GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
4397bfd4
4397bfd4
Guillaume Melquiond
Handle matching of boolean values in the interpreter.
fdc992a8
src/whyml/mlw_interp.ml
4397bfd4
@@ -45,6 +45,8 @@ type value =
Vcase
of
value
term_branch
list
let
array_cons_ls
ref
ps_equ
let
ls_true
ref
ps_equ
let
ls_false
ref
ps_equ
let
rec
print_value
fmt
v
match
v
@@ -228,6 +230,9 @@ let rec matching env (t:value) p =
else
if
ls2
ls_constr
then
raise
NoMatch
else
raise
Undetermined
Vbool
b
let
l
if
b
then
ls_true
else
ls_false
in
if
ls_equal
ls1
l
then
env
else
raise
NoMatch
_
raise
Undetermined
@@ -407,8 +412,8 @@ let eval_map_set ls_set l =
let
built_in_theories
"bool"
"Bool"
"True"
Non
e
eval_true
"False"
Non
e
eval_false
"True"
Some
ls_tru
e
eval_true
"False"
Some
ls_fals
e
eval_false
"int"
"Int"
"infix +"
None
eval_int_op
BigInt
add
