Commit 4ed1e418 authored by MARCHE Claude's avatar MARCHE Claude
command for steps different from regular command
parent 264aa6e2
...@@ -7,8 +7,10 @@ version_switch = "-version" ...@@ -7,8 +7,10 @@ version_switch = "-version"
version_regexp = "\\([0-9.]+\\(-dev\\|~beta.prv\\)?\\)" version_regexp = "\\([0-9.]+\\(-dev\\|~beta.prv\\)?\\)"
version_ok = "0.99.1" version_ok = "0.99.1"
version_ok = "0.95.2" version_ok = "0.95.2"
command = "%l/why3-cpulimit %t %m -s %e -timelimit %t %f" # %T means timelimit+1
command_steps = "%l/why3-cpulimit %t %m -s %e -steps-bound %S %f" command = "%l/why3-cpulimit %T %m -s %e -timelimit %t %f"
# %U means 2*timelimit+1
command_steps = "%l/why3-cpulimit %U %m -s %e -steps-bound %S %f"
driver = "drivers/alt_ergo.drv" driver = "drivers/alt_ergo.drv"
editor = "altgr-ergo" editor = "altgr-ergo"
...@@ -22,27 +24,11 @@ version_regexp = "\\([0-9.]+\\(-dev\\)?\\)" ...@@ -22,27 +24,11 @@ version_regexp = "\\([0-9.]+\\(-dev\\)?\\)"
version_old = "0.95.1" version_old = "0.95.1"
version_old = "0.95" version_old = "0.95"
command = "%l/why3-cpulimit %T %m -s %e -timelimit %t %f" command = "%l/why3-cpulimit %T %m -s %e -timelimit %t %f"
# Alt-Ergo print steps but do not have an option to pass them for replay
command_steps = "%l/why3-cpulimit %T %m -s %e -timelimit %t %f"
# [ATP alt-ergo-model]
# name = "Alt-Ergo"
# alternative = "models"
# exec = "alt-ergo"
# exec = "alt-ergo-0.95.3"
# exec = "alt-ergo-0.95.2"
# exec = "alt-ergo-0.95.1"
# exec = "alt-ergo-0.95"
# exec = "alt-ergo-0.95-dev"
# version_switch = "-version"
# version_regexp = "\\([0-9.]+\\(-dev\\)?\\)"
# version_ok = "0.95.1"
# version_old = "0.95"
# version_old = "0.95-dev"
# command = "%l/why3-cpulimit %T %m -s %e -timelimit %t -model %f"
# driver = "drivers/alt_ergo_model.drv"
# editor = "altgr-ergo"
[ATP alt-ergo] [ATP alt-ergo]
name = "Alt-Ergo" name = "Alt-Ergo"
exec = "alt-ergo" exec = "alt-ergo"
...@@ -51,6 +37,8 @@ version_switch = "-version" ...@@ -51,6 +37,8 @@ version_switch = "-version"
version_regexp = "\\([0-9.]+\\)" version_regexp = "\\([0-9.]+\\)"
version_old = "0.94" version_old = "0.94"
command = "%l/why3-cpulimit %t %m -s %e %f" command = "%l/why3-cpulimit %t %m -s %e %f"
command_steps = "%l/why3-cpulimit %t %m -s %e %f"
driver = "drivers/alt_ergo_0.94.drv" driver = "drivers/alt_ergo_0.94.drv"
...@@ -87,34 +75,20 @@ version_old = "0.8" ...@@ -87,34 +75,20 @@ version_old = "0.8"
driver = "drivers/alt_ergo_0.92.drv" driver = "drivers/alt_ergo_0.92.drv"
# CVC4 version 1.5-prerelease # CVC4 version >= 1.4
[ATP cvc4]
name = "CVC4"
exec = "cvc4"
exec = "cvc4-1.5-prerelease"
version_switch = "--version"
version_regexp = "This is CVC4 version \\([^ \n\r]+\\)"
version_ok = "1.5-prerelease"
driver = "drivers/cvc4.drv"
# --random-seed=42 is not needed as soon as --random-freq=0.0 by default
# to try: --inst-when=full-last-call
command = "%l/why3-cpulimit %T %m -s %e --stats --tlimit-per=%t000 --lang=smt2 %f"
command_steps = "%l/why3-cpulimit %T %m -s %e --stats --rlimit=%S --lang=smt2 %f"
# CVC4 version 1.4
[ATP cvc4] [ATP cvc4]
name = "CVC4" name = "CVC4"
exec = "cvc4" exec = "cvc4"
exec = "cvc4-1.4" exec = "cvc4-1.4"
