GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
2bd9354f
2bd9354f
MARCHE Claude
hopefully final commmit before release 0.73
a8a44982
3
CHANGES
2bd9354f
* marks an incompatible change
o [Provers] support for Z3 4.0
o [Sessions] a small change in the format. Why3 is still able to
read session files in the old format.
o completed support for the "Out Of Memory" prover result
configure.in
2bd9354f
@@ -625,15 +625,15 @@ if test "$enable_coq_support" = "yes" ; then
echo " FP arithmetic : $enable_coq_fp_libs $reason_coq_fp_libs"
fi
fi
fi
fi
echo "PVS support : $enable_pvs_support $reason_pvs_support"
dnl
if test "$enable_pvs_support" = "yes" ; then
dnl
echo " Version : $PVSVERSION"
dnl
echo " Lib : $PVSLIB"
dnl
echo " Realization support : $enable_pvs_libs $reason_pvs_libs"
dnl
if test "$enable_pvs_libs" = "yes" ; then
dnl
echo " FP arithmetic : $enable_pvs_fp_libs $reason_pvs_fp_libs"
dnl
fi
dnl
fi
fi
dnl
fi
echo "hypothesis selection : $enable_hypothesis_selection"
echo "debugging symbols : $enable_debug"
echo "profiling : $enable_profiling"
src/ide/replay.ml
2bd9354f
@@ -225,21 +225,7 @@ end
module
Session_scheduler
Make
O
module
Session_scheduler
Make
O
let
print_result
fmt
let
print_result
Call_provers
print_prover_result
Call_provers
pr_answer
ans
Call_provers
pr_output
out
Call_provers
pr_time
t
fprintf
fmt
"%a (%.1fs)"
Call_provers
print_prover_answer
ans
t
fprintf fmt "%a" Call_provers.print_prover_answer ans;
match
ans
Call_provers
HighFailure
fprintf
fmt
\n
Prover output:@
\n
%s@."
out
_
fprintf fmt "[limit=%s@\nProver output:@\n%s@." out
let
main_loop
O
main_loop
let
main_loop
O
main_loop
Supports
