GitLab
What's new
10
Support
Community forum
Keyboard shortcuts
Why3
why3
30b2bf6b
30b2bf6b
Jean-Christophe Filliâtre
programs: a better pretty-printer, for debugging purposes
af319f50
7
7 changed files
72 additions
29 deletions
+72
-29
Makefile.in
Makefile.in
+1
-1
src/programs/pgm_ttree.ml
+2
-2
src/programs/pgm_types.ml
+13
-4
src/programs/pgm_types.mli
+1
src/programs/pgm_typing.ml
+44
-20
src/programs/pgm_typing.mli
+0
-2
tests/test-pgm-jcf.mlw
+11
Makefile.in
30b2bf6b
@@ -737,7 +737,7 @@ testl: bin/whyml.byte
ocamlrun
-bt
bin/whyml.byte
-P
alt-ergo tests/test-pgm-jcf.mlw
testl-debug
bin/whyml.byte
ocamlrun
-bt
bin/whyml.byte
--debug-all
ocamlrun
-bt
bin/whyml.byte
--debug-all
--debug
program_typing
testl-ide
bin/whyide.opt
bin/whyide.opt tests/test-pgm-jcf.mlw
30b2bf6b
@@ -169,7 +169,7 @@ type label = Term.vsymbol
type
irec_variant
ivsymbol
Term
term
Term
lsymbol
option
type
ipattern
ipat_pat
Term
pattern
ipat_pat
Term
pattern
(* program variables *)
ipat_node
ipat_node
@@ -227,7 +227,7 @@ type post = T.post
type
rec_variant
pvsymbol
Term
term
Term
lsymbol
option
type
pattern
ppat_pat
Term
pattern
ppat_pat
Term
pattern
(* logic variables *)
ppat_node
ppat_node
30b2bf6b
@@ -151,6 +151,7 @@ module rec T : sig
val
print_type_v
Format
formatter
type_v
unit
val
print_type_c
Format
formatter
type_c
unit
val
print_pre
Format
formatter
pre
unit
val
print_post
Format
formatter
post
unit
struct
@@ -371,11 +372,19 @@ end = struct
open
Format
open
Pretty
let
print_post
fmt
_
q
el
let
print_exn_post
fmt
l
_
q
fprintf
fmt
"| %a -> {%a}"
print_ls
l
print_fmla
q
let
print_pre
fmt
f
fprintf
fmt
"@[{ %a }@]"
Pretty
print_fmla
f
print_post
fmt
v
q
_
fprintf
fmt
"@[{%a | %a}@]"
Pretty
print_vs
v
Pretty
print_fmla
q
let
print_post
fmt
v
q
el
let
print_exn_post
fmt
l
v
q
fprintf
fmt
"@[<hov 2>| %a %a->@ {%a}@]"
print_ls
l
print_option
print_vs
v
print_fmla
q
in
fprintf
fmt
"{%a} %a"
print_fmla
q
print_list
space
print_exn_post
el
fprintf
fmt
"@[{%a | %a}@ %a@]"
print_vs
v
print_fmla
q
print_list
space
print_exn_post
el
let
rec
print_type_v
fmt
function
Tpure
ty
30b2bf6b
@@ -111,6 +111,7 @@ module rec T : sig
val
print_type_v
Format
formatter
type_v
unit
val
print_type_c
Format
formatter
type_c
unit
val
print_pre
Format
formatter
pre
unit
val
print_post
Format
formatter
post
unit
30b2bf6b
@@ -1474,15 +1474,16 @@ and fresh_triple gl (_, e, _) =
let
rec
print_expr
fmt
e
match
e
expr_desc
Elogic
t
print_term
fmt
t
Elocal
v
s
fprintf
fmt
<local
%a
print_
vs
vs
pv_vs
f
print
f
fmt
"@[<hov 2><term: %a>@]"
Pretty
print
_term
t
Elocal
v
fprintf
fmt
"%a"
print_
pv
v
Eglobal
ls
fprintf
fmt
"<global %a>"
print_ls
ls
p_ls
Efun
_
t
fprintf
fmt
"@[fun _ ->@ %a@]"
print_triple
t
Efun
bl
t
fprintf
fmt
"@[fun %a ->@ %a@]"
print_list
space
print_pv
bl
print_triple
t
Elet
v
e1
e2
