Commit 38ce7f9d authored by Andrei Paskevich's avatar Andrei Paskevich
whyml: don't compute WP for library modules
parent fafd30d7
...@@ -31,11 +31,14 @@ let read_channel env path file c = ...@@ -31,11 +31,14 @@ let read_channel env path file c =
let inc = Mlw_typing.open_file env path in let inc = Mlw_typing.open_file env path in
Lexer.parse_program_file inc lb; Lexer.parse_program_file inc lb;
let mm, tm = Mlw_typing.close_file () in let mm, tm = Mlw_typing.close_file () in
if Debug.test_flag debug then Mstr.iter (fun _ m -> if path = [] && Debug.test_flag debug then begin
Format.fprintf Format.err_formatter let add_m _ m modm = Ident.Mid.add m.mod_theory.Theory.th_name m modm in
"@[<hov 2>module %a@\n%a@]@\nend@." Pretty.print_th m.mod_theory let modm = Mstr.fold add_m mm Ident.Mid.empty in
(Pp.print_list Pp.newline2 Mlw_pretty.print_pdecl) m.mod_decls; let print_m _ m = Format.eprintf
Format.pp_print_newline Format.err_formatter ()) mm; "@[<hov 2>module %a@\n%a@]@\nend@\n@." Pretty.print_th m.mod_theory
(Pp.print_list Pp.newline2 Mlw_pretty.print_pdecl) m.mod_decls in
Ident.Mid.iter print_m modm
end;
mm, tm mm, tm
let library_of_env = Env.register_format "whyml" ["mlw"] read_channel let library_of_env = Env.register_format "whyml" ["mlw"] read_channel
...@@ -289,14 +289,14 @@ let pdecl_vc env km th d = match d.pd_node with ...@@ -289,14 +289,14 @@ let pdecl_vc env km th d = match d.pd_node with
| PDlet ld -> Mlw_wp.wp_let env km th ld | PDlet ld -> Mlw_wp.wp_let env km th ld
| PDrec rdl -> Mlw_wp.wp_rec env km th rdl | PDrec rdl -> Mlw_wp.wp_rec env km th rdl
let add_pdecl uc d = let add_pdecl ~wp uc d =
let uc = { uc with let uc = { uc with
muc_decls = d :: uc.muc_decls; muc_decls = d :: uc.muc_decls;
muc_known = known_add_decl (Theory.get_known uc.muc_theory) uc.muc_known d; muc_known = known_add_decl (Theory.get_known uc.muc_theory) uc.muc_known d;
muc_local = Sid.union uc.muc_local d.pd_news } muc_local = Sid.union uc.muc_local d.pd_news }
in in
let uc = let uc =
if Debug.test_flag Typing.debug_type_only then uc else if not wp then uc else
let th = pdecl_vc uc.muc_env uc.muc_known uc.muc_theory d in let th = pdecl_vc uc.muc_env uc.muc_known uc.muc_theory d in
{ uc with muc_theory = th } { uc with muc_theory = th }
in in
...@@ -90,7 +90,7 @@ val add_meta : module_uc -> meta -> meta_arg list -> module_uc ...@@ -90,7 +90,7 @@ val add_meta : module_uc -> meta -> meta_arg list -> module_uc
(** Program decls *) (** Program decls *)
val add_pdecl : module_uc -> pdecl -> module_uc val add_pdecl : wp:bool -> module_uc -> pdecl -> module_uc
(** Builtin symbols *) (** Builtin symbols *)
...@@ -137,7 +137,7 @@ let flush_tuples uc = ...@@ -137,7 +137,7 @@ let flush_tuples uc =
Hashtbl.clear ht_tuple; Hashtbl.clear ht_tuple;
uc uc
let add_pdecl_with_tuples uc pd = add_pdecl (flush_tuples uc) pd let add_pdecl_with_tuples ~wp uc pd = add_pdecl ~wp (flush_tuples uc) pd
let add_decl_with_tuples uc d = add_decl (flush_tuples uc) d let add_decl_with_tuples uc d = add_decl (flush_tuples uc) d
(** Namespace lookup *) (** Namespace lookup *)
...@@ -1061,7 +1061,7 @@ let look_for_loc tdl s = ...@@ -1061,7 +1061,7 @@ let look_for_loc tdl s =
