Commit 3b62b108 authored by Andrei Paskevich's avatar Andrei Paskevich
whyml: vty instantiation
parent ceff2857
......@@ -65,6 +65,15 @@ module Wreg = Reg.W
let reg_equal : region -> region -> bool = (==)
let reg_hash r = id_hash r.reg_name
(* a region is ghost if and only if it corresponds to a ghost mutable field
in a record. The "contents" region of an ordinary reference is not ghost
even if the reference itself is ghost. This is because we can alias
a non-ghost reference with a ghost reference as follows:
let ghost_ref<ro> = K nonghost_ref<ro> ghost_value
Here, ghost_ref is ghost by contamination, but it shares <ro> with
a non-ghost reference. Notice that any write in ghost_ref is forbidden
(such a write would be a ghost expression touching a non-ghost region). *)
let create_region id ?(ghost=false) ty =
{ reg_name = id_register id; reg_ity = ty; reg_ghost = ghost }
......@@ -164,13 +173,13 @@ let ity_s_any pr pts ity =
(* traversal functions on type variables and regions *)
let rec ity_v_map fnv fnr ity = match ity.ity_node with
let rec ity_v_map_unsafe fnv fnr ity = match ity.ity_node with
| Ityvar v ->
fnv v
| Itypur (f,tl) ->
ity_pur f (List.map (ity_v_map fnv fnr) tl)
ity_pur f (List.map (ity_v_map_unsafe fnv fnr) tl)
| Ityapp (f,tl,rl) ->
ity_app f (List.map (ity_v_map fnv fnr) tl) (List.map fnr rl)
ity_app f (List.map (ity_v_map_unsafe fnv fnr) tl) (List.map fnr rl)
let rec ity_v_fold fnv fnr acc ity = match ity.ity_node with
| Ityvar v ->
......@@ -186,8 +195,8 @@ let ity_v_all prv prr ity =
let ity_v_any prv prr ity =
try ity_v_fold (any_fn prv) (any_fn prr) false ity with FoldSkip -> true
let ity_subst mv mr ity =
ity_v_map (fun v -> Mtv.find v mv) (fun r -> Mreg.find r mr) ity
let ity_subst_unsafe mv mr ity =
ity_v_map_unsafe (fun v -> Mtv.find v mv) (fun r -> Mreg.find r mr) ity
let ity_freevars = ity_v_fold (fun s v -> Stv.add v s) Util.const
let ity_topregions = ity_v_fold Util.const (fun s r -> Sreg.add r s)
......@@ -212,9 +221,16 @@ let ity_equal_check ty1 ty2 =
let reg_equal_check r1 r2 =
if not (reg_equal r1 r2) then raise (RegionMismatch (r1, r2))
let reg_protect fn r =
let nr = fn r in
if nr.reg_ghost <> r.reg_ghost then raise (RegionMismatch (r, nr));
nr
let ity_v_map fnv fnr ity = ity_v_map_unsafe fnv (reg_protect fnr) ity
type ity_subst = {
ity_subst_tv : ity Mtv.t;
ity_subst_reg : region Mreg.t;
ity_subst_reg : region Mreg.t; (* must preserve ghost-ness *)
let ity_subst_empty = {
......@@ -235,13 +251,13 @@ let reg_full_inst s r =
Mreg.find r s.ity_subst_reg
let ity_inst s ity =
ity_v_map
ity_v_map_unsafe
(fun v -> Mtv.find_def (ity_var v) v s.ity_subst_tv)
(fun r -> Mreg.find_def r r s.ity_subst_reg)
ity
let ity_full_inst s ity =
ity_subst s.ity_subst_tv s.ity_subst_reg ity
ity_subst_unsafe s.ity_subst_tv s.ity_subst_reg ity
let rec ity_match s ity1 ity2 =
let set = function
......@@ -262,7 +278,7 @@ let rec ity_match s ity1 ity2 =
and reg_match s r1 r2 =
let is_new = ref false in
let set = function
let set = function (* must preserve ghost-ness of regions *)
| None when r1.reg_ghost = r2.reg_ghost -> is_new := true; Some r2
| Some r3 as r when reg_equal r3 r2 -> r
| _ -> raise Exit
......@@ -300,7 +316,8 @@ and reg_refresh mv mr r = match Mreg.find_opt r mr with
mr, r
| None ->
let mr,ity = ity_inst_fresh mv mr r.reg_ity in
let id = id_clone r.reg_name and ghost = r.reg_ghost in
let id = id_clone r.reg_name in
let ghost = r.reg_ghost in
let reg = create_region id ~ghost ity in
Mreg.add r reg mr, reg
