Commit 4922dbf0 authored by François Bobot's avatar François Bobot
remove polymorphism in bench/prepare db incorporation
parent e16b146a
...@@ -485,7 +485,7 @@ BENCH_FILES = bench benchrc whybench ...@@ -485,7 +485,7 @@ BENCH_FILES = bench benchrc whybench
BENCHMODULES := $(addprefix src/bench/, $(BENCH_FILES)) BENCHMODULES := $(addprefix src/bench/, $(BENCH_FILES))
BENCHMODULES := src/ide/worker $(BENCHMODULES) BENCHMODULES := src/ide/worker src/ide/db $(BENCHMODULES)
BENCHML = $(addsuffix .ml, $(BENCHMODULES)) BENCHML = $(addsuffix .ml, $(BENCHMODULES))
BENCHMLI = $(addsuffix .mli, $(BENCHMODULES)) BENCHMLI = $(addsuffix .mli, $(BENCHMODULES))
...@@ -499,8 +499,8 @@ $(BENCHCMO) $(BENCHCMX): INCLUDES += -I src/ide -I src/bench -I @SQLITE3LIB@ ...@@ -499,8 +499,8 @@ $(BENCHCMO) $(BENCHCMX): INCLUDES += -I src/ide -I src/bench -I @SQLITE3LIB@
byte: bin/why3bench.byte byte: bin/why3bench.byte
opt: bin/why3bench.opt opt: bin/why3bench.opt
bin/why3bench.opt bin/why3bench.byte: INCLUDES += -thread -I +threads bin/why3bench.opt bin/why3bench.byte: INCLUDES += -thread -I +threads -I +sqlite3
bin/why3bench.opt bin/why3bench.byte: EXTLIBS += threads bin/why3bench.opt bin/why3bench.byte: EXTLIBS += threads sqlite3
bin/why3bench.opt: src/why.cmxa $(PGMCMX) $(BENCHCMX) bin/why3bench.opt: src/why.cmxa $(PGMCMX) $(BENCHCMX)
$(if $(QUIET), @echo 'Linking $@' &&) \ $(if $(QUIET), @echo 'Linking $@' &&) \
...@@ -27,20 +27,36 @@ open Driver ...@@ -27,20 +27,36 @@ open Driver
open Call_provers open Call_provers
open Scheduler open Scheduler
type 'a tool = { type tool_id = {
tval : 'a; tool_name : string;
ttrans : task trans; prover_name : string;
tool_db : Db.prover_id option;
(* tool_name, prover_name *)
type prob_id = {
prob_name : string;
prob_file : string;
prob_theory : string;
prob_db : Db.goal option;
(* prob_name, file_name, theory name *)
type tool = {
tval : tool_id;
ttrans : (task trans * (Db.transf_id option)) list;
tdriver : driver; tdriver : driver;
tcommand : string; tcommand : string;
tenv : env; tenv : env;
tuse : task; tuse : task;
tuse_trans : Db.transf_id option;
ttime : int; ttime : int;
tmem : int; tmem : int;
type 'a prob = { type prob = {
ptask : env -> task -> ('a * task) list; (** needed for tenv *) ptask : env -> task -> (prob_id * task) list; (** needed for tenv *)
ptrans : env -> task list trans; ptrans : env -> (task list trans * (Db.transf_id option)) list;
...@@ -48,20 +64,19 @@ type why_result = ...@@ -48,20 +64,19 @@ type why_result =
| InternalFailure of exn | InternalFailure of exn
| Done of prover_result | Done of prover_result
let print_why_result fmt = function let print_why_result fmt = function
| InternalFailure exn -> | InternalFailure exn ->
Format.fprintf fmt "InternalFailure %a" Exn_printer.exn_printer exn Format.fprintf fmt "InternalFailure %a" Exn_printer.exn_printer exn
| Done pr -> Call_provers.print_prover_result fmt pr | Done pr -> Call_provers.print_prover_result fmt pr
type result = {tool : tool_id;
prob : prob_id;
task : Decl.prsymbol;
idtask : int;
result : why_result}
type ('a,'b) result = {tool : 'a; type callback = tool_id -> prob_id ->
prob : 'b; task -> int -> why_result -> unit
idtask : int;
type ('a,'b) callback = 'a -> 'b -> task -> int -> why_result -> unit
let debug_call = Debug.register_flag "call" let debug_call = Debug.register_flag "call"
let debug = Debug.register_flag "bench_core" let debug = Debug.register_flag "bench_core"
...@@ -118,6 +133,23 @@ let new_external_proof = ...@@ -118,6 +133,23 @@ let new_external_proof =
Mutex.unlock queue_lock; Mutex.unlock queue_lock;
done done
let apply_trans (task,_db_goal) (trans,_db_trans) =
let task = Trans.apply trans task in
((task:task),None)
let apply_transl (task,_db_goal) (trans,_db_trans) =
