Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit 34aea94e authored by MARCHE Claude's avatar MARCHE Claude
rename split_intros_goal_wp into split_vc
parent 7adf6371
......@@ -328,7 +328,7 @@ let generate_auto_strategies config =
if b then eprintf " Prover %a will be used in Auto level >= %d@."
Whyconf.print_prover p lev) prover_auto_levels;
(* Split VCs *)
let code = "t split_intros_goal_wp exit" in
let code = "t split_vc exit" in
let split = {
strategy_name = "Split_VC";
strategy_desc = "Split@ the@ VC@ into@ subgoals";
......@@ -105,23 +105,9 @@ let () = Trans.register_transform
let simplify_intros =
Trans.compose Simplify_formula.simplify_trivial_wp_quantification introduce_premises
let split_intros_goal_wp =
let split_vc =
Trans.compose_l Split_goal.split_goal_right (Trans.singleton simplify_intros)
let split_intros_all_wp =
Trans.compose_l Split_goal.split_all_right (Trans.singleton simplify_intros)
let split_intros_premise_wp =
Trans.compose Split_goal.split_premise_right simplify_intros
let () = Trans.register_transform_l
"split_intros_goal_wp" split_intros_goal_wp
"split_vcp" split_vc
~desc:"The@ recommended@ splitting@ transformation@ to@ apply@ on@ VCs@ generated@ by@ WP@ (split_goal_right@ followed@ by@ simplify_trivial_quantifications@ followed@ by@ introduce_premises)."
"split_intros_all_wp" split_intros_all_wp
~desc:"Same@ as@ split_intros_goal_wp,@ but@ also@ split@ premises."
"split_intros_premise_wp" split_intros_premise_wp
~desc:"Same@ as@ split_intros_all_wp,@ but@ split@ only@ premises."
......@@ -56,7 +56,7 @@ let alt_ergo_driver : Driver.driver =
let () = log_time ("Initialising why3 worker: end ")
let split_trans = Trans.lookup_transform_l "split_intros_goal_wp" env
let split_trans = Trans.lookup_transform_l "split_vc" env
(* CF gmain.ml ligne 568 et suivante *)
module W =
