Commit 43ac5bd0 authored by Raphael Rieu-Helft's avatar Raphael Rieu-Helft
Remove spurious spaces, fix precedences
parent 9e916c2e
...@@ -367,7 +367,7 @@ module Print = struct ...@@ -367,7 +367,7 @@ module Print = struct
List.exists is_constructor its List.exists is_constructor its
| _ -> false in | _ -> false in
match query_syntax info.info_syn rs.rs_name, pvl with match query_syntax info.info_syn rs.rs_name, pvl with
| Some s, _ when complex_syntax s -> | Some s, _ when complex_syntax s || pvl = [] ->
let p = Mid.find rs.rs_name info.info_prec in let p = Mid.find rs.rs_name info.info_prec in
syntax_arguments_prec s (print_expr info) p fmt pvl syntax_arguments_prec s (print_expr info) p fmt pvl
| Some s, _ -> | Some s, _ ->
...@@ -407,8 +407,8 @@ module Print = struct ...@@ -407,8 +407,8 @@ module Print = struct
and print_fun_type_args info fmt (args, s, res, e) = and print_fun_type_args info fmt (args, s, res, e) =
if Stv.is_empty s then if Stv.is_empty s then
fprintf fmt "@[%a@] :@ %a@ =@ %a" fprintf fmt "@[%a@]:@ %a@ =@ @[<hov>@[%a@]@]"
(print_list space (print_vs_arg info)) args (print_list_suf space (print_vs_arg info)) args
(print_ty ~use_quote:false info) res (print_ty ~use_quote:false info) res
(print_expr ~opr:false info 18) e (print_expr ~opr:false info 18) e
else else
...@@ -510,7 +510,7 @@ module Print = struct ...@@ -510,7 +510,7 @@ module Print = struct
fprintf fmt fprintf fmt
(protect_on (opr && prec < 16) (protect_on (opr && prec < 16)
"@[<hv>@[<hov 2>if@ %a@]@ then %a@]") "@[<hv>@[<hov 2>if@ %a@]@ then %a@]")
(print_expr ~opr:false info 15) e1 (print_expr ~opr:false ~be:true info 18) e2 (print_expr ~opr:false info 15) e1 (print_expr ~be:true info 18) e2
| Eif (e1, e2, e3) when is_false e2 && is_true e3 -> | Eif (e1, e2, e3) when is_false e2 && is_true e3 ->
fprintf fmt (protect_on (prec < 4) "not %a") fprintf fmt (protect_on (prec < 4) "not %a")
(print_expr info 3) e1 (print_expr info 3) e1
...@@ -526,7 +526,7 @@ module Print = struct ...@@ -526,7 +526,7 @@ module Print = struct
@;<1 0>else@ %a@]") @;<1 0>else@ %a@]")
(print_expr ~opr:false info 18) e1 (print_expr ~opr:false info 18) e1
(print_expr ~opr:false info 18) e2 (print_expr ~opr:false info 18) e2
(print_expr ~opr:false info 18) e3 (print_expr info 18) e3
| Eblock [] -> | Eblock [] ->
fprintf fmt "()" fprintf fmt "()"
| Eblock [e] -> | Eblock [e] ->
...@@ -569,14 +569,16 @@ module Print = struct ...@@ -569,14 +569,16 @@ module Print = struct
(if prec < 18 && opr (if prec < 18 && opr
then "@[<hv>@[<hov 2>begin@ try@ %a@] with@]@\n@[<hov>%a@]@\nend" then "@[<hv>@[<hov 2>begin@ try@ %a@] with@]@\n@[<hov>%a@]@\nend"
else "@[<hv>@[<hov 2>try@ %a@] with@]@\n@[<hov>%a@]@\n") else "@[<hv>@[<hov 2>try@ %a@] with@]@\n@[<hov>%a@]")
(print_expr info 17) e (print_list newline (print_xbranch info false)) xl (print_expr ~be:true ~opr:false info 17) e
| Ematch (e, bl, xl) -> | Ematch (e, bl, xl) ->
(if (prec < 18 && opr) (if (prec < 18 && opr)
then "begin match @[%a@] with@\n@[<hov>%a\n%a@]@\nend" then "begin match @[%a@] with@\n@[<hov>%a\n%a@]@\nend"
else "match @[%a@] with@\n@[<hov>%a\n%a@]") else "match @[%a@] with@\n@[<hov>%a\n%a@]")
(print_expr info 17) e (print_list newline (print_branch info)) bl (print_expr ~be:true ~opr:false info 17) e
(print_list newline (print_xbranch info true)) xl (print_list newline (print_xbranch info true)) xl
| Eexn (xs, None, e) -> | Eexn (xs, None, e) ->
fprintf fmt "@[<hv>let exception %a in@\n%a@]" fprintf fmt "@[<hv>let exception %a in@\n%a@]"
