Commit 3fc95de4 authored by Andrei Paskevich's avatar Andrei Paskevich
Eliminate_epsilon: discriminate monomorphic identities (fix #127)
parent ce149dc8
......@@ -79,7 +79,10 @@ let detect_polymorphism_in_decl ign_ts ign_ls ign_pr d =
monomorphic, since it is checked by typing *)
List.fold_left (fun acc (ls,_) -> acc || check_ls ign_ls ls) false indl
| Dprop (_,pr,t) ->
(* todo: NE PAS TESTER le goal *)
(* todo: DO NOT TEST the goal. This requires skolemizing
type variables in the goal _before_ eliminate_epsilon
in the transformation chain, to avoid producing
polymorphic identities in monomorphic tasks *)
not (Spr.mem pr ign_pr) &&
let s = Term.t_ty_freevars Ty.Stv.empty t in
not (Ty.Stv.is_empty s)
......@@ -15,7 +15,7 @@ open Decl
(* Canonical forms for epsilon terms. *)
type canonical =
| Id (* identity lambda (\x (x_i). x (x_i)) *)
| Id of Ty.ty (* identity lambda (\x (x_i). x (x_i)) *)
| Eta of term (* eta-expansed term (\(x_i). t (x_i))
(x_i not in t's free variables) *)
| Partial of lsymbol * term list (* partial application
......@@ -48,7 +48,7 @@ let canonicalize x f =
if Mvs.set_disjoint (t_freevars Mvs.empty e) (Svs.of_list rvl)
then Eta e
else raise Exit
| Tvar u, [v] when vs_equal u v -> Id
| Tvar u, [v] when vs_equal u v -> Id v.vs_ty
| Tapp (ls, [fn; {t_node = Tvar u}]), v :: vl
when ls_equal ls fs_func_app ->
if vs_equal u v then match_apps fn vl else raise Exit
......@@ -84,8 +84,7 @@ let get_canonical ls =
let ax = create_prop_decl Paxiom pr (t_forall_close vl [] f) in
create_param_decl cs, ax, cs
let id_canonical =
let ty = Ty.ty_var (Ty.tv_of_string "a") in
let id_canonical ty =
let tyf = Ty.ty_func ty ty in
let cs = create_fsymbol (id_fresh "identity") [] tyf in
let vs = create_vsymbol (id_fresh "y") ty in
......@@ -101,6 +100,15 @@ let get_canonical =
let res = get_canonical ls in
Hls.add ht ls res; res
let id_canonical =
let ht = Ty.Hty.create 3 in fun ty ->
try Ty.Hty.find ht ty with Not_found ->
let res = id_canonical ty in
Ty.Hty.add ht ty res; res
let poly_id_canonical =
id_canonical (Ty.ty_var (Ty.tv_of_string "a"))
type to_elim =
| All (* eliminate all epsilon-terms *)
| NonLambda (* preserve lambda-terms *)
......@@ -143,8 +151,9 @@ let rec lift_f el acc t0 =
let vl = Mvs.keys (t_vars t0) in
let vs, f = t_open_bound fb in
let acc, t = match canonicalize vs f with
| Id ->
let ld, ax, cs = id_canonical in
| Id ty ->
let ld, ax, cs = if Ty.ty_closed ty then
id_canonical ty else poly_id_canonical in
let abst, axml = acc in
(ld :: abst, ax :: axml), fs_app cs [] vs.vs_ty
| Eta t -> lift_f el acc t