......@@ -312,9 +329,9 @@ let ity_app_fresh s tl =
raise (BadItyArity (s, List.length s.its_args, List.length tl)) in
(* refresh regions *)
let mr,rl = Util.map_fold_left (reg_refresh mv) Mreg.empty s.its_regs in
(* every external region in def is guaranteed to be in mr *)
(* every top region in def is guaranteed to be in mr *)
match s.its_def with
| Some ity -> ity_subst mv mr ity
| Some ity -> ity_subst_unsafe mv mr ity
| None -> ity_app s tl rl
let ity_app s tl rl =
......@@ -324,24 +341,20 @@ let ity_app s tl rl =
with Invalid_argument _ ->
(* region map *)
let add m v r = Mreg.add v r m in
let mr = try List.fold_left2 add Mreg.empty s.its_regs rl
let sub = { ity_subst_tv = mv; ity_subst_reg = Mreg.empty } in
let sub = try List.fold_left2 reg_match sub s.its_regs rl
raise (BadRegArity (s, List.length s.its_regs, List.length rl)) in
(* check that region types do unify *)
let sub = { ity_subst_tv = mv; ity_subst_reg = mr } in
let rmatch sub r1 r2 = ity_match sub r1.reg_ity r2.reg_ity in
ignore (List.fold_left2 rmatch sub s.its_regs rl);
(* to instantiate def, mv and mr are enough *)
(* every type var and top region in def are in its_args and its_regs *)
| Some ity -> ity_full_inst sub ity
let ity_pur s tl = match s.ts_def with
| Some ty ->
let add m v t = Mtv.add v t m in
let m = List.fold_left2 add Mtv.empty s.ts_args tl in
ity_subst m Mreg.empty (ity_of_ty ty)
ity_subst_unsafe m Mreg.empty (ity_of_ty ty)
| None ->
ity_pur s tl
......@@ -415,7 +428,8 @@ let eff_union x y =
{ eff_reads = Sreg.union x.eff_reads y.eff_reads;
eff_writes = Sreg.union x.eff_writes y.eff_writes;
eff_resets = Mreg.union join_reset x.eff_resets y.eff_resets;
eff_raises = Sexn.union x.eff_raises y.eff_raises; }
let eff_read e r = { e with eff_reads = Sreg.add r e.eff_reads }
let eff_write e r = { e with eff_writes = Sreg.add r e.eff_writes }
......@@ -473,6 +487,8 @@ type pvsymbol = {
pv_ity : ity;
pv_ghost : bool;
pv_mutable : region option;
pv_tvs : Stv.t;
pv_regs : Sreg.t;
module Pv = StructMake (struct
......@@ -491,15 +507,24 @@ let create_pvsymbol id ?mut ?(ghost=false) ity =
let ty = ty_of_ity ity in
let vs = create_vsymbol id ty in
begin match mut with
| Some r when not (ity_equal r.reg_ity ity) || ghost <> r.reg_ghost ->
| Some r when
(* A ghost variable may contain a non-ghost region.
No writes are allowed in such a ghost variable. *)
not (ity_equal r.reg_ity ity) || (r.reg_ghost && not ghost) ->
raise (InvalidPVsymbol vs.vs_name)
| _ ->
end;
{ pv_vs = vs;
pv_ity = ity;
pv_ghost = ghost;
pv_mutable = mut; }
let tvs = ity_freevars Stv.empty ity in
let regs = ity_topregions Sreg.empty ity in
let regs = option_fold (fun s r -> Sreg.add r s) regs mut in
{ pv_vs = vs;
pv_ity = ity;
pv_ghost = ghost;
pv_mutable = mut;
pv_tvs = tvs;
pv_regs = regs;
let pv_clone pv =
let id = id_clone pv.pv_vs.vs_name in
......@@ -525,7 +550,9 @@ and vty_arrow = {
a_eff : effect;
a_pre : term; (* epsilon under a dummy variable, to accumulate substs *)
a_post : term; (* epsilon under the value variable or under a dummy vs *)
a_xpost : (vsymbol * term) Mexn.t; (* epsilon under the value variable *)
a_xpost : term Mexn.t; (* epsilon under the exception value variable *)
a_tvs : Stv.t; (* we do not count type variables in eff/pre/post/xpost *)
a_regs : Sreg.t; (* we do not count regions in eff/pre/post/xpost *)
type pre = term
......@@ -540,6 +567,14 @@ type vty_comp = {
c_xpost : xpost;
let vty_freevars s = function
| VTvalue pv -> Stv.union s pv.pv_tvs
