GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
376cf77b
376cf77b
Sylvain Dailler
Clean does not remove running proof attempt.
fffc8da5
2
2 changed files
21 additions
13 deletions
+21
-13
src/session/controller_itp.ml
+19
-12
src/session/session_itp.mli
+2
-1
376cf77b
@@ -682,25 +682,32 @@ let schedule_tr_with_same_arguments
let
name
get_transf_name
s
tr
in
schedule_transformation
c
pn
name
args
callback
notification
let
is_valid
pa
proof_attempt_node
bool
match
pa
Session_itp
proof_state
None
false
Some
pr
begin
match
pr
Call_provers
pr_answer
Call_provers
Valid
true
_
false
let
is_running
pa
proof_attempt_node
bool
match
pa
Session_itp
proof_state
None
true
Some
pr
false
let
clean_session
c
remove
node_change
let
is_valid
pa
proof_attempt_node
bool
match
pa
Session_itp
proof_state
None
false
Some
pr
begin
match
pr
Call_provers
pr_answer
Call_provers
Valid
true
_
false
in
let
s
c
controller_session
in
Session_itp
session_iter_proof_attempt
fun
_
pa
let
pnid
pa
in
Hprover
iter
fun
_
paid
if
not
is_valid
get_proof_attempt_node
s
paid
then
let
npa
s
paid
in
if
not
is_valid
npa
not
is_running
npa
then
remove_subtree
c
removed
remove
node_change
APa
paid
get_proof_attempt_ids
s
pnid
s
s
pnid
s
(* This function folds on any subelements of given node and tries to mark all
proof attempts it encounters *)
376cf77b
@@ -65,7 +65,8 @@ type proof_attempt_node = {
proof_script
string
option
(* non empty for external ITP *)
val
proofAttemptID
proof_attempt_node
unit
session
unit
val
proofAttemptID
proof_attempt_node
unit
session
unit
(* [is_below s a b] true if a is below b in the session tree *)
val
is_below
session
any
any
bool
