Commit 2cfa1e3d authored by MARCHE Claude's avatar MARCHE Claude
in case of syntax error on reload, do not exit abruptly but displays a message...
in case of syntax error on reload, do not exit abruptly but displays a message and scroll to loc of the error
parent f482a3d6
......@@ -445,8 +445,8 @@ install_local: bin/why3config
ifeq (@enable_ide@,yes)
IDE_FILES = xml session gconfig db gmain
# IDE_FILES = xml session gconfig newmain
# IDE_FILES = xml session gconfig db gmain
IDEMODULES = $(addprefix src/ide/, $(IDE_FILES))
......@@ -508,13 +508,9 @@ let () =
M.maximum_running_proofs := gconfig.max_running_processes;
eprintf " done@."
with e ->
eprintf "Error while opening session with database '%s'@." project_dir;
eprintf "Aborting...@.";
raise e
eprintf "@[Error while opening session:@ %a@.@]"
Exn_printer.exn_printer e;
exit 1
let info_window ?(callback=(fun () -> ())) mt s =
......@@ -1051,18 +1047,20 @@ let color_loc (v:GSourceView2.source_view) l b e =
let stop = start#forward_chars (e-b) in
buf#apply_tag ~start ~stop orange_bg
let scroll_to_loc loc =
let (f,l,b,e) = Loc.get loc in
if f <> !current_file then
begin
source_view#source_buffer#set_text (source_text f);
set_current_file f;
end;
move_to_line source_view (l-1);
erase_color_loc source_view;
color_loc source_view l b e
let scroll_to_id id =
match id.Ident.id_loc with
| Some loc ->
begin
set_current_file f;
end;
| Some loc -> scroll_to_loc loc
| None ->
"Non-localized ident (no position available)\n";
......@@ -1190,6 +1188,24 @@ let () =
b#connect#pressed ~callback:replay_obsolete_proofs
in ()
let reload () =
try
M.reload_all gconfig.provers;
current_file := ""
| Loc.Located(loc,Parsing.Parse_error) ->
fprintf str_formatter
"@[Syntax error:@ %a@]" Loc.gen_report_position loc;
let msg = flush_str_formatter () in
scroll_to_loc loc;
info_window `ERROR msg
| e ->
"@[Error while reading file:@ %a@]" Exn_printer.exn_printer e;
let () =
let b = GButton.button ~packing:tools_box#add ~label:"Reload" () in
b#misc#set_tooltip_markup "Reloads the files";
......@@ -1197,9 +1213,7 @@ let () =
let i = GMisc.image ~pixbuf:(!image_reload) () in
let () = b#set_image i#coerce in
let (_ : GtkSignal.id) =
b#connect#pressed ~callback:(fun () ->
current_file := "";
M.reload_all gconfig.provers)
b#connect#pressed ~callback:reload
in ()
......@@ -862,9 +862,6 @@ let reload_root_goal ~provers mth tname old_goals t : goal =
let id = (Task.task_goal t).Decl.pr_name in
let gname = id.Ident.id_string in
let sum = task_checksum t in
let goal = raw_add_goal (Parent_theory mth) gname expl sum (Some t) in
let old_goal, goal_obsolete =
try
let old_goal = Util.Mstr.find gname old_goals in
......@@ -903,7 +900,8 @@ let reload_theory ~provers mfile old_theories (_,tname,th) =
(* reloads a file *)
let reload_file ~provers mf =
let reload_file ~provers mf theories =
eprintf "[Reload] file '%s'@." mf.file_name;
let theories =
try
......@@ -914,6 +912,7 @@ let reload_file ~provers mf =
(* TODO: do something clever than that! *)
exit 1
in
let new_mf = raw_add_file mf.file_name in
let old_theories = List.fold_left
(fun acc t -> Util.Mstr.add t.theory_name t acc)
......@@ -931,9 +930,15 @@ let reload_file ~provers mf =
(* reloads all files *)
let reload_all provers =
let files = !all_files in
let all_theories =
List.map (fun mf ->
(mf,read_file mf.file_name))
files
in
all_files := [];
O.reset ();
List.iter (reload_file ~provers) files
List.iter (fun (mf,ths) -> reload_file ~provers mf ths) all_theories
(* session opening *)
......@@ -223,8 +223,9 @@ module Make(O: OBSERVER) : sig
val reload_all: prover_data Util.Mstr.t -> unit
(** reloads all the files
If for a given file, the parsing or typing fails, then
then old version is kept, but marked obsolete
If for one of the file, the parsing or typing fails, then
the complete old session state is kept, and an exception
is raised
TODO
......@@ -16,7 +16,7 @@ theory TestInt
use import int.Int
goal Test1: 2+2 = 5
goal Test1: 2+2 =
goal Test2: forall x:int. x*x >= 0
