GitLab
What's new
7
Support
Community forum
Keyboard shortcuts
Why3
why3
4bfbb32a
4bfbb32a
Raphael Rieu-Helft
C extraction: use the syntax literal driver entries for number constants
5e540a79
2
2 changed files
30 additions
29 deletions
+30
-29
drivers/c.drv
drivers/c.drv
+6
-6
src/mlw/cprinter.ml
src/mlw/cprinter.ml
+24
-23
drivers/c.drv
4bfbb32a
@@ -23,7 +23,7 @@ end
module mach.int.Int32
syntax type int32 "int32_t"
syntax literal int32 "%
d
c
syntax val (+) "%1 + %2" prec 4 4 3
syntax val (-) "%1 - %2" prec 4 4 3
@@ -49,7 +49,7 @@ end
module mach.int.UInt32
syntax literal uint32 "
0x%8x
U"
%c
U"
@@ -181,7 +181,7 @@ struct __lsld32_result
struct __lsld32_result lsld32(uint32_t x, uint32_t cnt);
0x%8x
U"
%c
U"
@@ -223,7 +223,7 @@ end
module mach.int.Int64
syntax type int64 "int64_t"
syntax literal int64 "
%dL
INT64_C(%c)
@@ -250,7 +250,7 @@ end
module mach.int.UInt64
syntax literal uint64 "
0x%16xUL
UINT64_C(%c)
@@ -505,7 +505,7 @@ static struct __lsld64_result lsld64(uint64_t x, uint64_t cnt)
return result;
0x%16xUL
UINT64_C(%c)
syntax val uint64_max "0xffffffffffffffffUL" prec 0
src/mlw/cprinter.ml
4bfbb32a
@@ -925,29 +925,30 @@ module MLToC = struct
expr_or_return
env
e
Mltree
Econst
ic
let
open
Number
in
let
print
fmt
ic
let
n
ic
il_int
in
let
n
if
BigInt
lt
n
BigInt
zero
then
BigInt
to_string
n
if
BigInt
lt
n
BigInt
zero
then
Format
fprintf
fmt
"-%a"
print_in_base
10
None
BigInt
abs
n
else
match
ic
il_kind
ILitHex
Format
asprintf
"0x%a"
print_in_base
16
None
n
ILitOct
Format
asprintf
"0%a"
print_in_base
8
None
n
_
BigInt
to_string
n
in
let
suf
match
e
e_ity
ILitHex
Format
fprintf
fmt
"0x%a"
print_in_base
16
None
n
ILitOct
Format
fprintf
fmt
"0%a"
print_in_base
8
None
n
_
(* default to base 10 *)
Format
fprintf
fmt
"%a"
print_in_base
10
None
n
in
let
s
match
e
e_ity
I
i
begin
match
ty_of_ity
i
ty_node
Tyapp
ts_def
Range
ir_lower
l
ir_upper
h
,_
let
open
BigInt
in
let
unsigned
eq
l
zero
in
if
le
min32
l
le
h
max32
then
else
if
unsigned
le
h
maxu32
then
"u"
else
if
le
min64
l
le
h
max64
then
"l"
else
if
unsigned
le
h
maxu64
then
"ul"
else
raise
Unsupported
"unknown number format"
_
raise
Unsupported
"non-range integer constant"
let
ts
match
ty_of_ity
i
ty_node
Tyapp
ts
ts
_
assert
false
in
begin
match
query_syntax
info
literal
ts
ts_name
Some
st
Format
asprintf
"%a"
syntax_range_literal
cb
Some
print
st
ic
_
let
s
ts
ts_name
id_string
in
raise
Unsupported
"unspecified number format for type "
s
_
assert
false
in
let
e
C
Econst
Cint
n
suf
in
let
e
C
Econst
Cint
s
in
expr_or_return
env
e
Eapp
rs
el
when
is_struct_constructor
info
rs
