Commit 2eb4ca28 authored by Léon Gondelman's avatar Léon Gondelman
Fixed and proved theory list
parent 1975bbfd
......@@ -41,7 +41,7 @@
</transf>
</goal>
</theory>
<theory name="IntListCursor" sum="6a86c159c9325e79070f5efce8debf6a">
<theory name="IntListCursor" sum="3be4879452794a876cc462ddd755a3de">
<goal name="WP_parameter create" expl="VC for create">
<proof prover="1"><result status="valid" time="0.02"/></proof>
</goal>
......@@ -52,7 +52,7 @@
</goal>
</theory>
<theory name="TestListCursor" sum="650f68ba6185c1da3bf7ea3cb4c3d7e3">
<theory name="TestListCursor" sum="c8893f4016f1f1e3c221e4142f94eed3">
<goal name="WP_parameter list_sum" expl="VC for list_sum">
<transf name="split_goal_wp">
<goal name="WP_parameter list_sum.1" expl="1. loop invariant init">
......@@ -85,7 +85,7 @@
</transf>
</goal>
</theory>
<theory name="IntArrayCursor" sum="5e45c85fd72714bc8c3150cb7084a6c1" expanded="true">
<theory name="IntArrayCursor" sum="c77cddb83b83b50f0453ae017ebaaabf" expanded="true">
<proof prover="1"><result status="valid" time="0.01"/></proof>
</goal>
......@@ -126,7 +126,7 @@
</transf>
</goal>
</theory>
<theory name="TestArrayCursor" sum="6c32bfa8b7b8e063fd2046eb493d82bf">
<theory name="TestArrayCursor" sum="1818e28aa2ccadd10a21d99b8b296439">
<goal name="WP_parameter array_sum_array_to_list" expl="VC for array_sum_array_to_list">
<proof prover="1"><result status="valid" time="0.04"/></proof>
</goal>
......@@ -7,7 +7,9 @@ module InsertionSort
predicate le elt elt
clone relations.TotalPreOrder with type t = elt, predicate rel = le
clone export list.Sorted with type t = elt, predicate le = le
clone export list.Sorted with type t = elt, predicate le = le,
goal Transitive.Trans
use import list.List
use import list.Permut
......@@ -5,7 +5,10 @@
<prover id="0" name="Alt-Ergo" version="0.95.2" timelimit="10" memlimit="1000"/>
<prover id="1" name="CVC4" version="1.3" timelimit="10" memlimit="1000"/>
<file name="../insertion_sort_list.mlw" expanded="true">
<theory name="InsertionSort" sum="a68ab62da2fba48733e0e9f8699021f8" expanded="true">
<theory name="InsertionSort" sum="18eee291d33ec7eb040007ff367abb3c" expanded="true">
<goal name="Transitive.Trans" expanded="true">
<proof prover="0" timelimit="5"><result status="valid" time="0.01"/></proof>
</goal>
<goal name="WP_parameter insert" expl="VC for insert" expanded="true">
<transf name="split_goal_wp" expanded="true">
<goal name="WP_parameter insert.1" expl="1. postcondition">
......@@ -27,10 +30,10 @@
<proof prover="0"><result status="valid" time="0.03"/></proof>
</goal>
<goal name="WP_parameter insert.7" expl="7. postcondition">
<proof prover="0"><result status="valid" time="0.50"/></proof>
<proof prover="0"><result status="valid" time="0.58"/></proof>
</goal>
<goal name="WP_parameter insert.8" expl="8. postcondition" expanded="true">
<proof prover="1"><result status="valid" time="0.20"/></proof>
<proof prover="1"><result status="valid" time="0.42"/></proof>
</goal>
</transf>
</goal>
......@@ -4,30 +4,26 @@
<why3session shape_version="4">
<prover id="0" name="Coq" version="8.4pl4" timelimit="5" memlimit="0"/>
<prover id="1" name="CVC3" version="2.4.1" timelimit="5" memlimit="4000"/>
<prover id="2" name="Alt-Ergo" version="0.95.1" timelimit="5" memlimit="0"/>
<prover id="3" name="Z3" version="2.19" timelimit="5" memlimit="0"/>
<prover id="4" name="CVC3" version="2.2" timelimit="5" memlimit="0"/>
<prover id="5" name="Z3" version="3.2" timelimit="5" memlimit="4000"/>
<prover id="6" name="Alt-Ergo" version="0.95.2" timelimit="5" memlimit="4000"/>
<prover id="7" name="CVC4" version="1.3" timelimit="5" memlimit="4000"/>
<prover id="2" name="Alt-Ergo" version="0.95.2" timelimit="5" memlimit="4000"/>
<prover id="3" name="CVC4" version="1.3" timelimit="5" memlimit="4000"/>
<file name="../linked_list_rev.mlw" expanded="true">
<theory name="ListReverse" sum="d41d8cd98f00b204e9800998ecf8427e" expanded="true">
</theory>
<theory name="InPlaceRev" sum="3c1c96a3f0506ade10b9b7f2051e8742" expanded="true">
<theory name="InPlaceRev" sum="fd2061728df4ef10ceafdbfcc7847ac8" expanded="true">
<goal name="list_seg_frame" expanded="true">
<proof prover="0" edited="linked_list_rev_WP_InPlaceRev_list_seg_frame_1.v"><result status="valid" time="1.13"/></proof>
<proof prover="0" edited="linked_list_rev_WP_InPlaceRev_list_seg_frame_1.v" obsolete="true"><result status="valid" time="1.13"/></proof>
</goal>
<goal name="list_seg_functional" expanded="true">
<proof prover="0" edited="linked_list_rev_WP_InPlaceRev_list_seg_functional_1.v"><result status="valid" time="1.08"/></proof>
<proof prover="0" edited="linked_list_rev_WP_InPlaceRev_list_seg_functional_1.v" obsolete="true"><result status="valid" time="1.08"/></proof>
</goal>
<goal name="list_seg_sublistl" expanded="true">
<proof prover="0" edited="linked_list_rev_WP_InPlaceRev_list_seg_sublistl_1.v"><result status="valid" time="1.05"/></proof>
<proof prover="0" edited="linked_list_rev_WP_InPlaceRev_list_seg_sublistl_1.v" obsolete="true"><result status="valid" time="1.05"/></proof>
</goal>
<goal name="list_seg_no_repet" expanded="true">
<proof prover="0" edited="linked_list_rev_WP_InPlaceRev_list_seg_no_repet_1.v"><result status="valid" time="1.07"/></proof>
<proof prover="0" edited="linked_list_rev_WP_InPlaceRev_list_seg_no_repet_1.v" obsolete="true"><result status="valid" time="1.07"/></proof>
</goal>
<goal name="WP_parameter in_place_reverse" expl="VC for in_place_reverse" expanded="true">
<goal name="WP_parameter in_place_reverse" expl="VC for in_place_reverse">
<goal name="WP_parameter in_place_reverse.1" expl="1. loop invariant init">
<proof prover="2" memlimit="1000"><result status="valid" time="0.02"/></proof>
</goal>
......@@ -39,36 +35,28 @@
</goal>
<goal name="WP_parameter in_place_reverse.4" expl="4. loop invariant init">
<proof prover="1" memlimit="0"><result status="valid" time="0.02"/></proof>
<proof prover="2"><result status="valid" time="0.01"/></proof>
<proof prover="3"><result status="valid" time="0.02"/></proof>
<proof prover="4"><result status="valid" time="0.01"/></proof>
<proof prover="5" memlimit="0"><result status="valid" time="0.02"/></proof>
</goal>
<goal name="WP_parameter in_place_reverse.5" expl="5. assertion">
<proof prover="2"><result status="valid" time="0.20"/></proof>
<proof prover="2" memlimit="1000"><result status="valid" time="0.36"/></proof>
</goal>
<goal name="WP_parameter in_place_reverse.6" expl="6. loop invariant preservation">
<proof prover="2" memlimit="1000"><result status="valid" time="0.19"/></proof>
<proof prover="2" memlimit="1000"><result status="valid" time="0.33"/></proof>
</goal>
<goal name="WP_parameter in_place_reverse.7" expl="7. loop invariant preservation">
