Commit 366f7e3a authored by MARCHE Claude's avatar MARCHE Claude
fixed typos on doc of by/so
parent 7184c50f
...@@ -447,22 +447,31 @@ P(t) ...@@ -447,22 +447,31 @@ P(t)
corresponding set of subgoals. In absence of case analysis labels, corresponding set of subgoals. In absence of case analysis labels,
the number of subgoals generated is linear in the size of the initial goal. the number of subgoals generated is linear in the size of the initial goal.
\paragraph{Behavior on asymetric connectives and \texttt{by}/\texttt{so}} \paragraph{Behavior on asymmetric connectives and
The transformation treat specially asymetric and \texttt{by}/\texttt{so} The transformation treat specially asymmetric and
connectives. Asymetric conjunction \verb|A && B| in goal position \texttt{by}/\texttt{so} connectives. Asymmetric conjunction
is handled as syntactic sugar for \verb|A /\ (A -> B)|. \verb|A && B| in goal position is handled as syntactic sugar for
The conclusion of the first subgoal can then be used to prove the second one. \verb|A /\ (A -> B)|. The conclusion of the first subgoal can then
Asymetric disjunction \verb+A || B+ in hypothesis position is handled as Asymmetric disjunction \verb+A || B+ in hypothesis position is handled as
syntactic sugar for \verb|A \/ ((not A) /\ B)|. syntactic sugar for \verb|A \/ ((not A) /\ B)|.
In particular, a case analysis on such hypothesis would give the negation of In particular, a case analysis on such hypothesis would give the negation of
the first hypothesis in the second case. the first hypothesis in the second case.
The \texttt{by} connective is treated as a proof indication. In hypothesis position, \verb|A by B| is treated as if it were syntactic sugar for its regular interpretation \verb|A|. In goal position, it is treated as if \verb|B| was an intermediate step for proving \verb|A|. \verb|A by B| is then replaced by |B| and the transformation also generates a side-condition subgoal \verb|B -> A| representing the logical cut. The \texttt{by} connective is treated as a proof indication. In
Although splitting stops at disjunctive points like syntactic sugar for its regular interpretation \verb|A|. In goal
symetric disjunction and left-hand sides of implications, the occurences of the \texttt{by} connective are not restricted. For instance: position, it is treated as if \verb|B| was an intermediate step for
proving \verb|A|. \verb|A by B| is then replaced by \verb|B| and the
Although splitting stops at disjunctive points like symmetric
disjunction and left-hand sides of implications, the occurrences of
\begin{itemize} \begin{itemize}
\item Splitting \item Splitting
\begin{whycode} \begin{whycode}
...@@ -494,7 +503,7 @@ goal G1 : B || D ...@@ -494,7 +503,7 @@ goal G1 : B || D
goal G2 : B -> A (* side-condition *) goal G2 : B -> A (* side-condition *)
goal G3 : B || (D -> C) (* side-condition *) goal G3 : B || (D -> C) (* side-condition *)
\end{whycode} \end{whycode}
Note that due to the asymetric disjunction, the disjunction is kept in the Note that due to the asymmetric disjunction, the disjunction is kept in the
second side-condition subgoal. second side-condition subgoal.
...@@ -508,9 +517,9 @@ goal G2 : forall x. x = 42 -> P x (* side-condition *) ...@@ -508,9 +517,9 @@ goal G2 : forall x. x = 42 -> P x (* side-condition *)
Note that in the side-condition subgoal, the context is universally closed. Note that in the side-condition subgoal, the context is universally closed.
\end{itemize} \end{itemize}
The \texttt{so} connective plays a similar role in hypothesis position, as it serves as a consequence indication. In goal position, \verb|A so B| is treated as if it were syntatic sugar for its regular interpretation \verb|A|. In hypothesis position, it is treated as if both \verb|A| and \verb|B| were true because \verb|B| is a consequence of \verb|A|. \verb|A so B| is replaced by \verb|A /\ B| and the transformation also generates a side-condition subgoal \verb|A -> B| corresponding to the consequence relation between formula. The \texttt{so} connective plays a similar role in hypothesis position, as it serves as a consequence indication. In goal position, \verb|A so B| is treated as if it were syntactic sugar for its regular interpretation \verb|A|. In hypothesis position, it is treated as if both \verb|A| and \verb|B| were true because \verb|B| is a consequence of \verb|A|. \verb|A so B| is replaced by \verb|A /\ B| and the transformation also generates a side-condition subgoal \verb|A -> B| corresponding to the consequence relation between formula.
As for the \texttt{by} connective, occurences of \texttt{so} are unrestricted. As for the \texttt{by} connective, occurrences of \texttt{so} are unrestricted.
For instance: For instance:
...@@ -535,21 +544,26 @@ goal G3 : forall x. P x -> Q x -> T x (* side-condition *) ...@@ -535,21 +544,26 @@ goal G3 : forall x. P x -> Q x -> T x (* side-condition *)
goal G4 : forall x. P x -> Q x -> T x -> R x (* side-condition *) goal G4 : forall x. P x -> Q x -> T x -> R x (* side-condition *)
goal G5 : (exists x. P x /\ Q x /\ R x) -> A (* side-condition *) goal G5 : (exists x. P x /\ Q x /\ R x) -> A (* side-condition *)
In natural language, this corresponds to the following proof schema for \verb|A|: In natural language, this corresponds to the following proof schema
There exists a \verb|x| for which \verb|P| holds. Then, for that witness \verb|Q| and \verb|R| also holds. The last one holds because \verb|T| holds as well. And from those three conditions on \verb|x|, we can deduce \verb|A|. for \verb|A|: There exists a \verb|x| for which \verb|P| holds. Then,
\paragraph{Labels controlling the transformation} \paragraph{Labels controlling the transformation}
The transformations in the split family can be finely controlled by using The transformations in the split family can be controlled by using
labels on formula. labels on formulas.
The label \verb|"stop_split"| can be used to block the splitting of a formula. The label \verb|"stop_split"| can be used to block the splitting of a
The label is removed after blocking, so applying the transformation a second formula. The label is removed after blocking, so applying the
time will split the formula. This is can be used to decompose the splitting process in blocks. Also, if a formula with this label is found in non-goal position, transformation a second time will split the formula. This is can be
its \texttt{by}/\texttt{so} proof indication will be erased by the used to decompose the splitting process in several steps. Also, if a
transformation. In a sense, formula tagged by \verb|"stop_split"| are handled formula with this label is found in non-goal position, its
as if they were local lemmas. \texttt{by}/\texttt{so} proof indication will be erased by the
transformation. In a sense, formulas tagged by \verb|"stop_split"| are
handled as if they were local lemmas.
The label \verb|"case_split"| can be used to force case analysis on hypotheses. The label \verb|"case_split"| can be used to force case analysis on hypotheses.
For instance, applying \texttt{split\_goal} on For instance, applying \texttt{split\_goal} on
...@@ -595,4 +609,3 @@ and is likely to change in future versions. ...@@ -595,4 +609,3 @@ and is likely to change in future versions.
%%% TeX-PDF-mode: t %%% TeX-PDF-mode: t
%%% TeX-master: "manual" %%% TeX-master: "manual"
%%% End: %%% End:
