Commit 4e6e1cd2 authored by Andrei Paskevich's avatar Andrei Paskevich
regenerate .merlin on compilation
parent c0ef91ca
......@@ -1820,7 +1820,7 @@ doc/version.tex: doc/version.tex.in config.status
config.status: configure
./config.status --recheck
opt byte: lib/why3/META
opt byte: lib/why3/META .merlin
lib/why3/META: lib/why3/META.in config.status
./config.status chmod --file $@
