Commit 2ce79f5a authored by MARCHE Claude's avatar MARCHE Claude
remove temporary shape files created by tutorial example
parent 441471f5
...@@ -1757,7 +1757,7 @@ test-api-mlw.opt: examples/use_api/mlw.ml lib/why3/why3.cmxa ...@@ -1757,7 +1757,7 @@ test-api-mlw.opt: examples/use_api/mlw.ml lib/why3/why3.cmxa
test-session.byte: examples/use_api/create_session.ml lib/why3/why3.cma lib/why3/why3session.cma test-session.byte: examples/use_api/create_session.ml lib/why3/why3.cma lib/why3/why3session.cma
$(if $(QUIET),@echo 'Ocaml $<' &&) \ $(if $(QUIET),@echo 'Ocaml $<' &&) \
ocaml -I lib/why3 $(INCLUDES) $(EXTCMA) lib/why3/why3.cma lib/why3/why3session.cma $< > /dev/null\ ocaml -I lib/why3 $(INCLUDES) $(EXTCMA) lib/why3/why3.cma lib/why3/why3session.cma $< > /dev/null\
|| (rm -f why3session.xml; \ || (rm -f why3session.xml why3shapes.dat why3shapes.gz; \
printf "Test of Why3 API calls for Session module failed. Please fix it"; exit 2) printf "Test of Why3 API calls for Session module failed. Please fix it"; exit 2)
@rm -f why3session.xml @rm -f why3session.xml
...@@ -1765,7 +1765,7 @@ test-session.opt: examples/use_api/create_session.ml lib/why3/why3.cmxa lib/why3 ...@@ -1765,7 +1765,7 @@ test-session.opt: examples/use_api/create_session.ml lib/why3/why3.cmxa lib/why3
$(if $(QUIET),@echo 'Ocamlopt $<' &&) \ $(if $(QUIET),@echo 'Ocamlopt $<' &&) \
($(OCAMLOPT) -o $@ -I lib/why3 $(INCLUDES) $(EXTCMXA) lib/why3/why3.cmxa lib/why3/why3session.cmxa $< \ ($(OCAMLOPT) -o $@ -I lib/why3 $(INCLUDES) $(EXTCMXA) lib/why3/why3.cmxa lib/why3/why3session.cmxa $< \
&& ./test-session.opt > /dev/null) \ && ./test-session.opt > /dev/null) \
|| (rm -f test-session.opt why3session.xml; \ || (rm -f test-session.opt why3session.xml why3shapes.dat why3shapes.gz; \
@rm -f test-session.opt why3session.xml @rm -f test-session.opt why3session.xml
...@@ -37,8 +37,6 @@ export sessions="" ...@@ -37,8 +37,6 @@ export sessions=""
export shapes="" export shapes=""
run_dir () { run_dir () {
sessions="$sessions $1/*/why3session.xml"
shapes="$shapes $1/*/why3shapes.dat"
for f in `ls $1/*/why3session.xml`; do for f in `ls $1/*/why3session.xml`; do
d=`dirname $f` d=`dirname $f`
echo -n "Replaying $d ... " echo -n "Replaying $d ... "
...@@ -61,6 +59,8 @@ run_dir () { ...@@ -61,6 +59,8 @@ run_dir () {
fi fi
total=`expr $total + 1` total=`expr $total + 1`
done done
shapes="$shapes $1/*/why3shapes.*"
echo "=== Standard Library ===" echo "=== Standard Library ==="
Supports Markdown
