Commit 47256f46 authored by MARCHE Claude's avatar MARCHE Claude
LCP: proved up to test2 for lcp2
parent db47371a
...@@ -94,9 +94,7 @@ predicate array_bounded (a:array int) (b:int) = ...@@ -94,9 +94,7 @@ predicate array_bounded (a:array int) (b:int) =
lemma permut_bounded : lemma permut_bounded :
forall a1 a2:array int, n:int. forall a1 a2:array int, n:int.
a1.length = a2.length /\ permut a1 a2 /\ array_bounded a1 n -> array_bounded a2 n
array_bounded a1 n /\
permut_sub a1 a2 0 a1.length -> array_bounded a2 n
predicate inv(s:suffixArray) = predicate inv(s:suffixArray) =
s.values.length = s.suffixes.length /\ s.values.length = s.suffixes.length /\
...@@ -128,22 +126,22 @@ let test1 () = ...@@ -128,22 +126,22 @@ let test1 () =
let arr = Array.make 4 0 in let arr = Array.make 4 0 in
arr[0]<-1; arr[1]<-2; arr[2]<-2; arr[3]<-5; arr[0]<-1; arr[1]<-2; arr[2]<-2; arr[3]<-5;
let x = lcp arr 1 2 in let x = lcp arr 1 2 in
assert { x = 1 }; check { x = 1 };
(* int[] brr = {1,2,3,5}; *) (* int[] brr = {1,2,3,5}; *)
let brr = Array.make 4 0 in let brr = Array.make 4 0 in
brr[0]<-1; brr[1]<-2; brr[2]<-3; brr[3]<-5; brr[0]<-1; brr[1]<-2; brr[2]<-3; brr[3]<-5;
let x = lcp brr 1 2 in let x = lcp brr 1 2 in
assert { x = 0 }; check { x = 0 };
(* int[] crr = {1,2,3,5}; *) (* int[] crr = {1,2,3,5}; *)
let crr = Array.make 4 0 in let crr = Array.make 4 0 in
crr[0]<-1; crr[1]<-2; crr[2]<-3; crr[3]<-5; crr[0]<-1; crr[1]<-2; crr[2]<-3; crr[3]<-5;
let x = lcp crr 2 3 in let x = lcp crr 2 3 in
(* int[] drr = {1,2,3,3}; *) (* int[] drr = {1,2,3,3}; *)
let drr = Array.make 4 0 in let drr = Array.make 4 0 in
drr[0]<-1; drr[1]<-2; drr[2]<-3; drr[3]<-3; drr[0]<-1; drr[1]<-2; drr[2]<-3; drr[3]<-3;
let x = lcp drr 2 3 in let x = lcp drr 2 3 in
assert {x = 1} check {x = 1}
let compare (a:array int) (x y:int) : int let compare (a:array int) (x y:int) : int
requires { 0 <= x < a.length } requires { 0 <= x < a.length }
...@@ -160,6 +158,7 @@ let compare (a:array int) (x y:int) : int ...@@ -160,6 +158,7 @@ let compare (a:array int) (x y:int) : int
let sort (a:array int) (data : array int) let sort (a:array int) (data : array int)
requires { array_bounded data a.length } requires { array_bounded data a.length }
ensures { permut (old data) data }
'Init: 'Init:
for i = 0 to data.length - 1 do for i = 0 to data.length - 1 do
...@@ -204,25 +203,25 @@ let test2 () = ...@@ -204,25 +203,25 @@ let test2 () =
let sa = create arr in let sa = create arr in
let x = lcp2 sa 1 in let x = lcp2 sa 1 in
assert {x = -1 (* TODO *)}; check {x = -1 (* TODO *)};
let sa = create brr in let sa = create brr in
let sa = create crr in let sa = create crr in
let x = lcp2 sa 2 in let x = lcp2 sa 2 in
let sa = create drr in let sa = create drr in
assert {x = -1 (* TODO *)} check {x = -1 (* TODO *)}
end end
...@@ -236,7 +235,9 @@ module LRS ...@@ -236,7 +235,9 @@ module LRS
val solStart : ref int val solStart : ref int
val solLength : ref int val solLength : ref int
let lrs (a:array int) : unit = let lrs (a:array int) : unit
requires { a.length >= 0 }
let sa = SuffixArray.create a in let sa = SuffixArray.create a in
solStart := 0; solStart := 0;
solLength := 0; solLength := 0;
...@@ -252,8 +253,7 @@ module LRS ...@@ -252,8 +253,7 @@ module LRS
arr[0]<-7; arr[1]<-8; arr[2]<-8; arr[3]<-9; arr[0]<-7; arr[1]<-8; arr[2]<-8; arr[3]<-9;
lrs arr; lrs arr;
assert { !solStart = 1 }; check { !solStart = 1 /\ !solLength = 1 }
assert { !solLength = 1 }
end end
