Commit 4ce79abb authored by Francois Bobot's avatar Francois Bobot
vacid_sort : nouvelle syntax
parent 1cedcd8c
...@@ -3,21 +3,21 @@ theory Sorted ...@@ -3,21 +3,21 @@ theory Sorted
use real.Real use real.Real
use import array.Array use import array.Array
type array = (int, real) t type array = t int real
type multi = (real, int) t type multi = t real int
logic n : int = 4 logic n : int = 4
logic sorted(m : array) = logic sorted(m : array) =
forall x,y:int. x<=y -> Real.(<=)(select(m, x),select(m, y)) forall x y:int. x<=y -> Real.(<=)(select m x) (select m y)
logic count(m : array, i : int, j : int, v : real) : int = logic count(m : array) (i j : int) (v : real) : int =
if i = j then 0 else if i = j then 0 else
let c = count(m,i+1,j,v) in let c = count m (i+1) j v in
(if select (m,i) = v then c + 1 else c) (if select m i = v then c + 1 else c)
logic model(m1 : array, m2 : multi) = logic model(m1 : array) (m2 : multi) =
forall v:real. count(m1,1,n+1,v) = select(m2,v) forall v:real. count m1 1 (n+1) v = select m2 v
logic model_aux(m1 : array, i : int) : multi logic model_aux(m1 : array, i : int) : multi
...@@ -41,32 +41,32 @@ theory Sorted ...@@ -41,32 +41,32 @@ theory Sorted
goal G : goal G :
forall m1 : array. forall m1 : array.
select(m1,1) = 42. -> select m1 1 = 42. ->
select(m1,2) = 13. -> select m1 2 = 13. ->
select(m1,3) = 42. -> select m1 3 = 42. ->
select(m1,4) = 45. -> select m1 4 = 45. ->
forall m2 : array. forall m2 : array.
forall multi : multi. forall multi : multi.
model(m1,multi) -> model m1 multi ->
model(m2,multi) -> model m2 multi ->
sorted(m2) -> sorted m2 ->
select(m2,1) = 13. and select m2 1 = 13. and
select(m2,2) = 42. and select m2 2 = 42. and
select(m2,3) = 42. and select m2 3 = 42. and
select(m2,4) = 45. select m2 4 = 45.
(* goal G_false : (* goal G_false :
select(m2,1) = 42. and select m2 1 = 42. and
select(m2,2) = 13. and select m2 2 = 13. and
select(m2,3) = 42. select m2 3 = 42.
end end
\ No newline at end of file
