Commit 3b8f70f8 authored by MARCHE Claude's avatar MARCHE Claude
doc: update of getting started with IDE, part 1
parent d781a155
...@@ -67,7 +67,8 @@ ...@@ -67,7 +67,8 @@
* Final preparation: put on the web page * Final preparation: put on the web page
** why3-0.70.tar.gz ** why3-0.70.tar.gz
** manual in PDF ** manual in PDF: TODO: check that macro \todo can be commented out
from ./macros.tex
** API doc in HTML (suggestion: http://why3.lri.fr/api/) ** API doc in HTML (suggestion: http://why3.lri.fr/api/)
Note: check that URL of API doc is correct in doc/api.tex line 9. Note: check that URL of API doc is correct in doc/api.tex line 9.
** What to put in the annoucement ** What to put in the annoucement
...@@ -84,6 +85,8 @@ ...@@ -84,6 +85,8 @@
* document new IDE features (C) * document new IDE features (C)
* update IDE section of starting.tex (C)
* document "Make obsolete" (A) * document "Make obsolete" (A)
* Distribution of examples: we should distribute those who have an xml file * Distribution of examples: we should distribute those who have an xml file
\newcommand{\todo}[1]{{\Huge\bfseries #1}} \newcommand{\todo}[1]{{\Huge\bfseries TODO: #1}}
\newcommand{\why}{\textsf{Why3}\xspace} \newcommand{\why}{\textsf{Why3}\xspace}
\newcommand{\whyml}{\textsf{Why3ML}\xspace} \newcommand{\whyml}{\textsf{Why3ML}\xspace}
...@@ -36,7 +36,7 @@ friendly way. This section presents the basic use of this GUI. Please ...@@ -36,7 +36,7 @@ friendly way. This section presents the basic use of this GUI. Please
refer to Section~\ref{sec:ideref} for a more complete description. refer to Section~\ref{sec:ideref} for a more complete description.
\begin{figure}[tbp] \begin{figure}[tbp]
\includegraphics[width=\textwidth]{gui1.png} \includegraphics[width=\textwidth]{gui-0-70-1.png}
\caption{The GUI when started the very first time} \caption{The GUI when started the very first time}
\label{fig:gui1} \label{fig:gui1}
\end{figure} \end{figure}
...@@ -46,34 +46,36 @@ The GUI is launched on the file above as follows. ...@@ -46,34 +46,36 @@ The GUI is launched on the file above as follows.
why3ide hello_proof.why why3ide hello_proof.why
\end{verbatim} \end{verbatim}
When the GUI is started for the first time, you should get a window When the GUI is started for the first time, you should get a window
which looks like the screenshot of Figure~\ref{fig:gui1}. First of which looks like the screenshot of Figure~\ref{fig:gui1}.
all, the left column is a tool bar which provides different actions to
apply on goals. In this case, the section ``Provers'' is empty, which The left column is a tool bar which provides different actions to
means that you have not performed prover detection yet. You should do it apply on goals. The section ``Provers'' displays the provers that were
now using the menu \textsf{File/Detect provers}. Second, the middle detected as installed on your computer\footnote{If not done yet, you
part is a tree view that allows to browse inside the must perform prover autodetection using \texttt{why3config
theories. Initially, the item of this tree are closed. We can --detect-provers}}. Three provers were detected, in this case
expand this view using the menu \textsf{View/Expand all} or its these are Alt-Ergo~\cite{ergo}, Coq~\cite{CoqArt} and
shortcut \textsf{Ctrl-E}. This will result is something like the Simplify~\cite{simplify05}.
screenshot of Figure~\ref{fig:gui2}.
The middle part is a tree view that
allows to browse inside the theories.
% Initially, the item of this tree
% are closed. We can expand this view using the menu \textsf{View/Expand
% all} or its shortcut \textsf{Ctrl-E}. This will result is something
% like the screenshot of Figure~\ref{fig:gui2}.
In this tree view, we have a structured view of the file: this file
contains one theory, itself containg three goals.
\includegraphics[width=\textwidth]{gui2.png} \includegraphics[width=\textwidth]{gui-0-70-2.png}
\caption{The GUI with provers detected and tree view expanded} \caption{The GUI with goal G1 selected}
\label{fig:gui2} \label{fig:gui2}
In Figure~\ref{fig:gui2}, we clicked on the row corresponding to
In the tree view, we have now a strctured view of the file: this file
contains one theory, itself containg three goals. In
Figure~\ref{fig:gui2}, we also clicked on the row corresponding to
goal $G_1$. The \emph{task} associated with this goal is then goal $G_1$. The \emph{task} associated with this goal is then
displayed on the top right, and the corresponding part of the input displayed on the top right, and the corresponding part of the input
file is shown on the bottom right part. file is shown on the bottom right part.
Notice also that three provers were detected, and are now shown
in the ``provers'' section of the left toolbar. In this example,
detected provers are Alt-Ergo~\cite{ergo}, Coq~\cite{CoqArt} and
\subsection{Calling provers on goals} \subsection{Calling provers on goals}
...@@ -87,7 +89,7 @@ click on the \textsf{Simplify} button. After a short time, you should ...@@ -87,7 +89,7 @@ click on the \textsf{Simplify} button. After a short time, you should
get the display of Figure~\ref{fig:gui3}. get the display of Figure~\ref{fig:gui3}.
\includegraphics[width=\textwidth]{gui3.png} \todo{update \includegraphics[width=\textwidth]{gui3.png}}
\caption{The GUI after Simplify prover is run on each goal} \caption{The GUI after Simplify prover is run on each goal}
\label{fig:gui3} \label{fig:gui3}
...@@ -112,7 +114,7 @@ Simplify. Assuming we expand everything again, you should see now what ...@@ -112,7 +114,7 @@ Simplify. Assuming we expand everything again, you should see now what
is displayed on Figure~\ref{fig:gui4}. is displayed on Figure~\ref{fig:gui4}.
\includegraphics[width=\textwidth]{gui4.png} \todo{update \includegraphics[width=\textwidth]{gui4.png}}
\caption{The GUI after splitting goal $G_2$} \caption{The GUI after splitting goal $G_2$}
\label{fig:gui4} \label{fig:gui4}
...@@ -133,7 +135,7 @@ part you modify, in order to regenerate the file if the goal is ...@@ -133,7 +135,7 @@ part you modify, in order to regenerate the file if the goal is
changed. changed.
\includegraphics[width=\textwidth]{coqide.png} \todo{update \includegraphics[width=\textwidth]{coqide.png}}
\caption{CoqIDE on subgoal 1 of $G_2$} \caption{CoqIDE on subgoal 1 of $G_2$}
\label{fig:coqide} \label{fig:coqide}
...@@ -153,7 +155,7 @@ Starting the IDE on the modified file and expanding everything with ...@@ -153,7 +155,7 @@ Starting the IDE on the modified file and expanding everything with
\textsf{Ctrl-E}, we get the tree view shown on Figure~\ref{fig:gui5}. \textsf{Ctrl-E}, we get the tree view shown on Figure~\ref{fig:gui5}.
\includegraphics[width=\textwidth]{gui5.png} \todo{update \includegraphics[width=\textwidth]{gui5.png}}
\caption{The GUI restarted after modifying goal $G_2$} \caption{The GUI restarted after modifying goal $G_2$}
\label{fig:gui5} \label{fig:gui5}
