Commit 4b235d82 authored by Andrei Paskevich's avatar Andrei Paskevich
whyml: some notes in the comments
parent f3511aea
......@@ -23,6 +23,56 @@ open Ty
open Term
open Mlw_ty
1. A "proper type" of a vty [v] is [v] with all effects and specs
(pre/post/xpost) removed. Basically, it is formed from the ity's
of pvsymbols in the arguments and the result of [v].
2. Given a vty [v], [vty_freevars v] and [vty_topregions v] return
the sets of type variables and regions, respectively, that occur
in the proper type of [v]. We will call them "proper" type variables
and regions of [v].
3. The specs (pre/post/xpost) and the effects in a vty [v] may contain
type variables and regions that do not occur in the proper type of [v].
We will call them "extra" type variables and regions of [v].
4. A substitution given to [vty_full_inst] MUST instantiate every extra
type variable and region to itself. We do not verify this invariant,
but it is going to be ensured by the following.
5. An expression [e] provides the maps [e.e_tvs] and [e.e_regs] from
idents (vsymbols, pvsymbols, psymbols, ppsymbols) occurring in [e]
to sets of type variables and regions, respectively, that are
"related" to these idents. For example, every type variable and
region that occurs in a pv_ity of a pvsymbol [x] is related to [x].
For psymbols and ppsymbols, the meaning of "related" is explained below.
6. It is possible that [e.e_vty] contains a proper type variable or
a proper region that does not appear in the range of [e.e_tvs] or
[e.e_regs]. However, every extra type variable and region of
[e.e_vty] MUST occur in the range of [e.e_tvs] and [e.e_regs].
7. A psymbol (monomorphic program symbol) [p] provides the sets [p.p_tvs]
and [p.p_regs] of its related type variables and regions, respectively,
that cover both proper and extra type variables and regions of [p.p_vty].
One way to ensure this is to put into [p.p_tvs] the union of the proper
type variables of [p.p_vty] and all the type variables in the range of
[e.e_tvs], where [e] is the defining expression of [p] (similarly for
regions). However, this will relate to [p] more that just proper and
extra variables of [p.p_vty]. It is unclear whether this is a problem,
but my guess is it's not.
8. A ppsymbol
type variant = {
v_term : term; (* : tau *)
v_rel : lsymbol option; (* tau tau : prop *)