version_switch = "--version" version_switch = "--version"
version_regexp = "This is CVC4 version \\([^ \n\r]+\\)" version_regexp = "This is CVC4 version \\([^ \n\r]+\\)"
version_ok = "1.4" version_ok = "1.4"
driver = "drivers/cvc4_14.drv" driver = "drivers/cvc4_14.drv"
# --random-seed=42 is not needed as soon as --random-freq=0.0 by default # --random-seed=42 is not needed as soon as --random-freq=0.0 by default
# to try: --inst-when=full-last-call # to try: --inst-when=full-last-call
# --rlimit=%S : cvc4 1.4 DOES NOT accept -1 as argument
# cvc4 .14 does not print steps used in --stats anyway
command = "%l/why3-cpulimit %T %m -s %e --tlimit-per=%t000 --lang=smt2 %f" command = "%l/why3-cpulimit %T %m -s %e --tlimit-per=%t000 --lang=smt2 %f"
command_steps = "%l/why3-cpulimit %U %m -s %e --rlimit=%S --lang=smt2 %f"
# CVC4 version 1.0 to 1.3 # CVC4 version 1.0 to 1.3
...@@ -168,7 +142,6 @@ version_switch = "-version" ...@@ -168,7 +142,6 @@ version_switch = "-version"
version_regexp = "This is CVC3 version \\([^ \n]+\\)" version_regexp = "This is CVC3 version \\([^ \n]+\\)"
version_old = "2.2" version_old = "2.2"
version_old = "2.1" version_old = "2.1"
# we pass time 0 to why3-cpulimit to avoid race
command = "%l/why3-cpulimit %T %m -s %e -seed 42 -timeout %t %f" command = "%l/why3-cpulimit %T %m -s %e -seed 42 -timeout %t %f"
driver = "drivers/cvc3.drv" driver = "drivers/cvc3.drv"
...@@ -211,7 +184,6 @@ version_old = "1.7" ...@@ -211,7 +184,6 @@ version_old = "1.7"
version_old = "1.6" version_old = "1.6"
version_old = "1.5" version_old = "1.5"
version_old = "1.4" version_old = "1.4"
command = "%l/why3-cpulimit %T %m -s %e -s -R -xAuto -tAuto --cpu-limit=%t --tstp-in %f" command = "%l/why3-cpulimit %T %m -s %e -s -R -xAuto -tAuto --cpu-limit=%t --tstp-in %f"
driver = "drivers/eprover.drv" driver = "drivers/eprover.drv"
...@@ -303,7 +275,6 @@ exec = "vampire" ...@@ -303,7 +275,6 @@ exec = "vampire"
exec = "vampire-0.6" exec = "vampire-0.6"
version_regexp = "Vampire \\([0-9.]+\\)" version_regexp = "Vampire \\([0-9.]+\\)"
command = "%l/why3-cpulimit %T %m -s %e -t %t" command = "%l/why3-cpulimit %T %m -s %e -t %t"
driver = "drivers/vampire.drv" driver = "drivers/vampire.drv"
version_ok = "0.6" version_ok = "0.6"
...@@ -122,9 +122,12 @@ let print_prover_status fmt = function ...@@ -122,9 +122,12 @@ let print_prover_status fmt = function
| Unix.WSIGNALED n -> fprintf fmt "killed by signal %d" n | Unix.WSIGNALED n -> fprintf fmt "killed by signal %d" n
| Unix.WEXITED n -> fprintf fmt "exited with status %d" n | Unix.WEXITED n -> fprintf fmt "exited with status %d" n
let print_steps fmt s =
if s >= 0 then fprintf fmt ", %d steps)" s
let print_prover_result fmt let print_prover_result fmt
{pr_answer=ans; pr_status=status; pr_output=out; pr_time=t} = {pr_answer=ans; pr_status=status; pr_output=out; pr_time=t; pr_steps=s} =
fprintf fmt "%a (%.2fs)" print_prover_answer ans t; fprintf fmt "%a (%.2fs%a)" print_prover_answer ans t print_steps s;
if ans == HighFailure then if ans == HighFailure then
fprintf fmt "@\nProver exit status: %a@\nProver output:@\n%s@." fprintf fmt "@\nProver exit status: %a@\nProver output:@\n%s@."