let tasks = Trans.apply trans task in
List.map (fun task -> (task:task),None) tasks
let rec apply_transll trl acc (task,db_goal) =
match trl with
| [] -> (task,db_goal)::acc
| tr::trl ->
let tl = apply_transl (task,db_goal) tr in
List.fold_left (apply_transll trl) acc tl
let call callback tool prob = let call callback tool prob =
(** Prove goal *) (** Prove goal *)
let call pval i task = let call pval i task =
...@@ -133,11 +165,12 @@ let call callback tool prob = ...@@ -133,11 +165,12 @@ let call callback tool prob =
in in
(** Apply trans *) (** Apply trans *)
let iter_task (pval,task) = let iter_task (pval,task) =
let trans = Trans.compose_l (prob.ptrans tool.tenv) let translist = prob.ptrans tool.tenv in
(Trans.singleton tool.ttrans) in let tasks = apply_transll translist [] (task,pval.prob_db) in
let tl = Trans.apply trans task in let tasks = List.map
let iter i task = call pval i task; succ i in (fun task -> List.fold_left apply_trans task tool.ttrans) tasks in
ignore (List.fold_left iter 0 (List.rev tl)) in let iter i (task,_db_goal) = call pval i task; succ i in
ignore (List.fold_left iter 0 (List.rev tasks)) in
(** Split *) (** Split *)
let ths = prob.ptask tool.tenv tool.tuse in let ths = prob.ptask tool.tenv tool.tuse in
List.iter iter_task ths List.iter iter_task ths
...@@ -210,11 +243,11 @@ type output = ...@@ -210,11 +243,11 @@ type output =
(** In a file *) (** In a file *)
|Csv of string |Csv of string
type ('a,'b) bench = type bench =
bname : string; bname : string;
btools : 'a tool list; btools : tool list;
bprobs : 'b prob list; bprobs : prob list;
boutputs : output list; boutputs : output list;
...@@ -31,21 +31,37 @@ val maximum_running_proofs: int ref ...@@ -31,21 +31,37 @@ val maximum_running_proofs: int ref
(** bound on the number of prover processes running in parallel. (** bound on the number of prover processes running in parallel.
default is 2 *) default is 2 *)
type prob_id = {
prob_name : string;
prob_file : string;
type tool = {
tval : tool_id;
tenv : env; (** Allow to compare axiomatic easily *) tenv : env; (** Allow to compare axiomatic easily *)
ptask : env -> task -> ('a * task) list; (** needed for tenv and tuse *) ptask : env -> task -> (prob_id * task) list;
ptrans : env -> task list trans; (** perhaps should be merged in (** needed for tenv and tuse *)
ptask *) ptrans : env -> (task list trans * (Db.transf_id option)) list;
type why_result = type why_result =
...@@ -53,35 +69,35 @@ type why_result = ...@@ -53,35 +69,35 @@ type why_result =
val print_why_result : Format.formatter -> why_result -> unit val print_why_result : Format.formatter -> why_result -> unit
prob : prob_id;
idtask : int;
idtask : int;
val all_list_tp : val all_list_tp :
?callback:('a,'b) callback -> ?callback:callback ->
'a tool list -> 'b prob list -> ('a,'b) result list tool list -> prob list -> result list
val all_list_pt : val all_list_pt :
val all_array : val all_array :
'a tool array -> 'b prob array -> ('a,'b) result list array array tool array -> prob array -> result list array array
val any : val any :
('a tool * 'b prob) list -> ('a,'b) result list (tool * prob) list -> result list
val all_list_tools : val all_list_tools :
'a tool list -> 'b prob list -> ('a * ('a,'b) result list) list tool list -> prob list -> (tool_id * result list) list
type output = type output =
...@@ -91,25 +107,25 @@ type output = ...@@ -91,25 +107,25 @@ type output =
val run_bench : val run_bench :
?callback:('a,'b) callback -> ('a,'b) bench -> ('a,'b) result list ?callback:callback -> bench -> result list
val run_benchs : val run_benchs :
?callback:('a,'b) callback -> ('a,'b) bench list -> ?callback:callback -> bench list ->
(('a,'b) bench * ('a,'b) result list) list (bench * result list) list
val run_benchs_tools : val run_benchs_tools :
