GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
4665915e
4665915e
Guillaume Melquiond
Mark Bool.implb as native for the Coq driver.
3afa7e59
3
drivers/coq-common.gen
4665915e
@@ -43,6 +43,7 @@ theory bool.Bool
syntax function orb "(orb %1 %2)"
syntax function xorb "(xorb %1 %2)"
syntax function notb "(negb %1)"
syntax function implb "(implb %1)"
lib/coq/floating_point/Double.v
4665915e
@@ -164,13 +164,6 @@ Definition neg_post(x:floating_point.DoubleFormat.double)
value
res
value
x
R
exact
res
exact
x
R
model
res
model
x
R
Why3
assumption
Definition
implb
x
bool
y
bool
bool
match
x
y
true
false
false
_
_
true
Why3
assumption
Definition
lt
x
floating_point
DoubleFormat
double
y
floating_point
DoubleFormat
double
Prop
value
x
value
y
R
@@ -180,8 +173,3 @@ Definition gt(x:floating_point.DoubleFormat.double)
y
floating_point
DoubleFormat
double
Prop
value
y
value
x
R
Unused
content
named
double
exact
t
53
1024
Defined
lib/coq/floating_point/Single.v
4665915e
@@ -172,13 +172,6 @@ Definition neg_post(x:floating_point.SingleFormat.single)
value
res
value
x
R
exact
res
exact
x
R
model
res
model
x
R
Why3
assumption
Definition
implb
x
bool
y
bool
bool
match
x
y
true
false
false
_
_
true
Why3
assumption
Definition
lt
x
floating_point
SingleFormat
single
y
floating_point
SingleFormat
single
Prop
value
x
value
y
R
@@ -188,8 +181,3 @@ Definition gt(x:floating_point.SingleFormat.single)
y
floating_point
SingleFormat
single
Prop
value
y
value
x
R
Unused
content
named
single
exact
t
24
128
Defined
