Commit 2af41451 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Add Coq realization for int.ComputerDivision.
parent 123dcce8
...@@ -839,7 +839,7 @@ endif ...@@ -839,7 +839,7 @@ endif
ifeq (@enable_coq_libs@,yes) ifeq (@enable_coq_libs@,yes)
COQLIBS_INT_FILES = Abs EuclideanDivision Int MinMax COQLIBS_INT_FILES = Abs ComputerDivision EuclideanDivision Int MinMax
COQLIBS_INT = $(addprefix lib/coq/int/, $(COQLIBS_INT_FILES)) COQLIBS_INT = $(addprefix lib/coq/int/, $(COQLIBS_INT_FILES))
COQLIBS_REAL_FILES = Abs FromInt MinMax Real Square COQLIBS_REAL_FILES = Abs FromInt MinMax Real Square
(* This file is generated by Why3's Coq driver *)
(* Beware! Only edit allowed sections below *)
Require Import ZArith.
Require Import Rbase.
Require Import ZOdiv.
(*Add Rec LoadPath "/home/guillaume/bin/why3/share/why3/theories".*)
(*Add Rec LoadPath "/home/guillaume/bin/why3/share/why3/modules".*)
Require int.Int.
Require int.Abs.
Notation div := ZOdiv (only parsing).
Notation mod1 := ZOmod (only parsing).
(* YOU MAY EDIT THE CONTEXT BELOW *)
(* DO NOT EDIT BELOW *)
Lemma Div_mod : forall (x:Z) (y:Z), (~ (y = 0%Z)) -> (x = ((y * (div x
y))%Z + (mod1 x y))%Z).
(* YOU MAY EDIT THE PROOF BELOW *)
intros x y _.
apply ZO_div_mod_eq.
Qed.
Lemma Div_bound : forall (x:Z) (y:Z), ((0%Z <= x)%Z /\ (0%Z < y)%Z) ->
((0%Z <= (div x y))%Z /\ ((div x y) <= x)%Z).
intros x y (Hx,Hy).
split.
apply ZO_div_pos with (1 := Hx).
now apply Zlt_le_weak.
destruct (Z_eq_dec y 1) as [H|H].
rewrite H, ZOdiv_1_r.
apply Zle_refl.
destruct (Zle_lt_or_eq 0 x Hx) as [H'|H'].
apply Zlt_le_weak.
apply ZO_div_lt with (1 := H').
omega.
now rewrite <- H', ZOdiv_0_l.
Qed.
Lemma Mod_bound : forall (x:Z) (y:Z), (~ (y = 0%Z)) ->
(((-(Zabs y))%Z < (mod1 x y))%Z /\ ((mod1 x y) < (Zabs y))%Z).
intros x y Zy.
destruct (Zle_or_lt 0 x) as [Hx|Hx].
refine ((fun H => conj (Zlt_le_trans _ 0 _ _ (proj1 H)) (proj2 H)) _).
clear -Zy ; zify ; omega.
now apply ZOmod_lt_pos.
refine ((fun H => conj (proj1 H) (Zle_lt_trans _ 0 _ (proj2 H) _)) _).
apply ZOmod_lt_neg with (2 := Zy).
Qed.
Lemma Div_sign_pos : forall (x:Z) (y:Z), ((0%Z <= x)%Z /\ (0%Z < y)%Z) ->
(0%Z <= (div x y))%Z.
intros x y (Hx, Hy).
Qed.
Lemma Div_sign_neg : forall (x:Z) (y:Z), ((x <= 0%Z)%Z /\ (0%Z < y)%Z) ->
((div x y) <= 0%Z)%Z.
generalize (ZO_div_pos (-x) y).
rewrite ZOdiv_opp_l.
omega.
Qed.
Lemma Mod_sign_pos : forall (x:Z) (y:Z), ((0%Z <= x)%Z /\ ~ (y = 0%Z)) ->
(0%Z <= (mod1 x y))%Z.
intros x y (Hx, Zy).
Qed.
Lemma Mod_sign_neg : forall (x:Z) (y:Z), ((x <= 0%Z)%Z /\ ~ (y = 0%Z)) ->
((mod1 x y) <= 0%Z)%Z.
now apply ZOmod_lt_neg.
Qed.
Lemma Rounds_toward_zero : forall (x:Z) (y:Z), (~ (y = 0%Z)) ->
((Zabs ((div x y) * y)%Z) <= (Zabs x))%Z.
intros x y Zy.
rewrite Zmult_comm.
zify.
generalize (ZO_mult_div_le x y).
generalize (ZO_mult_div_ge x y).
omega.
Qed.
Lemma Div_1 : forall (x:Z), ((div x 1%Z) = x).
exact ZOdiv_1_r.
Qed.
Lemma Mod_1 : forall (x:Z), ((mod1 x 1%Z) = 0%Z).
exact ZOmod_1_r.
Qed.
Lemma Div_inf : forall (x:Z) (y:Z), ((0%Z <= x)%Z /\ (x < y)%Z) -> ((div x
y) = 0%Z).
exact ZOdiv_small.
Qed.
Lemma Mod_inf : forall (x:Z) (y:Z), ((0%Z <= x)%Z /\ (x < y)%Z) -> ((mod1 x
y) = x).
exact ZOmod_small.
Qed.
Lemma Div_mult : forall (x:Z) (y:Z) (z:Z), ((0%Z < x)%Z /\ ((0%Z <= y)%Z /\
(0%Z <= z)%Z)) -> ((div ((x * y)%Z + z)%Z x) = (y + (div z x))%Z).
intros x y z (Hx&Hy&Hz).
rewrite (Zplus_comm y).
rewrite <- ZO_div_plus.
now rewrite Zplus_comm, Zmult_comm.
apply Zmult_le_0_compat with (2 := Hz).
apply Zplus_le_0_compat with (1 := Hz).
apply Zmult_le_0_compat with (1 := Hy).
intros H.
now rewrite H in Hx.
Qed.
Lemma Mod_mult : forall (x:Z) (y:Z) (z:Z), ((0%Z < x)%Z /\ ((0%Z <= y)%Z /\
(0%Z <= z)%Z)) -> ((mod1 ((x * y)%Z + z)%Z x) = (mod1 z x)).
apply ZO_mod_plus.
Qed.
