io]
$(NAME)
.byte
$(NAME)
.js
50b0727d
@@ -4,7 +4,7 @@ open Format
let
let
printf
"%d@."
printf
"%d@."
Gcd__EuclideanAlgorithm31
euclid
int_of_string
Sys
argv
int_of_string
Sys
argv
2
euclid
int_of_string
Sys
argv
int_of_string
Sys
argv
2
let usage () =
let usage () =
