GitLab
What's new
7
Support
Community forum
Keyboard shortcuts
Why3
why3
47a250ed
47a250ed
MARCHE Claude
Zarith support: fixed compilation of Why3 Coq tactic
f983f9eb
2
2 changed files
14 additions
9 deletions
+14
-9
Makefile.in
Makefile.in
+12
-9
configure.in
configure.in
+2
Makefile.in
47a250ed
@@ -77,7 +77,7 @@ endif
# external libraries common to all binaries
EXTOBJS
EXTLIBS
str unix @BIGINTLIB@ dynlink
EXTLIBS
EXTCMA
addsuffix
.cma,
$(EXTLIBS)
addsuffix
.cmo,
$(EXTOBJS)
EXTCMXA
addsuffix
.cmxa,
$(EXTLIBS)
addsuffix
.cmx,
$(EXTOBJS)
@@ -102,12 +102,13 @@ endif
# Why3 library
LIBGENERATED
src/util/config.ml src/util/rc.ml src/parser/lexer.ml
LIBGENERATED
src/util/config.ml src/util/bigInt.ml
src/parser/parser.mli src/parser/parser.ml
src/driver/driver_parser.mli src/driver/driver_parser.ml
src/driver/driver_lexer.ml src/session/xml.ml
LIB_UTIL
config util opt lists strings extmap extset exthtbl weakhtbl
LIB_UTIL
config
bigInt
hashcons stdlib exn_printer pp debug loc print_tree
cmdline warning sysutil rc plugin bigInt number pqueue
@@ -165,16 +166,18 @@ $(LIBDEP): $(LIBGENERATED)
ifeq
(@enable_zarith@,yes)
src/util/bigInt.ml
src/util/bigInt_ocamlnum.ml
src/util/bigInt_zarith.ml
src/util/bigInt.ml
config.status
cp
src/util/bigInt_zarith.ml src/util/bigInt.ml
else
src/util/bigInt.ml
src/util/bigInt.ml
config.status
cp
src/util/bigInt_ocamlnum.ml src/util/bigInt.ml
endif
clean
rm
-f
src/util/bigInt.ml
# build targets
@@ -797,11 +800,11 @@ src/coq-tactic/coqCompat.ml: src/coq-tactic/coqCompat@coq_compat_version@.ml
lib/coq-tactic/why3tac.cmxs
lib/why3/why3.cmxa $(COQPCMX)
if
$(QUIET)
,@echo
'Linking $@'
$(OCAMLOPT)
$(OFLAGS)
-o
-shared
$(OCAMLOPT)
$(OFLAGS)
-o
-shared
@BIGINTLIB@.cmxa
lib/coq-tactic/why3tac.cma
lib/why3/why3.cma $(COQPCMO)
if
$(QUIET)
,@echo
'Linking $@'
$(OCAMLC)
-a
$(BFLAGS)
-o
$(OCAMLC)
-a
$(BFLAGS)
-o
@BIGINTLIB@.cma
src/coq-tactic/g_why3tac.ml
src/coq-tactic/g_why3tac.ml4
if
$(QUIET)
,@echo
'Camlp5 $<'
@@ -809,12 +812,12 @@ src/coq-tactic/g_why3tac.ml: src/coq-tactic/g_why3tac.ml4
src/coq-tactic/.why3-vo-byte
lib/coq-tactic/Why3.v lib/coq-tactic/why3tac.cma
if
$(QUIET)
,@echo
'Coqc $<'
WHY3CONFIG
$(COQC)
-byte
-I
lib/coq-tactic/
WHY3CONFIG
$(COQC)
-byte
@BIGINTINCLUDE@
-I
lib/coq-tactic/
touch
src/coq-tactic/.why3-vo-opt
lib/coq-tactic/Why3.v lib/coq-tactic/why3tac.cmxs
if
$(QUIET)
,@echo
'Coqc $<'
WHY3CONFIG
$(COQC)
-opt
-I
lib/coq-tactic/
WHY3CONFIG
$(COQC)
-opt
@BIGINTINCLUDE@
-I
lib/coq-tactic/
touch
# depend and clean targets
configure.in
47a250ed
@@ -346,6 +346,7 @@ if test "$enable_zarith" = yes; then
fi
if test -n "$BIGINTINCLUDE"; then
echo "ocamlfind found zarith in $BIGINTINCLUDE"
BIGINTINCLUDE="-I $BIGINTINCLUDE"
else
BIGINTINCLUDE="+zarith"
AC_CHECK_FILE($OCAMLLIB/zarith/zarith.cma,,enable_zarith=no)
@@ -710,6 +711,7 @@ AC_SUBST(SQLITE3LIB)
AC_SUBST(enable_bench)
AC_SUBST(META_OCAMLGRAPH)
AC_SUBST(enable_zarith)
AC_SUBST(BIGINTINCLUDE)
AC_SUBST(BIGINTLIB)