print_prover_status status out print_prover_status status out
...@@ -714,7 +714,7 @@ let merge_config config filename = ...@@ -714,7 +714,7 @@ let merge_config config filename =
{ config with main = main; provers = provers; strategies = strategies; { config with main = main; provers = provers; strategies = strategies;
prover_shortcuts = shortcuts; editors = editors } prover_shortcuts = shortcuts; editors = editors }
let debug = Debug.register_info_flag "whyconf" let _debug = Debug.register_info_flag "whyconf"
~desc:"Print@ debugging@ messages@ about@ whyconf." ~desc:"Print@ debugging@ messages@ about@ whyconf."
let save_config config = let save_config config =
...@@ -1149,6 +1149,7 @@ and expr_fun ~keep_loc uloc env pvl dsp de = ...@@ -1149,6 +1149,7 @@ and expr_fun ~keep_loc uloc env pvl dsp de =
let val_decl ?(keep_loc=true) (id,_,_,_,_,_ as vald) = let val_decl ?(keep_loc=true) (id,_,_,_,_,_ as vald) =
ignore keep_loc;
reunify_regions (); reunify_regions ();
Loc.try2 ?loc:id.pre_loc val_decl env_empty vald Loc.try2 ?loc:id.pre_loc val_decl env_empty vald
...@@ -445,20 +445,22 @@ let fuzzy_proof_time nres ores = ...@@ -445,20 +445,22 @@ let fuzzy_proof_time nres ores =
Done { res' with Call_provers.pr_time = told } Done { res' with Call_provers.pr_time = told }
| _, _ -> nres | _, _ -> nres
let dummy_limits = (0,0,0)
(** run_external_proof_v3 doesn't modify existing proof attempt, it can just (** run_external_proof_v3 doesn't modify existing proof attempt, it can just
create new one by find_prover *) create new one by find_prover *)
let run_external_proof_v3 eS eT a callback = let run_external_proof_v3 eS eT a callback =
match find_prover eS a with match find_prover eS a with
| None -> | None ->
callback a a.proof_prover 0 None Starting; callback a a.proof_prover dummy_limits None Starting;
(* nothing to do *) (* nothing to do *)
callback a a.proof_prover 0 None MissingProver callback a a.proof_prover dummy_limits None MissingProver
| Some(ap,npc,a) -> | Some(ap,npc,a) ->
callback a ap 0 None Starting; callback a ap dummy_limits None Starting;
if a.proof_edited_as = None && if a.proof_edited_as = None &&
npc.prover_config.Whyconf.interactive npc.prover_config.Whyconf.interactive
then begin then begin
callback a ap 0 None (MissingFile "unedited") callback a ap dummy_limits None (MissingFile "unedited")
end else begin end else begin
let previous_result = a.proof_state in let previous_result = a.proof_state in
let timelimit, memlimit = adapt_limits a in let timelimit, memlimit = adapt_limits a in
...@@ -474,7 +476,7 @@ let run_external_proof_v3 eS eT a callback = ...@@ -474,7 +476,7 @@ let run_external_proof_v3 eS eT a callback =
let command = Whyconf.get_complete_command npc.prover_config stepslimit in let command = Whyconf.get_complete_command npc.prover_config stepslimit in
let cb result = let cb result =
let result = fuzzy_proof_time result previous_result in let result = fuzzy_proof_time result previous_result in
callback a ap timelimit callback a ap (timelimit,memlimit,stepslimit)
(match previous_result with Done res -> Some res | _ -> None) (match previous_result with Done res -> Some res | _ -> None)
(StatusChange result) in (StatusChange result) in
try try
...@@ -492,13 +494,13 @@ let run_external_proof_v3 eS eT a callback = ...@@ -492,13 +494,13 @@ let run_external_proof_v3 eS eT a callback =
eT eT
(goal_task_or_recover eS a.proof_parent) (goal_task_or_recover eS a.proof_parent)
with NoFile f -> with NoFile f ->