(('a,'b) bench * ('a * ('a,'b) result list) list) list (bench * (tool_id * result list) list) list
type nb_avg = int * float type nb_avg = int * float
...@@ -125,25 +141,26 @@ type tool_res = ...@@ -125,25 +141,26 @@ type tool_res =
val print_tool_res : Format.formatter -> tool_res -> unit val print_tool_res : Format.formatter -> tool_res -> unit
val compute_average : ('a,'b) result list -> tool_res val compute_average : result list -> tool_res
val compute_timeline : val compute_timeline :
float -> float -> float -> ('a,'b) result list -> int list float -> float -> float -> result list -> int list
(** [compute_timeline start end step results] *)
val filter_timeline : ('a,'b) result list -> ('a,'b) result list val filter_timeline : result list -> result list
val max_time : ('a,'b) result list -> float val max_time : result list -> float
open Format open Format
val print_csv : val print_csv :
('b -> 'b -> int) -> (prob_id -> prob_id -> int) ->
(formatter -> 'a -> unit) -> (formatter -> tool_id -> unit) ->
(formatter -> 'b -> unit) -> (formatter -> prob_id -> unit) ->
formatter -> formatter ->
('a * ('a,'b) result list) list -> unit (tool_id * result list) list -> unit
val print_output : val print_output :
('a,'b) bench * ('a * ('a,'b) result list) list -> unit bench * (tool_id * result list) list -> unit
...@@ -27,9 +27,9 @@ open Theory ...@@ -27,9 +27,9 @@ open Theory
type id_tool = (string * string) type id_tool = (string * string)
type id_prob = (string * string * string) type id_prob = (string * string * string)
type benchrc = { tools : id_tool tool list Mstr.t; type benchrc = { tools : tool list Mstr.t;
probs : id_prob prob list Mstr.t; probs : prob list Mstr.t;
benchs : (id_tool,id_prob) bench Mstr.t benchs : bench Mstr.t
open Whyconf open Whyconf
...@@ -54,9 +54,9 @@ let read_tools absf wc map (name,section) = ...@@ -54,9 +54,9 @@ let read_tools absf wc map (name,section) =
let env = Lexer.create_env loadpath in let env = Lexer.create_env loadpath in
(* transformations *) (* transformations *)
let transforms = get_stringl ~default:[] section "transform" in let transforms = get_stringl ~default:[] section "transform" in
let lookup acc t = Trans.compose (Trans.lookup_transform t env) acc in let lookup acc t = (Trans.lookup_transform t env,None)::acc in
let transforms = List.fold_left lookup Trans.identity transforms let transforms = List.fold_left lookup [] transforms in
in let transforms = List.rev transforms in
(* use *) (* use *)
let use = get_stringl ~default:[] section "use" in let use = get_stringl ~default:[] section "use" in
let load_use task s = let load_use task s =
...@@ -84,12 +84,13 @@ let read_tools absf wc map (name,section) = ...@@ -84,12 +84,13 @@ let read_tools absf wc map (name,section) =
let load_driver (n,d,c) = n,Driver.load_driver env d,c in let load_driver (n,d,c) = n,Driver.load_driver env d,c in
let provers = List.map load_driver provers in let provers = List.map load_driver provers in
let create_tool (n,driver,command) = let create_tool (n,driver,command) =
{ tval = name,n ; { tval = {tool_name = name; prover_name = n;tool_db = None} ;
ttrans = transforms; ttrans = transforms;
tdriver = driver; tdriver = driver;
tcommand = command; tcommand = command;
tenv = env; tenv = env;
tuse = use; tuse = use;
tuse_trans = None;
ttime = timelimit; ttime = timelimit;
tmem = memlimit tmem = memlimit
} in } in
...@@ -99,12 +100,12 @@ let read_probs absf map (name,section) = ...@@ -99,12 +100,12 @@ let read_probs absf map (name,section) =
let gen_trans env = let gen_trans env =
let lookup acc t = Trans.compose_l let lookup acc t =
(try Trans.singleton (Trans.lookup_transform t env) with ((try Trans.singleton (Trans.lookup_transform t env) with
