Attention une mise à jour du service Gitlab va être effectuée le mardi 30 novembre entre 17h30 et 18h00. Cette mise à jour va générer une interruption du service dont nous ne maîtrisons pas complètement la durée mais qui ne devrait pas excéder quelques minutes. Cette mise à jour intermédiaire en version 14.0.12 nous permettra de rapidement pouvoir mettre à votre disposition une version plus récente.
Commit 44f9a679 authored by MARCHE Claude's avatar MARCHE Claude
scheduler
parent a8bf97d6
......@@ -1073,7 +1073,7 @@ let root_goals () =
exception AlreadyAttempted
let try_prover ~debug ~timelimit ~memlimit ~prover ~command ~driver
(g : goal) : unit -> unit =
(g : goal) : unit -> proof_attempt_status =
let db = current () in
let attempt =
try
......@@ -1132,16 +1132,20 @@ let try_prover ~debug ~timelimit ~memlimit ~prover ~command ~driver
g.proved <- true;
Goal.set_proved db g true;
(* TODO: update "proved" status of goal parents if any *)
Success
| Why.Call_provers.Timeout ->
External_proof.set_status db attempt Timeout
External_proof.set_status db attempt Timeout;
Timeout
| Why.Call_provers.Invalid | Why.Call_provers.Unknown _ ->
External_proof.set_status db attempt Unknown
External_proof.set_status db attempt Unknown;
Unknown
| Why.Call_provers.Failure _ | Why.Call_provers.HighFailure ->
External_proof.set_status db attempt HighFailure
External_proof.set_status db attempt HighFailure;
HighFailure
with Exit ->
if debug then Format.eprintf "prover callback aborted because of an exception raised during elaboration@.";
HighFailure
......@@ -150,7 +150,8 @@ exception AlreadyAttempted
val try_prover :
debug:bool -> timelimit:int -> memlimit:int -> prover:prover ->
command:string -> driver:Driver.driver -> goal -> (unit -> unit)
(unit -> proof_attempt_status)
(** attempts to prove goal with the given prover. This function
prepares the goal for that prover, adds it as an new
external_proof attempt, setting its current status to Scheduled,
......@@ -158,8 +159,9 @@ val try_prover :
actually sets the status to running, launches the prover, and
waits for its termination. Upon termination of the external
process, the prover's answer is retrieved and database is
updated. The [proved] field of the database is updated, and also
these of any goal affected, according to invariant above.
updated, that is the [proved] field of the database is updated,
and also these of any goal affected, according to invariant
above. The prover result is also returned.
Although goal preparation is not re-entrant, the function
returned initially is re-entrant, thus is suitable for being executed
......@@ -14,7 +14,7 @@ let schedule_proof_attempt ~debug ~timelimit ~memlimit ~prover
goal =
let prepare_goal =
try
Db.try_prover ~debug ~timelimit ~memlimit ~prover ~command ~driver goal
Db.try_prover ~debug ~timelimit ~memlimit ~prover ~command ~driver goal;
with Db.AlreadyAttempted ->
raise Exit
in
......@@ -27,14 +27,16 @@ let schedule_proof_attempt ~debug ~timelimit ~memlimit ~prover
(* lock and store the attempt into the queue *)
Mutex.lock queue_lock;
Queue.push (prepare_goal,callback) attempts;
callback Db.Scheduled;
(* try to run attempt if resource available *)
while !running_proofs < !maximum_running_proofs do
let call,callback = Queue.pop attempts in
incr running_proofs;
Mutex.unlock queue_lock;
(* END LOCKED SECTION *)
call ();
callback ();
callback Db.Running;
let res = call () in
callback res;
(* BEGIN LOCKED SECTION *)
decr running_proofs;
......@@ -23,7 +23,7 @@ open Why
val schedule_proof_attempt :
debug:bool -> timelimit:int -> memlimit:int -> prover:Db.prover ->
callback:(unit -> unit) -> Db.goal -> unit
callback:(Db.proof_attempt_status -> unit) -> Db.goal -> unit
(** schedules an attempt to prove goal with the given prover. This
function just prepares the goal for the proof attempt, and put
it in the queue of waiting proofs attempts, associated with its
......@@ -178,6 +178,8 @@ let do_theory tname th glist =
(* A good-old text-based interface *)
let count = ref 0
let goal_menu g =
try
while true do
......@@ -206,11 +208,14 @@ let goal_menu g =
raise Exit
(* this is for calling the scheduler *)
let callback () =
printf "Scheduled goal is finished, you should update@."
incr count;
let c = !count in
printf "Scheduling task #%d@." c;
let callback result =
printf "Scheduled task #%d: status set to %a, you should update the view@." c Db.print_status result
in
Scheduler.schedule_proof_attempt
~debug:true ~timelimit ~memlimit:0
~debug:false ~timelimit ~memlimit:0
~prover:p.prover ~command:p.command ~driver:p.driver
~callback
g;
