Commit 46973e4a authored by MARCHE Claude's avatar MARCHE Claude
ITP: better error messages
parent d649e382
...@@ -454,8 +454,10 @@ let message_zone = ...@@ -454,8 +454,10 @@ let message_zone =
(**** Message-zone printing functions *****) (**** Message-zone printing functions *****)
(* Function used to print stuff on the message_zone *) (* Function used to print stuff on the message_zone *)
let print_message s = let print_message fmt =
message_zone#buffer#set_text s Format.kasprintf
fmt
let add_to_msg_zone s = let add_to_msg_zone s =
let s = message_zone#buffer#get_text () ^ "\n" ^ s in let s = message_zone#buffer#get_text () ^ "\n" ^ s in
...@@ -878,21 +880,21 @@ let open_session: GMenu.menu_item = ...@@ -878,21 +880,21 @@ let open_session: GMenu.menu_item =
let treat_message_notification msg = match msg with let treat_message_notification msg = match msg with
(* TODO: do something ! *) (* TODO: do something ! *)
| Proof_error (_id, s) -> print_message s | Proof_error (_id, s) -> print_message "%s" s
| Transf_error (_id, s) -> print_message s | Transf_error (_id, s) -> print_message "%s" s
| Strat_error (_id, s) -> print_message s | Strat_error (_id, s) -> print_message "%s" s
| Replay_Info s -> print_message s | Replay_Info s -> print_message "%s" s
| Query_Info (_id, s) -> print_message s | Query_Info (_id, s) -> print_message "%s" s
| Query_Error (_id, s) -> print_message s | Query_Error (_id, s) -> print_message "%s" s
| Help s -> print_message s | Help s -> print_message "%s" s
| Information s -> print_message s | Information s -> print_message "%s" s
| Task_Monitor (t, s, r) -> update_monitor t s r | Task_Monitor (t, s, r) -> update_monitor t s r
| Open_File_Error s -> print_message s | Open_File_Error s -> print_message "%s" s
| Error s -> | Error s ->
if Debug.test_flag debug then if Debug.test_flag debug then
print_message s print_message "%s" s
else else
print_message "Request failed." print_message "%s" "Request failed. You can get details using --debug ide_info"
...@@ -968,17 +970,18 @@ let treat_notification n = match n with ...@@ -968,17 +970,18 @@ let treat_notification n = match n with
| Initialized g_info -> | Initialized g_info ->
(* TODO: treat other *) (* TODO: treat other *)
init_completion g_info.provers g_info.transformations g_info.commands; init_completion g_info.provers g_info.transformations g_info.commands;
| Saved -> (* TODO *) | Saved ->
print_message "got a Saved notification not yet supported\n" print_message "Session saved."
| Message (msg) -> treat_message_notification msg | Message (msg) -> treat_message_notification msg
| Dead _s -> (* TODO *)
print_message "got a Dead notification not yet supported\n"
| Task (_id, s) -> | Task (_id, s) ->
(* TODO: check that the id is the current one *) (* TODO: check that the id is the current one *)
task_view#source_buffer#set_text s; task_view#source_buffer#set_text s;
(* scroll to end of text *) (* scroll to end of text *)
task_view#scroll_to_mark `INSERT task_view#scroll_to_mark `INSERT
| File_contents _ -> assert false (* This IDE never requests file contents *) | File_contents _
| Dead _ ->
print_message "Serveur sent an unexpected notification '%a'. Please report." print_notify n
(* start the interface *) (* start the interface *)
...@@ -688,7 +688,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct ...@@ -688,7 +688,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct
init_and_send_file file init_and_send_file file
end end
else else
P.notify (Message (Open_File_Error ("Not a file: " ^ f))) P.notify (Message (Open_File_Error ("File not found: " ^ f)))
else else
P.notify (Message (Open_File_Error ("File already in session: " ^ fn))) P.notify (Message (Open_File_Error ("File already in session: " ^ fn)))
...@@ -737,7 +737,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct ...@@ -737,7 +737,7 @@ module Make (S:Controller_itp.Scheduler) (P:Protocol) = struct
end end
else else
begin begin
P.notify (Message (Open_File_Error ("Not a file: " ^ f))); P.notify (Message (Open_File_Error ("File not found: " ^ f)));
false false
end) end)
with with