in in
List.fold_left look None tdl List.fold_left look None tdl
let add_types uc tdl = let add_types ~wp uc tdl =
let add m d = let add m d =
let id = d.td_ident.id in let id = d.td_ident.id in
Mstr.add_new (Loc.Located (d.td_loc, ClashSymbol id)) id d m in Mstr.add_new (Loc.Located (d.td_loc, ClashSymbol id)) id d m in
...@@ -1329,7 +1329,7 @@ let add_types uc tdl = ...@@ -1329,7 +1329,7 @@ let add_types uc tdl =
in in
let add_type_decl uc ts = let add_type_decl uc ts =
if is_impure_type ts then if is_impure_type ts then
add_pdecl_with_tuples uc (create_ty_decl ts) add_pdecl_with_tuples ~wp uc (create_ty_decl ts)
else else
add_decl_with_tuples uc (Decl.create_ty_decl ts.its_pure) add_decl_with_tuples uc (Decl.create_ty_decl ts.its_pure)
in in
...@@ -1337,7 +1337,7 @@ let add_types uc tdl = ...@@ -1337,7 +1337,7 @@ let add_types uc tdl =
let uc = List.fold_left add_type_decl uc abstr in let uc = List.fold_left add_type_decl uc abstr in
let uc = if algeb = [] then uc else let uc = if algeb = [] then uc else
if List.exists is_impure_data algeb then if List.exists is_impure_data algeb then
add_pdecl_with_tuples uc (create_data_decl algeb) add_pdecl_with_tuples ~wp uc (create_data_decl algeb)
else else
let d = List.map mk_pure_decl algeb in let d = List.map mk_pure_decl algeb in
add_decl_with_tuples uc (Decl.create_data_decl d) add_decl_with_tuples uc (Decl.create_data_decl d)
...@@ -1445,15 +1445,15 @@ let add_decl loc uc decl = ...@@ -1445,15 +1445,15 @@ let add_decl loc uc decl =
in in
add_td uc (Theory.get_rev_decls (Typing.add_decl loc th0 decl)) add_td uc (Theory.get_rev_decls (Typing.add_decl loc th0 decl))
let add_decl loc uc = function let add_decl ~wp loc uc = function
| TypeDecl tdl -> add_types uc tdl | TypeDecl tdl -> add_types ~wp uc tdl
| decl -> add_decl loc uc decl | decl -> add_decl loc uc decl
let add_decl loc uc d = let add_decl ~wp loc uc d =
if Debug.test_flag Typing.debug_parse_only then uc else if Debug.test_flag Typing.debug_parse_only then uc else
Loc.try3 loc add_decl loc uc d Loc.try3 loc (add_decl ~wp) loc uc d
let add_pdecl loc uc = function let add_pdecl ~wp loc uc = function
| Dlet (id, gh, e) -> | Dlet (id, gh, e) ->
let e = dexpr (create_denv uc) e in let e = dexpr (create_denv uc) e in
let pd = match e.de_desc with let pd = match e.de_desc with
...@@ -1466,12 +1466,12 @@ let add_pdecl loc uc = function ...@@ -1466,12 +1466,12 @@ let add_pdecl loc uc = function
errorm ~loc "%s must be a ghost variable" id.id; errorm ~loc "%s must be a ghost variable" id.id;
let def = create_let_defn (Denv.create_user_id id) e in let def = create_let_defn (Denv.create_user_id id) e in
create_let_decl def in create_let_decl def in
add_pdecl_with_tuples uc pd add_pdecl_with_tuples ~wp uc pd
| Dletrec rdl -> | Dletrec rdl ->
let rdl = dletrec (create_denv uc) rdl in let rdl = dletrec (create_denv uc) rdl in
let rdl = expr_rec (create_lenv uc) rdl in let rdl = expr_rec (create_lenv uc) rdl in
let pd = create_rec_decl rdl in let pd = create_rec_decl rdl in
| Dexn (id, pty) -> | Dexn (id, pty) ->
let ity = match pty with let ity = match pty with
| Some pty -> | Some pty ->
