Commit 4d13ffc8 authored by MARCHE Claude's avatar MARCHE Claude
Merge branch 'markdown' into 'master'
Convert some text files to markdown
See merge request !1
parents 1055fdb8 a2654c57
Installation instructions
Installation from a source distribution (tarball)
......@@ -7,14 +7,14 @@ Installation from a source distribution (tarball)
After unpacking, installation is done by
./configure
make
make install (as root)
./configure
make
To install also the Ocaml library do
To install also the Ocaml library, do
make byte
make install-lib (as root)
make byte
Installation from the git repository
......@@ -22,15 +22,16 @@ Installation from the git repository
First run
autoconf
automake --add-missing
autoconf
to build the ./configure file and install the helper scripts, then follow
instructions from the section above.
to build the `./configure` file and install the helper scripts, then follow
the instructions from the section above.
Detailed instructions
For detailed instructions and required dependencies, please see
the manual (doc/manual.pdf), Chapter 5 "Compilation, Installation".
the manual [doc/manual.pdf](http://why3.lri.fr/manual.pdf), Chapter 5
[Compilation, Installation](http://why3.lri.fr/doc/install.html).
WHY 3
Why3 is a platform for deductive program verification. It provides
a rich language for specification and programming, called WhyML, and
......@@ -11,42 +13,43 @@ automated extraction mechanism. WhyML is also used as an intermediate
language for the verification of C, Java, or Ada programs.
PROJECT HOME
http://why3.lri.fr
http://why3.lri.fr/
https://gforge.inria.fr/projects/why3
https://gitlab.inria.fr/why3/why3
DOCUMENTATION
The documentation (a tutorial and a reference manual) is in
the file doc/manual.pdf.
The documentation (a tutorial and a reference manual) is in the file
[doc/manual.pdf](http://why3.lri.fr/manual.pdf) or online at
http://why3.lri.fr/doc/.
Various examples can be found in the subdirectories theories/
and examples/.
Various examples can be found in the subdirectories [theories/](theories)
and [examples/](examples).
Mailing list (Why3 Club):
http://lists.gforge.inria.fr/mailman/listinfo/why3-club
Bug Tracking System:
https://gforge.inria.fr/tracker/?atid=10293&group_id=2990&func=browse
https://gitlab.inria.fr/why3/why3/issues
COPYRIGHT
This program is distributed under the GNU LGPL 2.1. See the enclosed
file LICENSE.
file [LICENSE](LICENSE).
The files src/util/extmap.ml{i} are derived from the sources of
OCaml 3.12 standard library, and are distributed under the GNU
LGPL version 2 (see file OCAML-LICENSE).
The files [src/util/extmap.ml{i}](src/util/extmap.mli) are derived from the
sources of OCaml 3.12 standard library, and are distributed under the GNU
LGPL version 2 (see file [OCAML-LICENSE](OCAML-LICENSE)).
Icon sets for the graphical interface of Why3 are subject to specific
licenses, some of them may forbid commercial usage. These specific
licenses are detailed in files share/images/*/*.txt
licenses are detailed in files [share/images/\*/\*.txt](share/images).
INSTALLATION
See the file INSTALL.
See the file [INSTALL.md](INSTALL.md).
