Commit 3264cee2 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Remove extraneous boxing in Coq printer.
parent 01fc55d2
......@@ -262,7 +262,7 @@ and print_tnode opl opr info fmt t = match t.t_node with
Number.print number_format fmt c
| Tlet (t1,tb) ->
let v,t2 = t_open_bound tb in
fprintf fmt (protect_on opr "@[<hov>let %a :=@[<hov 1>@ %a@] in@ %a@]")
fprintf fmt (protect_on opr "@[<hov>let %a :=@ %a in@ %a@]")
print_vs v (print_term info) t1 (print_opl_term info) t2;
forget_var v
| Tcase (t,bl) ->
......@@ -289,7 +289,7 @@ and print_tnode opl opr info fmt t = match t.t_node with
| Tapp (fs,pl) when is_fs_tuple fs ->
fprintf fmt "%a" (print_paren_r (print_term info)) pl
| Tapp (fs,[l;r]) when ls_equal fs fs_func_app ->
fprintf fmt "(%a@ %a)" (print_opr_term info) l (print_opr_term info) r
fprintf fmt "@[<hov 1>(%a@ %a)@]" (print_opr_term info) l (print_opr_term info) r
| Tapp (fs, tl) ->
begin match query_syntax info.info_syn fs.ls_name with
| Some s ->
......@@ -306,7 +306,7 @@ and print_tnode opl opr info fmt t = match t.t_node with
| Tquant (Tforall,fq) ->
let vl,_tl,f = t_open_quant fq in
fprintf fmt (protect_on opr "@[<hov>forall @[<hov>%a@],@ @[<hov>%a@]@]")
fprintf fmt (protect_on opr "@[<hov>forall @[<hov>%a@],@ %a@]")
(print_list space (print_vsty info)) vl
(* (print_tl info) tl *) (print_term info) f;
List.iter forget_var vl
......@@ -316,7 +316,7 @@ and print_tnode opl opr info fmt t = match t.t_node with
match vl with
| [] -> print_term info fmt f
| v::vr ->
fprintf fmt (protect_on opr "@[<hov>exists @[<hov>%a@],@ @[<hov>%a@]@]")
fprintf fmt (protect_on opr "@[<hov>exists %a,@ %a@]")
(print_vsty_nopar info) v
aux vr
in
......@@ -338,7 +338,7 @@ and print_tnode opl opr info fmt t = match t.t_node with
fprintf fmt (protect_on opr "@[<hov>~ %a@]") (print_opl_term info) f
| Tif (f1,f2,f3) ->
"@[<hov>if @[<hov>%a@] then@ @[<hov>%a@]@ else@ @[<hov>%a@]@]")
"@[<hov>if %a then@ %a@ else@ %a@]")
(print_term info) f1 (print_term info) f2 (print_opl_term info) f3
and print_tbranch info fmt br =