...@@ -1479,7 +1479,7 @@ let add_pdecl loc uc = function ...@@ -1479,7 +1479,7 @@ let add_pdecl loc uc = function
| None -> ity_unit in | None -> ity_unit in
let xs = create_xsymbol (Denv.create_user_id id) ity in let xs = create_xsymbol (Denv.create_user_id id) ity in
let pd = create_exn_decl xs in let pd = create_exn_decl xs in
| Dparam (id, gh, tyv) -> | Dparam (id, gh, tyv) ->
let tyv, _ = dtype_v (create_denv uc) tyv in let tyv, _ = dtype_v (create_denv uc) tyv in
let tyv = type_v (create_lenv uc) gh Svs.empty vars_empty tyv in let tyv = type_v (create_lenv uc) gh Svs.empty vars_empty tyv in
...@@ -1493,11 +1493,11 @@ let add_pdecl loc uc = function ...@@ -1493,11 +1493,11 @@ let add_pdecl loc uc = function
errorm ~loc "%s must be a ghost function" id.id; errorm ~loc "%s must be a ghost function" id.id;
LetA (create_psymbol (Denv.create_user_id id) a) in LetA (create_psymbol (Denv.create_user_id id) a) in
let pd = create_val_decl lv in let pd = create_val_decl lv in
let add_pdecl loc uc d = let add_pdecl ~wp loc uc d =
Loc.try3 loc add_pdecl loc uc d Loc.try3 loc (add_pdecl ~wp) loc uc d
let use_clone_pure lib mth uc loc (use,inst) = let use_clone_pure lib mth uc loc (use,inst) =
...@@ -1586,6 +1586,7 @@ let open_file, close_file = ...@@ -1586,6 +1586,7 @@ let open_file, close_file =
let lenv = Stack.create () in let lenv = Stack.create () in
let open_file lib path = let open_file lib path =
let env = Env.env_of_library lib in let env = Env.env_of_library lib in
let wp = path = [] && Debug.nottest_flag Typing.debug_type_only in
Stack.push (Mstr.empty,Mstr.empty) lenv; Stack.push (Mstr.empty,Mstr.empty) lenv;
let open_theory id = Stack.push false inm; let open_theory id = Stack.push false inm;
Stack.push (Theory.create_theory ~path (Denv.create_user_id id)) tuc in Stack.push (Theory.create_theory ~path (Denv.create_user_id id)) tuc in
...@@ -1602,10 +1603,10 @@ let open_file, close_file = ...@@ -1602,10 +1603,10 @@ let open_file, close_file =
then Stack.push (Mlw_module.close_namespace (Stack.pop muc) imp name) muc then Stack.push (Mlw_module.close_namespace (Stack.pop muc) imp name) muc
else Stack.push (Theory.close_namespace (Stack.pop tuc) imp name) tuc in else Stack.push (Theory.close_namespace (Stack.pop tuc) imp name) tuc in
let new_decl loc d = if Stack.top inm let new_decl loc d = if Stack.top inm
then Stack.push (add_decl loc (Stack.pop muc) d) muc then Stack.push (add_decl ~wp loc (Stack.pop muc) d) muc
else Stack.push (Typing.add_decl loc (Stack.pop tuc) d) tuc in else Stack.push (Typing.add_decl loc (Stack.pop tuc) d) tuc in
let new_pdecl loc d = let new_pdecl loc d =
Stack.push (add_pdecl loc (Stack.pop muc) d) muc in Stack.push (add_pdecl ~wp loc (Stack.pop muc) d) muc in
let use_clone loc use = let (mmd,mth) = Stack.top lenv in if Stack.top inm let use_clone loc use = let (mmd,mth) = Stack.top lenv in if Stack.top inm
then Stack.push (use_clone lib mmd mth (Stack.pop muc) loc use) muc then Stack.push (use_clone lib mmd mth (Stack.pop muc) loc use) muc
else Stack.push (use_clone_pure lib mth (Stack.pop tuc) loc use) tuc in else Stack.push (use_clone_pure lib mth (Stack.pop tuc) loc use) tuc in
