GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
49d028ba
49d028ba
François Bobot
why3html : add stdout as possible output and the context option
for simple integration of the result into existing page.
6a6b268f
41 additions
24 deletions
+41
-24
src/ide/html_session.ml
+41
-24
49d028ba
@@ -17,6 +17,7 @@
@@ -17,6 +17,7 @@
open
Format
open
Why3
open
Why3
let
includes
ref
let
includes
ref
@@ -25,33 +26,38 @@ let opt_version = ref false
let
output_dir
ref
let
output_dir
ref
let
allow_obsolete
ref
true
let
allow_obsolete
ref
true
let
opt_config
ref
None
let
opt_config
ref
None
let
opt_context
ref
false
let
spec
Arg
align
let
spec
Arg
align
"-I"
"-I"
Arg
String
fun
s
includes
s
includes
Arg
String
fun
s
includes
s
includes
"<s>
a
dd s to loadpath"
"<s>
A
dd s to loadpath"
"-v"
"-v"
Arg
Set
opt_version
Arg
Set
opt_version
p
rint version information"
P
"-o"
"-o"
Arg
Set_string
output_dir
Arg
Set_string
output_dir
the directory to output the files
The directory to output the files ('-' for stdout)
"--strict"
"--strict"
Arg
Clear
allow_obsolete
Arg
Clear
allow_obsolete
f
orbid obsolete session"
F
"-C"
Arg
String
fun
s
opt_config
Some
s
"-C"
Arg
String
fun
s
opt_config
Some
s
"<file> Read configuration from <file>"
"--config"
Arg
String
fun
s
opt_config
Some
s
"--config"
Arg
String
fun
s
opt_config
Some
s
" same as -C"
" Same as -C"
"--context"
Arg
Set
opt_context
" Add context around the generated code in order to allow direct \
visualisation (header, css, ...). It also add in the directory \
all the needed external file. It can't be set with stdout output"
let
version_msg
Format
sprintf
let
version_msg
sprintf
"Why3 html session output, version %s (build date: %s)"
Config
version
Config
builddate
Config
version
Config
builddate
let
usage_str
Format
sprintf
let
usage_str
sprintf
"Usage: %s [options] [<file.why>|<project directory>] ... "
Filename
basename
Sys
argv
Filename
basename
Sys
argv
@@ -61,17 +67,20 @@ let () = Arg.parse spec set_file usage_str
let
let
if
opt_version
then
begin
if
opt_version
then
begin
Format
printf
"%s@."
version_msg
printf
"%s@."
version_msg
exit
exit
let
output_dir
let
output_dir
if
output_dir
then
begin
match
output_dir
Format
printf
"output_dir must be set@."
printf
exit
"Error: output_dir must be set@."
exit
else
output_dir
when
opt_context
printf
"Error: context and stdout output can't be set at the same time@."
exit
_
output_dir
let
allow_obsolete
allow_obsolete
let
allow_obsolete
allow_obsolete
let
includes
rev
includes
let
includes
rev
includes
@@ -80,7 +89,6 @@ open Session_ro
let
env
read_config
includes
opt_config
let
env
read_config
includes
opt_config
open
Format
open
Util
open
Util
let
print_prover
fmt
function
let
print_prover
fmt
function
@@ -127,14 +135,11 @@ let print_session fmt s =
fprintf
fmt
"<p><ul>%a</ul></p>"
fprintf
fmt
Pp
print_list
Pp
newline
print_file
s
Pp
print_list
Pp
newline
print_file
s
let
run_file
f
type
context
let
session_path
get_project_dir
f
in
formatter
Session_ro
session
unit
let
session
read_project_dir
allow_obsolete
env
session_path
in
Session_ro
session
unit
formatter
unit
format
let
basename
Filename
basename
session_path
in
let
cout
open_out
Filename
concat
output_dir
basename
".html"
in
let
simple_context
context
"<!DOCTYPE html
let
fmt
formatter_of_out_channel
cout
in
fprintf
fmt
"<!DOCTYPE html
PUBLIC
-//W3C//DTD XHTML 1.0 Strict//EN
PUBLIC
http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd
<html xmlns=
http://www.w3.org/1999/xhtml
<html xmlns=
@@ -146,7 +151,19 @@ PUBLIC \"-//W3C//DTD XHTML 1.0 Strict//EN\"
</body>
</body>
</html>
</html>
print_session
session
let
run_file
f
let
session_path
get_project_dir
f
in
let
session
read_project_dir
allow_obsolete
env
session_path
in
let
cout
if
output_dir
then
stdout
else
let
basename
Filename
basename
session_path
in
open_out
Filename
concat
output_dir
basename
".html"
in
let
fmt
cout
in
if
opt_context
then
fprintf
fmt
simple_context
print_session
session
else
print_session
fmt
session
pp_print_flush
fmt
if
output_dir
then
close_out
cout
let
Queue
iter
run_file
files
let
Queue
iter
run_file
files
