Commit 401fca38 authored by Andrei Paskevich's avatar Andrei Paskevich
TPTP: Metitarski has special TPTP syntax
parent 4bcdf5ad
...@@ -9,7 +9,7 @@ ...@@ -9,7 +9,7 @@
* real.Polar (should work as is) * real.Polar (should work as is)
printer "tptp-fof" printer "metitarski"
filename "%f-%t-%g.tptp" filename "%f-%t-%g.tptp"
valid "^SZS status Theorem" valid "^SZS status Theorem"
...@@ -47,9 +47,12 @@ let forget_tvar v = forget_id ident_printer v.tv_name ...@@ -47,9 +47,12 @@ let forget_tvar v = forget_id ident_printer v.tv_name
type tptp_format = FOF | TFF0 | TFF1 type tptp_format = FOF | TFF0 | TFF1
type tptp_number = TPTP | MetiTarski
type info = { type info = {
info_syn : syntax_map; info_syn : syntax_map;
info_fmt : tptp_format; info_fmt : tptp_format;
info_num : tptp_number;
info_srt : ty Mty.t ref; info_srt : ty Mty.t ref;
info_urg : string list ref; info_urg : string list ref;
...@@ -102,6 +105,14 @@ let number_format = { ...@@ -102,6 +105,14 @@ let number_format = {
Number.def_real_support = Number.Number_unsupported; Number.def_real_support = Number.Number_unsupported;
let number_format_metitarski = { number_format with
Number.frac_real_support = Number.Number_custom
(Number.PrintFracReal ("%s", "(%s * %s)", "(%s / %s)"));
let print_number info fmt c = Number.print (match info.info_num with
| TPTP -> number_format | MetiTarski -> number_format_metitarski) fmt c
let rec print_app info fmt ls tl oty = let rec print_app info fmt ls tl oty =
match query_syntax info.info_syn ls.ls_name with match query_syntax info.info_syn ls.ls_name with
| Some s -> syntax_arguments s (print_term info) fmt tl | Some s -> syntax_arguments s (print_term info) fmt tl
...@@ -124,7 +135,7 @@ and print_term info fmt t = match t.t_node with ...@@ -124,7 +135,7 @@ and print_term info fmt t = match t.t_node with
| Tapp (ls, tl) -> | Tapp (ls, tl) ->
print_app info fmt ls tl t.t_ty print_app info fmt ls tl t.t_ty
| Tconst c -> | Tconst c ->
Number.print number_format fmt c print_number info fmt c
| Tlet (t1,tb) -> | Tlet (t1,tb) ->
let v,t2 = t_open_bound tb in let v,t2 = t_open_bound tb in
fprintf fmt "$let_tt(%a@ =@ %a,@ %a)" fprintf fmt "$let_tt(%a@ =@ %a,@ %a)"
...@@ -243,10 +254,13 @@ let print_decl info fmt d = match d.d_node with ...@@ -243,10 +254,13 @@ let print_decl info fmt d = match d.d_node with
head print_pr pr (print_fmla info) f head print_pr pr (print_fmla info) f
| Dprop ((Plemma|Pskip), _, _) -> assert false | Dprop ((Plemma|Pskip), _, _) -> assert false
let print_decls fm = let print_decls fm nm =
let print_decl (sm,fm,ct) fmt d = let print_decl (sm,fm,ct) fmt d =
let info = { info_syn = sm; info_fmt = fm; let info = { info_syn = sm;
info_srt = ref ct; info_urg = ref [] } in info_fmt = fm;
info_num = nm;
info_srt = ref ct;
try print_decl info fmt d; try print_decl info fmt d;
(sm,fm,!(info.info_srt)), !(info.info_urg) (sm,fm,!(info.info_srt)), !(info.info_urg)
with Unsupported s -> raise (UnsupportedDecl (d,s)) in with Unsupported s -> raise (UnsupportedDecl (d,s)) in
...@@ -255,8 +269,8 @@ let print_decls fm = ...@@ -255,8 +269,8 @@ let print_decls fm =
Discriminate.on_syntax_map (fun sm -> Discriminate.on_syntax_map (fun sm ->
Trans.fold print_decl ((sm,fm,Mty.empty),[])) Trans.fold print_decl ((sm,fm,Mty.empty),[]))
let print_task fm = let print_task fm nm =
let print_decls = print_decls fm in let print_decls = print_decls fm nm in
fun args ?old:_ fmt task -> fun args ?old:_ fmt task ->
(* In trans-based p-printing [forget_all] is a no-no *) (* In trans-based p-printing [forget_all] is a no-no *)
(* forget_all ident_printer; *) (* forget_all ident_printer; *)
...@@ -268,9 +282,14 @@ let print_task fm = ...@@ -268,9 +282,14 @@ let print_task fm =
print (snd (Trans.apply print_decls task)); print (snd (Trans.apply print_decls task));
pp_print_flush fmt () pp_print_flush fmt ()
let () = register_printer "tptp-tff0" (print_task TFF0) ~desc:"TPTP TFF0 format" let () =
let () = register_printer "tptp-tff1" (print_task TFF1) ~desc:"TPTP TFF1 format" register_printer "tptp-tff0" (print_task TFF0 TPTP) ~desc:"TPTP TFF0 format";
let () = register_printer "tptp-fof" (print_task FOF) ~desc:"TPTP FOF format" register_printer "tptp-tff1" (print_task TFF1 TPTP) ~desc:"TPTP TFF1 format";
register_printer "tptp-fof" (print_task FOF TPTP) ~desc:"TPTP FOF format"
let () =
register_printer "metitarski" (print_task FOF MetiTarski)
~desc:"MetiTarski TPTP format"
(** DFG input format for SPASS >= 3.8 (** DFG input format for SPASS >= 3.8
(with the help of Daniel Wand) (with the help of Daniel Wand)
...@@ -406,6 +425,7 @@ let print_dfg args ?old:_ fmt task = ...@@ -406,6 +425,7 @@ let print_dfg args ?old:_ fmt task =
let info = { let info = {
info_syn = get_syntax_map task; info_syn = get_syntax_map task;
info_fmt = FOF; info_fmt = FOF;
info_num = TPTP;
info_urg = ref []; info_urg = ref [];
info_srt = ref Mty.empty } in info_srt = ref Mty.empty } in
let dl = Task.task_decls task in let dl = Task.task_decls task in
