Commit 33424746 authored by Andrei Paskevich's avatar Andrei Paskevich
Tptp_printer: restore memoization
parent 9d9770f8
...@@ -263,28 +263,30 @@ let print_decl info fmt d = match d.d_node with ...@@ -263,28 +263,30 @@ let print_decl info fmt d = match d.d_node with
head print_pr pr (print_fmla info) f head print_pr pr (print_fmla info) f
| Dprop ((Plemma|Pskip), _, _) -> assert false | Dprop ((Plemma|Pskip), _, _) -> assert false
let print_decls fm nm rew_rules = let print_decls fm nm =
Format.eprintf "rewrite rules:"; Format.eprintf "rewrite rules:";
Spr.iter (fun pr -> Format.eprintf " %s" pr.pr_name.id_string) rew_rules; Spr.iter (fun pr -> Format.eprintf " %s" pr.pr_name.id_string) rew_rules;
Format.eprintf "@."; Format.eprintf "@.";
let print_decl (sm,fm,ct) fmt d = let print_decl (sm,fm,rr,ct) fmt d =
let info = { info_syn = sm; let info = { info_syn = sm;
info_fmt = fm; info_fmt = fm;
info_num = nm; info_num = nm;
info_srt = ref ct; info_srt = ref ct;
info_urg = ref []; info_urg = ref [];
info_rules = rew_rules } in info_rules = rr } in
try print_decl info fmt d; try print_decl info fmt d;
(sm,fm,!(info.info_srt)), !(info.info_urg) (sm,fm,rr,!(info.info_srt)), !(info.info_urg)
with Unsupported s -> raise (UnsupportedDecl (d,s)) in with Unsupported s -> raise (UnsupportedDecl (d,s)) in
let print_decl = Printer.sprint_decl print_decl in let print_decl = Printer.sprint_decl print_decl in
let print_decl task acc = print_decl task.Task.task_decl acc in let print_decl task acc = print_decl task.Task.task_decl acc in
Discriminate.on_syntax_map (fun sm -> Discriminate.on_syntax_map (fun sm ->
Trans.fold print_decl ((sm,fm,Mty.empty),[])) Trans.on_tagged_pr Compute.meta_rewrite (fun rr ->
Trans.fold print_decl ((sm,fm,rr,Mty.empty),[])))
let print_task fm nm = let print_task fm nm =
let print_decls = print_decls fm nm in
fun args ?old:_ fmt task -> fun args ?old:_ fmt task ->
(* In trans-based p-printing [forget_all] is a no-no *) (* In trans-based p-printing [forget_all] is a no-no *)
(* forget_all ident_printer; *) (* forget_all ident_printer; *)
...@@ -293,10 +295,7 @@ let print_task fm nm = ...@@ -293,10 +295,7 @@ let print_task fm nm =
let rec print = function let rec print = function
| x :: r -> print r; Pp.string fmt x | x :: r -> print r; Pp.string fmt x
| [] -> () in | [] -> () in
let print_decls_with_meta = print (snd (Trans.apply print_decls task));
Trans.on_tagged_pr Compute.meta_rewrite (print_decls fm nm)
in
print (snd (Trans.apply print_decls_with_meta task));
pp_print_flush fmt () pp_print_flush fmt ()
let () = let () =
