Commit 3876183a authored by Sylvain Dailler's avatar Sylvain Dailler
Removed useless use_shapes argument.
parent 8039f0d5
...@@ -404,7 +404,7 @@ let reload_files (c : controller) ~use_shapes = ...@@ -404,7 +404,7 @@ let reload_files (c : controller) ~use_shapes =
let add_file c ?format fname = let add_file c ?format fname =
let theories = read_file c.controller_env ?format fname in let theories = read_file c.controller_env ?format fname in
add_file_section ~use_shapes:false c.controller_session fname theories format add_file_section c.controller_session fname theories format
(* Update the proof_state according to new false state and then remove (* Update the proof_state according to new false state and then remove
the subtree *) the subtree *)
...@@ -1295,7 +1295,7 @@ let merge_theory ~use_shapes env old_s old_th s th : unit = ...@@ -1295,7 +1295,7 @@ let merge_theory ~use_shapes env old_s old_th s th : unit =
(* add a theory and its goals to a session. if a previous theory is (* add a theory and its goals to a session. if a previous theory is
provided in merge try to merge the new theory with the previous one *) provided in merge try to merge the new theory with the previous one *)
let make_theory_section ~use_shapes ?merge (s:session) parent_name (th:Theory.theory) let make_theory_section ?merge (s:session) parent_name (th:Theory.theory)
: theory = : theory =
let add_goal parent goal id = let add_goal parent goal id =
let name,_expl,task = Termcode.goal_expl_task ~root:true goal in let name,_expl,task = Termcode.goal_expl_task ~root:true goal in
...@@ -1312,21 +1312,21 @@ let make_theory_section ~use_shapes ?merge (s:session) parent_name (th:Theory.th ...@@ -1312,21 +1312,21 @@ let make_theory_section ~use_shapes ?merge (s:session) parent_name (th:Theory.th
List.iter2 (add_goal parent) tasks goalsID; List.iter2 (add_goal parent) tasks goalsID;
begin begin
match merge with match merge with
| Some (old_s, old_th, env) -> | Some (old_s, old_th, env, use_shapes) ->
merge_theory ~use_shapes env old_s old_th s theory merge_theory ~use_shapes env old_s old_th s theory
| _ -> () | _ -> ()
end; end;
theory theory
(* add a why file to a session *) (* add a why file to a session *)
let add_file_section ~use_shapes (s:session) (fn:string) let add_file_section (s:session) (fn:string)
(theories:Theory.theory list) format : unit = (theories:Theory.theory list) format : unit =
let fn = Sysutil.relativize_filename s.session_dir fn in let fn = Sysutil.relativize_filename s.session_dir fn in
if Hstr.mem s.session_files fn then if Hstr.mem s.session_files fn then
Debug.dprintf debug "[session] file %s already in database@." fn Debug.dprintf debug "[session] file %s already in database@." fn
else else
begin begin
let theories = List.map (make_theory_section ~use_shapes s fn) theories in let theories = List.map (make_theory_section s fn) theories in
let f = { file_name = fn; let f = { file_name = fn;
file_format = format; file_format = format;
file_theories = theories; file_theories = theories;
...@@ -1356,10 +1356,10 @@ let merge_file_section ~use_shapes ~old_ses ~old_theories ~env ...@@ -1356,10 +1356,10 @@ let merge_file_section ~use_shapes ~old_ses ~old_theories ~env
(* if we found one, we remove it from the table and merge it *) (* if we found one, we remove it from the table and merge it *)
let old_th = Hstr.find old_th_table theory_name in let old_th = Hstr.find old_th_table theory_name in
Hstr.remove old_th_table theory_name; Hstr.remove old_th_table theory_name;
make_theory_section ~use_shapes ~merge:(old_ses,old_th,env) s fn th make_theory_section ~merge:(old_ses,old_th,env,use_shapes) s fn th
with Not_found -> with Not_found ->
(* if no theory was found we make a new theory section *) (* if no theory was found we make a new theory section *)
make_theory_section ~use_shapes s fn th make_theory_section s fn th
in in
let theories = List.map add_theory theories in let theories = List.map add_theory theories in
(* we save the remaining, detached *) (* we save the remaining, detached *)
...@@ -108,9 +108,9 @@ val empty_session : ?shape_version:int -> string -> session ...@@ -108,9 +108,9 @@ val empty_session : ?shape_version:int -> string -> session
argument *) argument *)
val add_file_section : val add_file_section :
use_shapes:bool -> session -> string -> (Theory.theory list) -> session -> string -> (Theory.theory list) ->
Env.fformat option -> unit Env.fformat option -> unit
(** [add_file_section ~merge:(old_s,old_ths,env) s fn ths] adds a new (** [add_file_section s fn ths] adds a new
'file' section in session [s], named [fn], containing fresh theory 'file' section in session [s], named [fn], containing fresh theory
subsections corresponding to theories [ths]. The tasks of each subsections corresponding to theories [ths]. The tasks of each
theory nodes generated are computed using [Task.split_theory]. *) theory nodes generated are computed using [Task.split_theory]. *)
