GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
4f7af118
4f7af118
François Bobot
[Tagset] give bounds for max_tags
b800fea5
2
2 changed files
7 additions
3 deletions
+7
-3
examples/stdlib/tagset/why3session.xml
+4
-2
stdlib/mach/tagset.mlw
+3
-1
4f7af118
@@ -34,7 +34,9 @@
@@ -34,7 +34,9 @@
<proof
prover=
"1"
><result
status=
"valid"
time=
"0.11"
/></proof>
<proof
prover=
"1"
><result
status=
"valid"
time=
"0.11"
/></proof>
</goal>
</goal>
<goal
name=
"VC max_tags"
expl=
"VC for max_tags"
proved=
"true"
<goal
name=
"VC max_tags"
expl=
"VC for max_tags"
proved=
"true"
<proof
prover=
"0"
obsolete=
"true"
><result
status=
"timeout"
time=
"1.00"
/></proof>
<proof
prover=
"1"
><result
status=
"valid"
time=
"0.09"
/></proof>
<proof
prover=
"1"
><result
status=
"valid"
time=
"0.09"
/></proof>
<proof
prover=
"2"
obsolete=
"true"
><result
status=
"timeout"
time=
"1.00"
/></proof>
</goal>
</goal>
<goal
name=
"VC resize"
expl=
"VC for resize"
proved=
"true"
<goal
name=
"VC resize"
expl=
"VC for resize"
proved=
"true"
<transf
name=
"split_vc"
proved=
"true"
<transf
name=
"split_vc"
proved=
"true"
@@ -209,7 +211,7 @@
@@ -209,7 +211,7 @@
<proof
prover=
"1"
><result
status=
"valid"
time=
"0.04"
/></proof>
<proof
prover=
"1"
><result
status=
"valid"
time=
"0.04"
/></proof>
</goal>
</goal>
<goal
name=
"VC remove.22"
expl=
"postcondition"
proved=
"true"
<goal
name=
"VC remove.22"
expl=
"postcondition"
proved=
"true"
<proof
prover=
"0"
><result
status=
"valid"
time=
"0.05"
steps=
161
/></proof>
<proof
prover=
"0"
><result
status=
"valid"
time=
"0.05"
steps=
73
/></proof>
</goal>
</goal>
</transf>
</transf>
</goal>
</goal>
@@ -291,7 +293,7 @@
@@ -291,7 +293,7 @@
<goal
name=
"Iterator.VC next"
expl=
"VC for next"
proved=
"true"
<goal
name=
"Iterator.VC next"
expl=
"VC for next"
proved=
"true"
<transf
name=
"split_vc"
proved=
"true"
<transf
name=
"split_vc"
proved=
"true"
<goal
name=
"VC next.0"
expl=
"assertion"
proved=
"true"
<goal
name=
"VC next.0"
expl=
"assertion"
proved=
"true"
<proof
prover=
"0"
><result
status=
"valid"
time=
"0.02"
steps=
86
/></proof>
<proof
prover=
"0"
><result
status=
"valid"
time=
"0.02"
steps=
109
/></proof>
</goal>
</goal>
<goal
name=
"VC next.1"
expl=
"index in array bounds"
proved=
"true"
<goal
name=
"VC next.1"
expl=
proved=
"true"
<proof
prover=
"1"
><result
status=
"valid"
time=
"0.06"
/></proof>
<proof
prover=
"1"
><result
status=
"valid"
time=
"0.06"
/></proof>
4f7af118
@@ -53,6 +53,7 @@ module TagSetIntf
val function max_tags (h: t) : Int63.int63
ensures { forall v. S.mem v h.elts -> tag v <= result }
ensures { -1 <= result < Int63.max_int63 }
val add (h: t) (k: key): unit
requires { k <> S.dummy }
@@ -156,7 +157,8 @@ module TagSet
tag k < Array.length h.iterated.value && Array.(S.tag h.iterated.value[tag k] <> S.tag S.dummy)
let function max_tags (h: t) : Int63.int63
ensures { forall v. S.mem v h.elts -> tag v <= result } =
ensures { -1 <= result < Int63.max_int63 } =
Array.(length h.iterated.value) - 1
let resize (h:t) (k:key) : unit