fprintf
fmt
"@[let %a = %a in@ %a@]"
print_vs
v
pv_vs
fprintf
fmt
<hv 0>@[<hov 2>
let %a =
%a in@
%a@]"
print_vs
v
pv_vs
print_expr
e1
print_expr
e2
Eif
e1
e2
e3
@@ -1492,20 +1493,42 @@ let rec print_expr fmt e = match e.expr_desc with
Eany
c
fprintf
fmt
"@[[any %a]@]"
print_type_c
c
_
fprintf
fmt
"<other>"
Elabel
_
_
fprintf
fmt
"<todo: Elabel>"
Eassert
_
_
fprintf
fmt
"<todo: Eassert>"
Efor
_
_
_
_
_
_
fprintf
fmt
"<todo: Efor>"
Etry
_
_
fprintf
fmt
"<todo: Etry>"
Eraise
_
_
fprintf
fmt
"<todo: Eraise>"
Ematch
v
cl
fprintf
fmt
"@[<hov 2>match %a with@ %a@]"
print_pv
v
print_list
newline
print_branch
cl
Eloop
_
_
fprintf
fmt
"<todo: Eloop>"
Eletrec
_
_
fprintf
fmt
"<todo: Eletrec>"
Eabsurd
fprintf
fmt
"absurd"
print_pv
fmt
v
fprintf
fmt
"<%s : %a/%a>"
v
pv_name
id_string
print_ty
v
pv_ty
print_vs
v
pv_vs
print_triple
fmt
p
e
q
fprintf
fmt
%a
@ %a@
%a
print_pre
p
print_expr
e
print_post
q
fprintf
fmt
<hv 0>
%a@ %a@ %a@]"
T
print_pre
p
print_expr
e
T
print_post
q
print_pre
fmt
_
fprintf
fmt
"<pre>"
print_recfun
fmt
v
bl
_
t
fprintf
fmt
"@[<hov 2>rec %a@ %a =@ %a@]"
print_pv
v
print_list
space
print_pv
bl
print_triple
t
print_
post
fmt
_
fprintf
fmt
<post>"
print_
branch
fmt
p
e
fprintf
fmt
@[<hov 4>| %a ->@ %a@]"
print_pattern
p
print_expr
e
print_
recfun
fmt
v
_bl
_
t
fprintf
fmt
"@[rec %a _ = %a@]"
print_vs
v
print_triple
t
print_
pattern
fmt
p
Pretty
print_pat
fmt
p
ppat_pa
t
(* typing declarations (combines the three phases together) *)
@@ -1602,8 +1625,9 @@ let rec decl ~wp env penv lmod uc = function
Pgm_module
add_logic_pdecl
env
d
uc
Ptree
Dlet
id
e
let
e
type_expr
uc
e
in
Debug
dprintf
debug
"@[--typing %s-----@
\n
%a@
\n
%a@]@."
id
id
print_expr
e
print_type_v
e
expr_type_v
if
Debug
test_flag
debug
then
eprintf
\n
%a@
\n
%a@]@."
id
id
print_expr
e
print_type_v
e
expr_type_v
let
ls
uc
add_global
id
id_loc
id
id
e
expr_type_v
uc
in
let
d
Dlet
ls
e
in
let
uc
add_decl
d
uc
in
@@ -1617,9 +1641,9 @@ let rec decl ~wp env penv lmod uc = function
let
tyv
v
pv_tv
in
let
loc
loc_of_id
v
pv_name
in
let
id
v
pv_name
id_string
in
if Debug.test_flag debug then
eprintf "@[--typing %s-----@\n %a@.%a@]@."
id print_recfun d print_type_v tyv;
if
Debug
test_flag
debug
then
eprintf
\n
%a@.%a@]@."
id
print_recfun
d
print_type_v
tyv
let
ps
uc
add_global
loc
id
tyv
uc
in
uc
ps
d
in
30b2bf6b
@@ -26,5 +26,3 @@ val decl :
wp
bool
Env
env
Pgm_env
t
Pgm_module
t
Pgm_module
Mnm
t
Pgm_module
uc
Ptree
program_decl
Pgm_module
uc
val
print_post
Format
formatter
Pgm_ttree
post
unit
30b2bf6b
@@ -4,6 +4,17 @@ module P
use import int.Int
use import module stdlib.Ref
use import list.List
use import list.Length
let rec length_ (l : list 'a) variant { length l } =
match l with
| Nil -> 0
| Cons _ r -> 1 + length_ r
{ result = length l }
(* parameter b : ref int *)
(* let f () = *)
