GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
3fc95de4
3fc95de4
Andrei Paskevich
Eliminate_epsilon: discriminate monomorphic identities (fix
#127
ce149dc8
2
src/transform/detect_polymorphism.ml
3fc95de4
@@ -79,7 +79,10 @@ let detect_polymorphism_in_decl ign_ts ign_ls ign_pr d =
monomorphic, since it is checked by typing *)
fold_left
fun
acc
ls
,_
acc
check_ls
ign_ls
ls
false
indl
fold_left
fun
acc
ls
,_
acc
check_ls
ign_ls
ls
false
indl
Dprop
_
pr
t
Dprop
_
pr
t
(* todo: NE PAS TESTER le goal *)
(* todo: DO NOT TEST the goal. This requires skolemizing
type variables in the goal _before_ eliminate_epsilon
in the transformation chain, to avoid producing
polymorphic identities in monomorphic tasks *)
not
Spr
mem
pr
ign_pr
not
Spr
mem
pr
ign_pr
let
s
Term
t_ty_freevars
Ty
Stv
empty
t
in
let
s
Term
t_ty_freevars
Ty
Stv
empty
t
in
not
Ty
Stv
is_empty
s
not
Ty
Stv
is_empty
s
src/transform/eliminate_epsilon.ml
3fc95de4
@@ -15,7 +15,7 @@ open Decl
(* Canonical forms for epsilon terms. *)
type
canonical
type
canonical
Id
(* identity lambda (\x (x_i). x (x_i)) *)
Id
of
Ty
ty
Eta
of
term
(* eta-expansed term (\(x_i). t (x_i))
Eta
of
term
(x_i not in t's free variables) *)
Partial
of
lsymbol
term
list
(* partial application
Partial
of
lsymbol
term
list
@@ -48,7 +48,7 @@ let canonicalize x f =
if
Mvs
set_disjoint
t_freevars
Mvs
empty
e
Svs
of_list
rvl
if
Mvs
set_disjoint
t_freevars
Mvs
empty
e
Svs
of_list
rvl
then
Eta
e
then
Eta
e
else
raise
Exit
else
raise
Exit
Tvar
u
v
when
vs_equal
u
v
Id
Tvar
u
v
when
vs_equal
u
v
Id
v
vs_ty
Tapp
ls
fn
t_node
Tvar
u
v
vl
Tapp
ls
fn
t_node
Tvar
u
v
vl
when
ls_equal
ls
fs_func_app
when
ls_equal
ls
fs_func_app
if
vs_equal
u
v
then
match_apps
fn
vl
else
raise
Exit
if
vs_equal
u
v
then
match_apps
fn
vl
else
raise
Exit
@@ -84,8 +84,7 @@ let get_canonical ls =
let
ax
create_prop_decl
Paxiom
pr
t_forall_close
vl
f
in
let
ax
create_prop_decl
Paxiom
pr
t_forall_close
vl
f
in
create_param_decl
cs
ax
cs
create_param_decl
cs
ax
cs
let
id_canonical
let
id_canonical
ty
let
ty
Ty
ty_var
Ty
tv_of_string
"a"
in
let
tyf
Ty
ty_func
ty
ty
in
let
tyf
Ty
ty_func
ty
ty
in
let
cs
create_fsymbol
id_fresh
"identity"
tyf
in
let
cs
create_fsymbol
id_fresh
"identity"
tyf
in
let
vs
create_vsymbol
id_fresh
"y"
ty
in
let
vs
create_vsymbol
id_fresh
"y"
ty
in
@@ -101,6 +100,15 @@ let get_canonical =
let
res
get_canonical
ls
in
let
res
get_canonical
ls
in
Hls
add
ht
ls
res
res
Hls
add
ht
ls
res
res
let
id_canonical
let
ht
Ty
Hty
create
3
in
fun
ty
try
Ty
Hty
find
ht
ty
Not_found
let
res
id_canonical
ty
in
Ty
Hty
add
ht
ty
res
res
let
poly_id_canonical
id_canonical
Ty
ty_var
Ty
tv_of_string
"a"
type
to_elim
type
to_elim
All
(* eliminate all epsilon-terms *)
All
NonLambda
(* preserve lambda-terms *)
NonLambda
@@ -143,8 +151,9 @@ let rec lift_f el acc t0 =
let
vl
Mvs
keys
t_vars
t0
in
let
vl
Mvs
keys
t_vars
t0
in
let
vs
f
t_open_bound
fb
in
let
vs
f
t_open_bound
fb
in
let
acc
t
match
canonicalize
vs
f
let
acc
t
match
canonicalize
vs
f
Id
Id
ty
let
ld
ax
cs
id_canonical
in
let
ld
ax
cs
if
Ty
ty_closed
ty
then
id_canonical
ty
else
poly_id_canonical
in
let
abst
axml
acc
in
let
abst
axml
acc
in
ld
abst
ax
axml
fs_app
cs
vs
vs_ty
ld
abst
ax
axml
fs_app
cs
vs
vs_ty
Eta
t
lift_f
el
acc
t
Eta
t
lift_f
el
acc
t