callback a ap 0 None (MissingFile f) callback a ap dummy_limits None (MissingFile f)
end end
(** run_external_proof_v2 modify the session according to the current state *) (** run_external_proof_v2 modify the session according to the current state *)
let run_external_proof_v2 eS eT a callback = let run_external_proof_v2 eS eT a callback =
let previous_res = ref (a.proof_state,a.proof_obsolete) in let previous_res = ref (a.proof_state,a.proof_obsolete) in
let callback a ap timelimit previous state = let callback a ap limits previous state =
begin match state with begin match state with
| Starting -> previous_res := (a.proof_state,a.proof_obsolete) | Starting -> previous_res := (a.proof_state,a.proof_obsolete)
| MissingFile _ -> | MissingFile _ ->
...@@ -516,7 +518,7 @@ let run_external_proof_v2 eS eT a callback = ...@@ -516,7 +518,7 @@ let run_external_proof_v2 eS eT a callback =
end end
| _ -> () | _ -> ()
end; end;
callback a ap timelimit previous state callback a ap limits previous state
in in
run_external_proof_v3 eS eT a callback run_external_proof_v3 eS eT a callback
...@@ -681,29 +683,29 @@ type report = ...@@ -681,29 +683,29 @@ type report =
| Edited_file_absent of string | Edited_file_absent of string
| No_former_result of Call_provers.prover_result | No_former_result of Call_provers.prover_result
let push_report report (g,p,t,r) = let push_report report (g,p,limits,r) =
(g.goal_name,p,t,r)::report (g.goal_name,p,limits,r)::report
let check_external_proof eS eT todo a = let check_external_proof eS eT todo a =
let callback a ap tl old s = let callback a ap limits old s =
let g = a.proof_parent in let g = a.proof_parent in
match s with match s with
| Starting -> | Starting ->
Todo.start todo Todo.start todo
| MissingFile f -> | MissingFile f ->
Todo._done todo (g, ap, tl, Edited_file_absent f) Todo._done todo (g, ap, limits, Edited_file_absent f)
| MissingProver -> | MissingProver ->
Todo._done todo (g, ap, tl, Prover_not_installed) Todo._done todo (g, ap, limits, Prover_not_installed)
| StatusChange (Scheduled | Running) -> () | StatusChange (Scheduled | Running) -> ()
| StatusChange (Interrupted | Unedited | JustEdited) -> assert false | StatusChange (Interrupted | Unedited | JustEdited) -> assert false
| StatusChange (InternalFailure e) -> | StatusChange (InternalFailure e) ->
Todo._done todo (g, ap, tl, CallFailed e) Todo._done todo (g, ap, limits, CallFailed e)
| StatusChange (Done res) -> | StatusChange (Done res) ->
let r = let r =
match old with match old with
| None -> No_former_result res | None -> No_former_result res
| Some old -> Result (res, old) in | Some old -> Result (res, old) in
Todo._done todo (g, ap, tl, r) in Todo._done todo (g, ap, limits, r) in
run_external_proof_v2 eS eT a callback run_external_proof_v2 eS eT a callback
let rec goal_iter_proof_attempt_with_release ~release f g = let rec goal_iter_proof_attempt_with_release ~release f g =
...@@ -159,10 +159,10 @@ module Make(O: OBSERVER) : sig ...@@ -159,10 +159,10 @@ module Make(O: OBSERVER) : sig
val run_external_proof_v3 : val run_external_proof_v3 :
O.key Session.env_session -> t -> O.key Session.proof_attempt -> O.key Session.env_session -> t -> O.key Session.proof_attempt ->
(O.key Session.proof_attempt -> Whyconf.prover -> (O.key Session.proof_attempt -> Whyconf.prover ->
int -> Call_provers.prover_result option -> run_external_status -> unit) -> int * int * int -> Call_provers.prover_result option -> run_external_status -> unit) ->
unit unit
(** [run_external_proof_v3 env_session sched pa callback] the (** [run_external_proof_v3 env_session sched pa callback] the