<proof prover="2" memlimit="1000"><result status="valid" time="0.09"/></proof>
<proof prover="2" memlimit="1000"><result status="valid" time="0.15"/></proof>
</goal>
<goal name="WP_parameter in_place_reverse.8" expl="8. loop invariant preservation">
<proof prover="1"><result status="valid" time="0.12"/></proof>
<proof prover="5"><result status="valid" time="0.10"/></proof>
<proof prover="7"><result status="valid" time="0.13"/></proof>
<proof prover="3"><result status="valid" time="0.13"/></proof>
</goal>
<goal name="WP_parameter in_place_reverse.9" expl="9. loop invariant preservation">
<proof prover="1" memlimit="1000"><result status="valid" time="0.09"/></proof>
<proof prover="2" memlimit="1000"><result status="valid" time="0.91"/></proof>
</goal>
<goal name="WP_parameter in_place_reverse.10" expl="10. loop variant decrease">
<proof prover="6"><result status="valid" time="0.10"/></proof>
<proof prover="2"><result status="valid" time="0.10"/></proof>
</goal>
<goal name="WP_parameter in_place_reverse.11" expl="11. postcondition">
<proof prover="2"><result status="valid" time="0.22"/></proof>
<proof prover="4"><result status="valid" time="0.02"/></proof>
</goal>
</transf>
</goal>
......@@ -15,7 +15,8 @@ module Elt
type elt
This diff is collapsed.
......@@ -16,7 +16,8 @@ module MergesortQueue
type elt
let merge (q1: t elt) (q2: t elt) (q: t elt)
requires { q.elts = Nil /\ sorted q1.elts /\ sorted q2.elts }
......@@ -2,11 +2,11 @@
<!DOCTYPE why3session PUBLIC "-//Why3//proof session v5//EN"
"http://why3.lri.fr/why3session.dtd">
<prover id="0" name="Alt-Ergo" version="0.95.1" timelimit="20" memlimit="0"/>
<prover id="0" name="Alt-Ergo" version="0.95.2" timelimit="5" memlimit="1000"/>
<file name="../sorted_list.mlw" expanded="true">
<theory name="FindInSortedList" sum="9315da3cc3b88fe0c4ad3f06aad610f4" expanded="true">
<theory name="FindInSortedList" sum="a6b267074f636ad1d1f4475349be62a0" expanded="true">
<goal name="Sorted_not_mem" expanded="true">
<proof prover="0"><result status="valid" time="0.01"/></proof>
</goal>
<goal name="WP_parameter find" expl="VC for find" expanded="true">
<proof prover="0"><result status="valid" time="0.02"/></proof>
(* This file is generated by Why3's Coq driver *)
(* Beware! Only edit allowed sections below *)
Require Import BuiltIn.
Require BuiltIn.
Require int.Int.
(* Why3 assumption *)
Inductive list (a:Type) :=
| Nil : list a
| Cons : a -> (list a) -> list a.
Axiom list_WhyType : forall (a:Type) {a_WT:WhyType a}, WhyType (list a).
Existing Instance list_WhyType.
Implicit Arguments Nil [[a]].
Implicit Arguments Cons [[a]].
Parameter num_occ: forall {a:Type} {a_WT:WhyType a}, a -> (list a) -> Z.
Axiom num_occ_def : forall {a:Type} {a_WT:WhyType a}, forall (x:a) (l:(list
a)),
match l with
| Nil => ((num_occ x l) = 0%Z)
| (Cons y r) => ((x = y) -> ((num_occ x l) = (1%Z + (num_occ x r))%Z)) /\
((~ (x = y)) -> ((num_occ x l) = (0%Z + (num_occ x r))%Z))
end.
Fixpoint mem {a:Type} {a_WT:WhyType a} (x:a) (l:(list a)) {struct l}: Prop :=
match l with
| Nil => False
| (Cons y r) => (x = y) \/ (mem x r)
end.
Axiom Mem_Num_Occ : forall {a:Type} {a_WT:WhyType a}, forall (x:a) (l:(list
a)), (mem x l) <-> (0%Z < (num_occ x l))%Z.
Fixpoint infix_plpl {a:Type} {a_WT:WhyType a} (l1:(list a)) (l2:(list
a)) {struct l1}: (list a) :=
match l1 with
| Nil => l2
| (Cons x1 r1) => (Cons x1 (infix_plpl r1 l2))
end.
