Commit 50656d81 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Remove some obsolete Coq notations.
Since these files depend on Flocq, we are sure that Coq is at least 8.7.
parent 3895e560
...@@ -72,7 +72,7 @@ apply Rmult_le_compat. ...@@ -72,7 +72,7 @@ apply Rmult_le_compat.
now apply (IZR_le 0). now apply (IZR_le 0).
apply bpow_ge_0. apply bpow_ge_0.
apply IZR_le. apply IZR_le.
apply (Z.lt_le_pred (Zabs (Zpos m)) (Zpower radix2 24)). apply (Z.lt_le_pred (Z.abs (Zpos m)) (Zpower radix2 24)).
apply Digits.Zpower_gt_Zdigits. apply Digits.Zpower_gt_Zdigits.
revert H1. revert H1.
generalize (Digits.Zdigits radix2 (Z.pos m)). generalize (Digits.Zdigits radix2 (Z.pos m)).
...@@ -74,7 +74,7 @@ apply Rmult_le_compat. ...@@ -74,7 +74,7 @@ apply Rmult_le_compat.
apply (Z.lt_le_pred (Zabs (Zpos m)) (Zpower radix2 53)). apply (Z.lt_le_pred (Z.abs (Zpos m)) (Zpower radix2 53)).
...@@ -1207,7 +1207,7 @@ Proof. ...@@ -1207,7 +1207,7 @@ Proof.
fold sb. fold sb.
unfold FLT_exp. unfold FLT_exp.
replace (sb - 1 + 1 + 1 - sb)%Z with 1%Z by ring. replace (sb - 1 + 1 + 1 - sb)%Z with 1%Z by ring.
apply Zmax_l. apply Z.max_l.
pose sb_gt_1; pose Hemax'; omega. pose sb_gt_1; pose Hemax'; omega.
apply Zle_bool_true. apply Zle_bool_true.
pose Hemax'; pose Hsbb; omega. pose Hemax'; pose Hsbb; omega.
...@@ -1276,7 +1276,7 @@ Lemma Exact_rounding_for_integers : ...@@ -1276,7 +1276,7 @@ Lemma Exact_rounding_for_integers :
Proof with auto with typeclass_instances. Proof with auto with typeclass_instances.
intros m z Hz. intros m z Hz.
apply round_generic... apply round_generic...
assert (Zabs z <= pow2sb)%Z. assert (Z.abs z <= pow2sb)%Z.
apply Z.abs_le with (1:=Hz). apply Z.abs_le with (1:=Hz).
destruct (Zle_lt_or_eq _ _ H) as [Bz|Bz] ; clear H Hz. destruct (Zle_lt_or_eq _ _ H) as [Bz|Bz] ; clear H Hz.
apply generic_format_FLT. apply generic_format_FLT.
...@@ -4633,7 +4633,7 @@ Proof. ...@@ -4633,7 +4633,7 @@ Proof.
fold sb. fold sb.
replace (sb - 1 + 1 + - sb)%Z with 0%Z by ring. replace (sb - 1 + 1 + - sb)%Z with 0%Z by ring.
pose Hemax'; pose sb_gt_1; omega. pose Hemax'; pose sb_gt_1; omega.