callback is applied with [callback pa p timelimit old_result callback is applied with [callback pa p limits old_result
status]. run_external_proof_v3 don't change the existing proof status]. run_external_proof_v3 don't change the existing proof
attempt just can add new by O.uninstalled_prover. Be aware since attempt just can add new by O.uninstalled_prover. Be aware since
the session is not modified there is no test to see if the the session is not modified there is no test to see if the
...@@ -255,24 +255,24 @@ module Make(O: OBSERVER) : sig ...@@ -255,24 +255,24 @@ module Make(O: OBSERVER) : sig
O.key env_session -> t -> O.key env_session -> t ->
obsolete_only:bool -> obsolete_only:bool ->
context_unproved_goals_only:bool -> O.key any -> unit context_unproved_goals_only:bool -> O.key any -> unit
(** [replay es sched ~obsolete_only ~context_unproved_goals_only a] (** [replay es sched ~obsolete_only ~context_unproved_goals_only
reruns proofs under [a] a] reruns proofs under [a] if [obsolete_only] is set then does
if [obsolete_only] is set then does not rerun non-obsolete proofs not rerun non-obsolete proofs if [context_unproved_goals_only]
if [context_unproved_goals_only] is set then don't rerun proofs is set then only rerun proofs whose previous answer was
already 'valid' (FIXME: its the opposite, no?) 'valid' *)
val check_all: val check_all:
?release:bool -> (** Can all the goals be released at the end? def: false *) ?release:bool -> (** Can all the goals be released at the end? def: false *)
?filter:(O.key proof_attempt -> bool) -> ?filter:(O.key proof_attempt -> bool) ->
callback:((Ident.ident * Whyconf.prover * int * report) list -> unit) -> callback:((Ident.ident * Whyconf.prover * (int * int * int) * report) list -> unit) ->
unit unit
(** [check_all session callback] reruns all the proofs of the (** [check_all session callback] reruns all the proofs of the
session, and reports for all proofs the current result and the session, and reports for all proofs the current result and the
new one (does not change the session state) When finished, new one (does not change the session state). When finished,
calls the callback with the reports which are 4-uples (goal calls the callback with the reports which are 4-uples [(goal
name, prover, timelimit, report) *) name, prover, limits, report)] where [limits] is a triple
[(timelimit, memlimit, stepslimit)] *)
val play_all : val play_all :
O.key env_session -> t -> callback:(unit-> unit) -> O.key env_session -> t -> callback:(unit-> unit) ->
...@@ -242,14 +242,14 @@ let print_statistics files = ...@@ -242,14 +242,14 @@ let print_statistics files =
List.iter print_file (List.rev files) List.iter print_file (List.rev files)
let print_report (g,p,t,r) = let print_report (g,p,(t,m,s),r) =
printf " goal '%s', prover '%a': " g.Ident.id_string Whyconf.print_prover p; printf " goal '%s', prover '%a': " g.Ident.id_string Whyconf.print_prover p;
match r with match r with
| M.Result(new_res,old_res) -> | M.Result(new_res,old_res) ->
(* begin match !opt_smoke with *) (* begin match !opt_smoke with *)
(* | Session.SD_None -> *) (* | Session.SD_None -> *)
printf "%a instead of %a (timelimit=%d)@." printf "%a instead of %a (timelimit=%d, memlimit=%d, stepslimit=%d)@."
print_result new_res print_result old_res t print_result new_res print_result old_res t m s
(* | _ -> *) (* | _ -> *)
(* printf "Smoke detected!!!@." *) (* printf "Smoke detected!!!@." *)
(* end *) (* end *)
