Commit 33918667 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Fix testsuite breakage due to floating-point theories for Coq and Gappa provers.
parent 20f53fc1
......@@ -187,7 +187,7 @@ theory floating_point.Rounding
syntax function ToZero "zr"
syntax function Up "up"
syntax function Down "dn"
syntax function NearTiesToAway "na"
syntax function NearestTiesToAway "na"
......@@ -6,11 +6,18 @@ Require Import Rbasic_fun.
Require Import R_sqrt.
Require Import Rtrigo.
Require Import AltSeries. (* for def of pi *)
Require int.Int.
Require real.Real.
Require real.Abs.
Require real.FromInt.
Require real.Square.
Require floating_point.Rounding.
Require floating_point.Single.
Definition unit := unit.
Parameter mark : Type.
Parameter qtmark : Type.
Parameter at1: forall (a:Type), a -> mark -> a.
Parameter at1: forall (a:Type), a -> qtmark -> a.
Implicit Arguments at1.
......@@ -18,46 +25,15 @@ Parameter old: forall (a:Type), a -> a.
Implicit Arguments old.
Axiom assoc_mul_div : forall (x:R) (y:R) (z:R), (~ (z = (0)%R)) ->
((Rdiv (x * y)%R z)%R = (x * (Rdiv y z)%R)%R).
Axiom assoc_div_mul : forall (x:R) (y:R) (z:R), ((~ (y = (0)%R)) /\
~ (z = (0)%R)) -> ((Rdiv (Rdiv x y)%R z)%R = (Rdiv x (y * z)%R)%R).
Axiom assoc_div_div : forall (x:R) (y:R) (z:R), ((~ (y = (0)%R)) /\
~ (z = (0)%R)) -> ((Rdiv x (Rdiv y z)%R)%R = (Rdiv (x * z)%R y)%R).
Axiom Abs_le : forall (x:R) (y:R), ((Rabs x) <= y)%R <-> (((-y)%R <= x)%R /\
(x <= y)%R).
Axiom Sqrt_positive : forall (x:R), ((0)%R <= x)%R -> ((0)%R <= (sqrt x))%R.
Axiom Sqrt_square : forall (x:R), ((0)%R <= x)%R -> ((Rsqr (sqrt x)) = x).
Axiom Square_sqrt : forall (x:R), ((0)%R <= x)%R -> ((sqrt (x * x)%R) = x).
Axiom Pythagorean_identity : forall (x:R),
(((Rsqr (Rtrigo_def.cos x)) + (Rsqr (Rtrigo_def.sin x)))%R = (1)%R).
Axiom Cos_le_one : forall (x:R), ((Rabs (Rtrigo_def.cos x)) <= (1)%R)%R.
Axiom Sin_le_one : forall (x:R), ((Rabs (Rtrigo_def.sin x)) <= (1)%R)%R.
Axiom Cos_0 : ((Rtrigo_def.cos (0)%R) = (1)%R).
Axiom Sin_0 : ((Rtrigo_def.sin (0)%R) = (0)%R).
Definition implb(x:bool) (y:bool): bool := match (x,
y) with
| (true, false) => false
| (_, _) => true
end.
Axiom Pi_interval : ((314159265358979323846264338327950288419716939937510582097494459230781640628620899862803482534211706798214808651328230664709384460955058223172535940812848111745028410270193852110555964462294895493038196 / 100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000)%R < PI)%R /\
(PI < (314159265358979323846264338327950288419716939937510582097494459230781640628620899862803482534211706798214808651328230664709384460955058223172535940812848111745028410270193852110555964462294895493038197 / 100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000)%R)%R.
Axiom Cos_pi : ((Rtrigo_def.cos PI) = (-(1)%R)%R).
Axiom Sin_pi : ((Rtrigo_def.sin PI) = (0)%R).
Axiom Cos_pi2 : ((Rtrigo_def.cos ((05 / 10)%R * PI)%R) = (0)%R).