Axiom Append_assoc : forall {a:Type} {a_WT:WhyType a}, forall (l1:(list a))
(l2:(list a)) (l3:(list a)), ((infix_plpl l1 (infix_plpl l2
l3)) = (infix_plpl (infix_plpl l1 l2) l3)).
Axiom Append_l_nil : forall {a:Type} {a_WT:WhyType a}, forall (l:(list a)),
((infix_plpl l (Nil : (list a))) = l).
Fixpoint length {a:Type} {a_WT:WhyType a} (l:(list a)) {struct l}: Z :=
match l with
| Nil => 0%Z
| (Cons _ r) => (1%Z + (length r))%Z
end.
Axiom Length_nonnegative : forall {a:Type} {a_WT:WhyType a}, forall (l:(list
a)), (0%Z <= (length l))%Z.
Axiom Length_nil : forall {a:Type} {a_WT:WhyType a}, forall (l:(list a)),
((length l) = 0%Z) <-> (l = (Nil : (list a))).
Axiom Append_length : forall {a:Type} {a_WT:WhyType a}, forall (l1:(list a))
(l2:(list a)), ((length (infix_plpl l1
l2)) = ((length l1) + (length l2))%Z).
Axiom mem_append : forall {a:Type} {a_WT:WhyType a}, forall (x:a) (l1:(list
a)) (l2:(list a)), (mem x (infix_plpl l1 l2)) <-> ((mem x l1) \/ (mem x
l2)).
Axiom mem_decomp : forall {a:Type} {a_WT:WhyType a}, forall (x:a) (l:(list
a)), (mem x l) -> exists l1:(list a), exists l2:(list a),
(l = (infix_plpl l1 (Cons x l2))).
Axiom Append_Num_Occ : forall {a:Type} {a_WT:WhyType a}, forall (x:a)
(l1:(list a)) (l2:(list a)), ((num_occ x (infix_plpl l1 l2)) = ((num_occ x
l1) + (num_occ x l2))%Z).
Fixpoint reverse {a:Type} {a_WT:WhyType a} (l:(list a)) {struct l}: (list
a) :=
match l with
| Nil => (Nil : (list a))
| (Cons x r) => (infix_plpl (reverse r) (Cons x (Nil : (list a))))
end.
Axiom reverse_append : forall {a:Type} {a_WT:WhyType a}, forall (l1:(list a))
(l2:(list a)) (x:a), ((infix_plpl (reverse (Cons x l1))
l2) = (infix_plpl (reverse l1) (Cons x l2))).
Axiom reverse_cons : forall {a:Type} {a_WT:WhyType a}, forall (l:(list a))
(x:a), ((reverse (Cons x l)) = (infix_plpl (reverse l) (Cons x (Nil : (list
a))))).
Axiom cons_reverse : forall {a:Type} {a_WT:WhyType a}, forall (l:(list a))
(x:a), ((Cons x (reverse l)) = (reverse (infix_plpl l (Cons x (Nil : (list
a)))))).
Axiom reverse_reverse : forall {a:Type} {a_WT:WhyType a}, forall (l:(list
a)), ((reverse (reverse l)) = l).
Axiom reverse_mem : forall {a:Type} {a_WT:WhyType a}, forall (l:(list a))
(x:a), (mem x l) <-> (mem x (reverse l)).
Axiom Reverse_length : forall {a:Type} {a_WT:WhyType a}, forall (l:(list a)),
((length (reverse l)) = (length l)).
Axiom reverse_num_occ : forall {a:Type} {a_WT:WhyType a}, forall (x:a)
(l:(list a)), ((num_occ x l) = (num_occ x (reverse l))).
Definition permut {a:Type} {a_WT:WhyType a} (l1:(list a)) (l2:(list
a)): Prop := forall (x:a), ((num_occ x l1) = (num_occ x l2)).
Axiom Permut_refl : forall {a:Type} {a_WT:WhyType a}, forall (l:(list a)),
(permut l l).
Axiom Permut_sym : forall {a:Type} {a_WT:WhyType a}, forall (l1:(list a))
(l2:(list a)), (permut l1 l2) -> (permut l2 l1).