| VTarrow a -> Stv.union s a.a_tvs
let vty_topregions s = function
| VTvalue pv -> Sreg.union s pv.pv_regs
| VTarrow a -> Sreg.union s a.a_regs
(* smart constructors *)
let vty_value pvs = VTvalue pvs
......@@ -563,11 +598,11 @@ let open_spec = function
let vty_arrow
x ?(pre=t_true) ?(post=t_true) ?(xpost=Mexn.empty) ?(effect=eff_empty) vty =
(* check for clashes *)
let check_vs y = if vs_equal x.pv_vs y then raise (DuplicateVar y) in
(* let check_vs y = if vs_equal x.pv_vs y then raise (DuplicateVar y) in *)
let check_pv y = if pv_equal x y then raise (DuplicateVar x.pv_vs) in
let rec check = function
| VTarrow a ->
Mexn.iter (fun _ (y,_) -> check_vs y) a.a_xpost;
(* Mexn.iter (fun _ (y,_) -> check_vs y) a.a_xpost; *)
check_pv a.a_arg;
check a.a_vty
| VTvalue y ->
......@@ -586,8 +621,8 @@ let vty_arrow
let conv_xpost xs (vs,f) =
if not (ty_equal (ty_of_ity xs.xs_ity) vs.vs_ty)
then raise (InvalidExceptionPost xs);
check_vs vs;
vs, t_eps_close vs f
(* check_vs vs; *)
t_eps_close vs f
in
let post = match vty with
| VTvalue pv -> t_eps_close pv.pv_vs post
......@@ -600,6 +635,8 @@ let vty_arrow
a_pre = close_spec pre;
a_post = post;
a_xpost = Mexn.mapi conv_xpost xpost;
a_tvs = vty_freevars x.pv_tvs vty;
a_regs = vty_topregions x.pv_regs vty;
......@@ -615,14 +652,14 @@ let vty_app_arrow arr x =
let subst f = t_subst_single arr.a_arg.pv_vs (t_var x.pv_vs) f in
let _,pre = open_spec (subst arr.a_pre) in
let res,post = open_spec (subst arr.a_post) in
let xsubst (_,e) = open_spec (subst e) in
let xsubst e = open_spec (subst e) in
let rec arr_subst arr = { arr with
a_vty = (match arr.a_vty with
| VTarrow a -> VTarrow (arr_subst a)
| VTvalue _ -> arr.a_vty);
a_pre = subst arr.a_pre;
a_post = subst arr.a_post;
a_xpost = Mexn.map (fun (x,e) -> x, subst e) arr.a_xpost;
a_xpost = Mexn.map subst arr.a_xpost;
in
let vty = match arr.a_vty with
......@@ -644,14 +681,28 @@ let open_vty_arrow arr =
let c = vty_app_arrow arr pv in
pv, c.c_vty
let vty_full_inst ~ghost s = function
| VTvalue pv ->
let pv = pv_full_inst s pv in
VTvalue { pv with pv_ghost = ghost || pv.pv_ghost }
| VTarrow _a ->
assert false (*TODO*)
let vty_app_spec _subst _v _pv (* : pre * post * xpost *) =
let vty_full_inst s vty =
let subT = Mtv.map ty_of_ity s.ity_subst_tv in
let rec inst subV = function
| VTvalue pv ->
(* this is not the same vsymbol anymore that is bound in
the preceding post. However, this should not matter. *)
VTvalue (pv_full_inst s pv)
| VTarrow a ->
let x = pv_full_inst s a.a_arg in
let subV = Mvs.add a.a_arg.pv_vs (t_var x.pv_vs) subV in
let subst = t_ty_subst subT subV in
let vty = inst subV a.a_vty in
VTarrow {
a_arg = x;
a_vty = vty;
a_eff = eff_full_inst s a.a_eff;
a_pre = subst a.a_pre;
a_post = subst a.a_post;
a_xpost = Mexn.map subst a.a_xpost;
in
inst Mvs.empty vty
......@@ -182,6 +182,8 @@ type pvsymbol = private {
pv_ity : ity;
pv_ghost : bool;
pv_tvs : Stv.t;
pv_regs : Sreg.t;
val create_pvsymbol : preid -> ?mut:region -> ?ghost:bool -> ity -> pvsymbol
......@@ -218,3 +220,10 @@ val vty_app_arrow : vty_arrow -> pvsymbol -> vty_comp
val open_vty_arrow : vty_arrow -> pvsymbol * vty
val vty_freevars : Stv.t -> vty -> Stv.t (* only args and values count... *)
val vty_topregions : Sreg.t -> vty -> Sreg.t (* ...not eff/pre/post/xpost *)
(* the substitution must cover not only the vty_freevars and
vty_topregions of vty, but also every type variable and
every region in effects and pre/post/xpost formulas *)
val vty_full_inst : ity_subst -> vty -> vty