Axiom Sin_pi2 : ((Rtrigo_def.sin ((05 / 10)%R * PI)%R) = (1)%R).
Axiom Cos_plus_pi : forall (x:R),
((Rtrigo_def.cos (x + PI)%R) = (-(Rtrigo_def.cos x))%R).
......@@ -86,82 +62,18 @@ Parameter atan: R -> R.
Axiom Tan_atan : forall (x:R), ((Rtrigo.tan (atan x)) = x).
Inductive mode :=
| NearestTiesToEven : mode
| ToZero : mode
| Up : mode
| Down : mode
| NearTiesToAway : mode .
Parameter single : Type.
Axiom Zero : ((IZR 0%Z) = (0)%R).
Axiom One : ((IZR 1%Z) = (1)%R).
Axiom Add : forall (x:Z) (y:Z), ((IZR (x + y)%Z) = ((IZR x) + (IZR y))%R).
Axiom Sub : forall (x:Z) (y:Z), ((IZR (x - y)%Z) = ((IZR x) - (IZR y))%R).
Axiom Mul : forall (x:Z) (y:Z), ((IZR (x * y)%Z) = ((IZR x) * (IZR y))%R).
Axiom Neg : forall (x:Z), ((IZR (-x)%Z) = (-(IZR x))%R).
Parameter round: mode -> R -> R.
Parameter round_logic: mode -> R -> single.
Parameter value: single -> R.
Parameter exact: single -> R.
Parameter model: single -> R.
Definition round_error(x:single): R := (Rabs ((value x) - (exact x))%R).
Definition total_error(x:single): R := (Rabs ((value x) - (model x))%R).
Definition no_overflow(m:mode) (x:R): Prop := ((Rabs (round m
x)) <= (33554430 * 10141204801825835211973625643008)%R)%R.
Axiom Bounded_real_no_overflow : forall (m:mode) (x:R),
((Rabs x) <= (33554430 * 10141204801825835211973625643008)%R)%R ->
(no_overflow m x).
Axiom Round_monotonic : forall (m:mode) (x:R) (y:R), (x <= y)%R -> ((round m
x) <= (round m y))%R.
Axiom Exact_rounding_for_integers : forall (m:mode) (i:Z),
(((-16777216%Z)%Z <= i)%Z /\ (i <= 16777216%Z)%Z) -> ((round m
(IZR i)) = (IZR i)).
Axiom Round_down_le : forall (x:R), ((round (Down ) x) <= x)%R.
Axiom Round_up_ge : forall (x:R), (x <= (round (Up ) x))%R.
Axiom Round_down_neg : forall (x:R), ((round (Down ) (-x)%R) = (-(round (Up )
x))%R).
Axiom Round_up_neg : forall (x:R), ((round (Up ) (-x)%R) = (-(round (Down )
x))%R).
(* YOU MAY EDIT THE CONTEXT BELOW *)
Require Import Interval_tactic.
(* DO NOT EDIT BELOW *)
Theorem WP_parameter_my_cosine : forall (x:single),
((Rabs (value x)) <= (1 / 32)%R)%R ->
((Rabs (((1)%R - (((value x) * (value x))%R * (05 / 10)%R)%R)%R - (Rtrigo_def.cos (value x)))%R) <= (1 / 16777216)%R)%R.
Theorem WP_parameter_my_cosine : forall (x:floating_point.Single.single),
((Rabs (floating_point.Single.value x)) <= (1 / 32)%R)%R ->
((Rabs ((1%R - (((floating_point.Single.value x) * (floating_point.Single.value x))%R * (05 / 10)%R)%R)%R - (Rtrigo_def.cos (floating_point.Single.value x)))%R) <= (1 / 16777216)%R)%R.
(* YOU MAY EDIT THE PROOF BELOW *)
intros x H.
interval with (i_bisect_diff (value x)).
interval with (i_bisect_diff (Single.value x)).
Qed.