Trans.UnknownTrans _ -> Trans.lookup_transform_l t env) acc Trans.UnknownTrans _ -> Trans.lookup_transform_l t env),None)::acc
in in
let transforms = List.fold_left lookup Trans.identity_l transforms in let transforms = List.fold_left lookup [] transforms in
transforms List.rev transforms
in in
(* format *) (* format *)
let format = get_stringo section "format" in let format = get_stringo section "format" in
...@@ -117,7 +118,9 @@ let read_probs absf map (name,section) = ...@@ -117,7 +118,9 @@ let read_probs absf map (name,section) =
let m = Env.read_channel ?format:format env fname cin in let m = Env.read_channel ?format:format env fname cin in
close_in cin; close_in cin;
let ths = Mnm.bindings m in let ths = Mnm.bindings m in
List.rev_map (fun (n,th) -> ((name,fname,n),th)) ths let prob_id n = {prob_name = name;prob_file = fname; prob_theory = n;
prob_db = None} in
List.rev_map (fun (n,th) -> (prob_id n,th)) ths
in in
let map (name,th) = name,Task.split_theory th None task in let map (name,th) = name,Task.split_theory th None task in
let fold acc (n,l) = let fold acc (n,l) =
...@@ -44,15 +44,9 @@ open Why ...@@ -44,15 +44,9 @@ open Why
open Util open Util
type id_tool = (string * string) type benchrc = { tools : tool list Mstr.t;
(* tool_name, prover_name *) probs : prob list Mstr.t;
val read_file : Whyconf.config -> string -> benchrc val read_file : Whyconf.config -> string -> benchrc
...@@ -310,12 +310,13 @@ let () = ...@@ -310,12 +310,13 @@ let () =
let prover = try Mstr.find s (get_provers config) with let prover = try Mstr.find s (get_provers config) with
| Not_found -> eprintf "Prover %s not found.@." s; exit 1 | Not_found -> eprintf "Prover %s not found.@." s; exit 1
in in
{ B.tval = "cmdline",s; { B.tval = {B.tool_name = "cmdline"; prover_name = s; tool_db = None};
ttrans = Trans.identity; ttrans = [Trans.identity,None];
tdriver = load_driver env prover.driver; tdriver = load_driver env prover.driver;
tcommand = prover.command; tcommand = prover.command;
tuse = !opt_task; tuse = !opt_task;
tuse_trans = None;
ttime = of_option !opt_timelimit; ttime = of_option !opt_timelimit;
tmem = of_option !opt_memlimit; tmem = of_option !opt_memlimit;
} in } in
...@@ -324,11 +325,11 @@ let () = ...@@ -324,11 +325,11 @@ let () =
Debug.dprintf debug "Load transformations@."; Debug.dprintf debug "Load transformations@.";
let transl = let transl =
in in
List.fold_left lookup Trans.identity_l !opt_trans in List.rev (List.fold_left lookup [] !opt_trans) in
let fold_prob acc = function let fold_prob acc = function
| None, _ -> acc | None, _ -> acc
...@@ -343,7 +344,10 @@ let () = ...@@ -343,7 +344,10 @@ let () =
let th = Mnm.bindings m in let th = Mnm.bindings m in
List.rev_append (List.map (fun v -> (("cmdline","",n),v)) l) acc in let prob_id = {B.prob_name = "cmdline";prob_file = "";
prob_theory = n;
prob_db = None} in
List.rev_append (List.map (fun v -> (prob_id,v)) l) acc in
th |> List.map map |> List.fold_left fold [] in th |> List.map map |> List.fold_left fold [] in
{ B.ptask = gen; { B.ptask = gen;
ptrans = fun _ -> transl; ptrans = fun _ -> transl;
...@@ -375,7 +379,7 @@ let () = ...@@ -375,7 +379,7 @@ let () =
let nb_done = ref 0 in let nb_done = ref 0 in
let nb_valid = ref 0 in let nb_valid = ref 0 in
let nb_failure = ref 0 in let nb_failure = ref 0 in
let callback (_,tool) (_,file,prob) task i res = let callback tool_id prob_id task i res =
if not !opt_quiet then if not !opt_quiet then
begin begin match res with begin begin match res with
| B.Done {Call_provers.pr_answer = ans} -> incr nb_done; | B.Done {Call_provers.pr_answer = ans} -> incr nb_done;
...@@ -388,15 +392,18 @@ let () = ...@@ -388,15 +392,18 @@ let () =
!nb_done !nb_valid !nb_failure !nb_done !nb_valid !nb_failure
end; end;
Debug.dprintf debug "%s.%s %a %i with %s : %a@."
