Commit 4d13ffc8 authored by MARCHE Claude's avatar MARCHE Claude
Merge branch 'markdown' into 'master'
Convert some text files to markdown
See merge request !1
parents 1055fdb8 a2654c57
Installation instructions
Installation instructions =========================
Installation from a source distribution (tarball) Installation from a source distribution (tarball)
...@@ -7,14 +7,14 @@ Installation from a source distribution (tarball) ...@@ -7,14 +7,14 @@ Installation from a source distribution (tarball)
After unpacking, installation is done by After unpacking, installation is done by
./configure ./configure
make make
make install (as root) make install (as root)
To install also the Ocaml library do To install also the Ocaml library, do
make byte make byte
make install-lib (as root) make install-lib (as root)
Installation from the git repository Installation from the git repository
...@@ -22,15 +22,16 @@ Installation from the git repository ...@@ -22,15 +22,16 @@ Installation from the git repository
First run First run
autoconf autoconf
automake --add-missing automake --add-missing
to build the ./configure file and install the helper scripts, then follow to build the `./configure` file and install the helper scripts, then follow
instructions from the section above. the instructions from the section above.
Detailed instructions Detailed instructions
For detailed instructions and required dependencies, please see For detailed instructions and required dependencies, please see
the manual (doc/manual.pdf), Chapter 5 "Compilation, Installation". the manual [doc/manual.pdf](http://why3.lri.fr/manual.pdf), Chapter 5
[Compilation, Installation](http://why3.lri.fr/doc/install.html).
WHY 3
Why3 is a platform for deductive program verification. It provides Why3 is a platform for deductive program verification. It provides
a rich language for specification and programming, called WhyML, and a rich language for specification and programming, called WhyML, and
...@@ -11,42 +13,43 @@ automated extraction mechanism. WhyML is also used as an intermediate ...@@ -11,42 +13,43 @@ automated extraction mechanism. WhyML is also used as an intermediate
language for the verification of C, Java, or Ada programs. language for the verification of C, Java, or Ada programs.
PROJECT HOME PROJECT HOME
http://why3.lri.fr http://why3.lri.fr/
https://gforge.inria.fr/projects/why3 https://gitlab.inria.fr/why3/why3
DOCUMENTATION DOCUMENTATION
The documentation (a tutorial and a reference manual) is in The documentation (a tutorial and a reference manual) is in the file
the file doc/manual.pdf. [doc/manual.pdf](http://why3.lri.fr/manual.pdf) or online at
http://why3.lri.fr/doc/.
Various examples can be found in the subdirectories theories/ Various examples can be found in the subdirectories [theories/](theories)
and examples/. and [examples/](examples).
Mailing list (Why3 Club): Mailing list (Why3 Club):
http://lists.gforge.inria.fr/mailman/listinfo/why3-club http://lists.gforge.inria.fr/mailman/listinfo/why3-club
Bug Tracking System: Bug Tracking System:
https://gforge.inria.fr/tracker/?atid=10293&group_id=2990&func=browse https://gitlab.inria.fr/why3/why3/issues
COPYRIGHT COPYRIGHT
This program is distributed under the GNU LGPL 2.1. See the enclosed This program is distributed under the GNU LGPL 2.1. See the enclosed
file LICENSE. file [LICENSE](LICENSE).
The files src/util/extmap.ml{i} are derived from the sources of The files [src/util/extmap.ml{i}](src/util/extmap.mli) are derived from the
OCaml 3.12 standard library, and are distributed under the GNU sources of OCaml 3.12 standard library, and are distributed under the GNU
LGPL version 2 (see file OCAML-LICENSE). LGPL version 2 (see file [OCAML-LICENSE](OCAML-LICENSE)).
Icon sets for the graphical interface of Why3 are subject to specific Icon sets for the graphical interface of Why3 are subject to specific
licenses, some of them may forbid commercial usage. These specific licenses, some of them may forbid commercial usage. These specific
licenses are detailed in files share/images/*/*.txt licenses are detailed in files [share/images/\*/\*.txt](share/images).
INSTALLATION INSTALLATION
See the file INSTALL. See the file [INSTALL.md](INSTALL.md).