Axiom Permut_trans : forall {a:Type} {a_WT:WhyType a}, forall (l1:(list a))
(l2:(list a)) (l3:(list a)), (permut l1 l2) -> ((permut l2 l3) -> (permut
l1 l3)).
Axiom Permut_cons : forall {a:Type} {a_WT:WhyType a}, forall (x:a) (l1:(list
a)) (l2:(list a)), (permut l1 l2) -> (permut (Cons x l1) (Cons x l2)).
Axiom Permut_swap : forall {a:Type} {a_WT:WhyType a}, forall (x:a) (y:a)
(l:(list a)), (permut (Cons x (Cons y l)) (Cons y (Cons x l))).
Axiom Permut_cons_append : forall {a:Type} {a_WT:WhyType a}, forall (x:a)
(l1:(list a)) (l2:(list a)), (permut (infix_plpl (Cons x l1) l2)
Axiom Permut_assoc : forall {a:Type} {a_WT:WhyType a}, forall (l1:(list a))
(l2:(list a)) (l3:(list a)), (permut (infix_plpl (infix_plpl l1 l2) l3)
(infix_plpl l1 (infix_plpl l2 l3))).
Axiom Permut_append : forall {a:Type} {a_WT:WhyType a}, forall (l1:(list a))
(l2:(list a)) (k1:(list a)) (k2:(list a)), (permut l1 k1) -> ((permut l2
k2) -> (permut (infix_plpl l1 l2) (infix_plpl k1 k2))).
Axiom Permut_append_swap : forall {a:Type} {a_WT:WhyType a}, forall (l1:(list
a)) (l2:(list a)), (permut (infix_plpl l1 l2) (infix_plpl l2 l1)).
Axiom Permut_mem : forall {a:Type} {a_WT:WhyType a}, forall (x:a) (l1:(list
a)) (l2:(list a)), (permut l1 l2) -> ((mem x l1) -> (mem x l2)).
(* Why3 goal *)
Theorem Permut_length : forall {a:Type} {a_WT:WhyType a}, forall (l1:(list
a)) (l2:(list a)), (permut l1 l2) -> ((length l1) = (length l2)).
intros a a_WT l1 l2 h1.
Qed.
Require BuiltIn.
Require int.Int.
| Nil : list a
a)),
match l with
end.
Axiom Num_Occ_Positive : forall {a:Type} {a_WT:WhyType a}, forall (x:a)
(l:(list a)), (0%Z <= (num_occ x l))%Z.
match l with
| Nil => False
end.
match l1 with
| Nil => l2
end.
match l with
| Nil => 0%Z
end.
l2)).
a) :=
match l with
end.
a))))).
a)))))).
(permut l l).
l1 l3)).
(* Why3 goal *)
Require Import Why3.
Ltac cvc := why3 "CVC4,1.4,".
generalize dependent l2.
induction l1; intros.
destruct l2.
trivial.
cvc.
pose (h2 := h1).
clearbody h2.
specialize (h1 a0).
assert (mem a0 l2) by cvc.
apply mem_decomp in H.
destruct H as [l3 [l4 H]].
assert (permut l1 (infix_plpl l3 l4)).
intro.
cvc.
cvc.
Qed.
......@@ -66,7 +66,8 @@ module Tower_of_Hanoi
use import list.Length
use import list.RevAppend
clone import list.RevSorted with type t = int, predicate le = (<)
clone import list.RevSorted with type t = int, predicate le = (<),
type tower = {
mutable rod : list int;
......@@ -2,33 +2,33 @@
<file name="../vstte10_aqueue.mlw">
<theory name="AmortizedQueue" sum="b357314754b0898c4e610c0bb61806fb">
<goal name="WP_parameter empty" expl="VC for empty">
<file name="../vstte10_aqueue.mlw" expanded="true">
<theory name="AmortizedQueue" sum="60e0a38eed52550859b9a34330155b5a" expanded="true">
<goal name="WP_parameter empty" expl="VC for empty" expanded="true">
</goal>
<goal name="WP_parameter head" expl="VC for head">
<proof prover="0"><result status="valid" time="0.12"/></proof>
<goal name="WP_parameter head" expl="VC for head" expanded="true">
</goal>
