Commit 4fa83226 authored by François Bobot's avatar François Bobot
pp : add one ansi-code function
parent 87db1335
......@@ -377,7 +377,8 @@ let () =
| Call_provers.Valid -> incr nb_valid
| _ -> () end
| _ -> ();
Format.printf "\027[0G(%i/%i) valid : %i%!"
Format.printf "%a(%i/%i) valid : %i%!"
Pp.Ansi.set_column 0
!nb_done !nb_scheduled !nb_valid
end;
Debug.dprintf Scheduler.debug "%s.%s %a %i with %s : %a@."
......@@ -167,3 +167,9 @@ let string_of_wnl p x =
wnl fmt;
fprintf fmt "%a@?" p x;
Buffer.contents b
module Ansi =
struct
let set_column fmt n = fprintf fmt "\027[%iG" n
......@@ -124,3 +124,8 @@ val string_of_wnl : (Format.formatter -> 'a -> unit) -> 'a -> string
(** same as {!string_of} but without newline *)
val wnl : Format.formatter -> unit
module Ansi :
sig
val set_column : Format.formatter -> int -> unit
