Commit 4b79dcf1 authored by Andrei Paskevich's avatar Andrei Paskevich
encoding_twin: make the order of added declarations more deterministic
parent f12b7a9f
...@@ -46,14 +46,22 @@ let make_pont = Wty.memoize 3 (fun ty -> ...@@ -46,14 +46,22 @@ let make_pont = Wty.memoize 3 (fun ty ->
create_prop_decl Paxiom pr ax in create_prop_decl Paxiom pr ax in
t2tb, tb2t, [t2tb_def; tb2t_def; bridge_l; bridge_r]) t2tb, tb2t, [t2tb_def; tb2t_def; bridge_l; bridge_r])
let seen = Hty.create 7 let seen_h = Hty.create 7
let seen_q = Queue.create ()
let check_in ty =
if not (Hty.mem seen_h ty) then begin
Hty.add seen_h ty ();
Queue.add ty seen_q
let add_decls tenv decls = let add_decls tenv decls =
let add ty () decls = let add decls ty =
let _,_,defs = Mty.find ty tenv in let _,_,defs = Mty.find ty tenv in
List.append defs decls in List.append defs decls in
let decls = Hty.fold add seen decls in let decls = Queue.fold add decls seen_q in
Hty.clear seen; Queue.clear seen_q;
Hty.clear seen_h;
decls decls
let conv_arg tenv t aty = let conv_arg tenv t aty =
...@@ -61,7 +69,7 @@ let conv_arg tenv t aty = ...@@ -61,7 +69,7 @@ let conv_arg tenv t aty =
if ty_equal tty aty then t else if ty_equal tty aty then t else
try try
let t2tb,tb2t,_ = Mty.find tty tenv in let t2tb,tb2t,_ = Mty.find tty tenv in
Hty.replace seen tty (); check_in tty;
match t.t_node with match t.t_node with
| Tapp (fs,[t]) when ls_equal fs tb2t -> t | Tapp (fs,[t]) when ls_equal fs tb2t -> t
| _ -> fs_app t2tb [t] tty | _ -> fs_app t2tb [t] tty
...@@ -73,7 +81,7 @@ let conv_app tenv fs tl tty = ...@@ -73,7 +81,7 @@ let conv_app tenv fs tl tty =
if ty_equal tty vty then t else if ty_equal tty vty then t else
try try
let _,tb2t,_ = Mty.find tty tenv in let _,tb2t,_ = Mty.find tty tenv in
fs_app tb2t [t] tty fs_app tb2t [t] tty
with Not_found -> t with Not_found -> t
