Commit 29201f7c authored by François Bobot's avatar François Bobot
Documentation: add description to all the registration functions
 (metas, debug flags, transformations, formats) except for label.
This description is used in --list-*. The description can use any of
the formatting markup of Format "@ " "@[",...
Transformations can also specify from which metas and labels they
depend, and add informations about how they are interpreted.
TODO:
  - complete and correct the documentation
  - when a transformation use Trans.on_meta, it should be possible to
    add an interpretation of the metas in the documentation.
  - recover a summary version of --list-* ?
  - be able to export in latex?
parent 1ff60124
...@@ -98,6 +98,18 @@ valid_goals () { ...@@ -98,6 +98,18 @@ valid_goals () {
done done
list_stuff () {
echo -n "$1 "
if $pgml $1 > /dev/null 2>&1; then
echo "ok"
else
echo "$pgm $1 FAIL"
$pgm $1
exit 1
fi
echo "=== Checking drivers ===" echo "=== Checking drivers ==="
drivers drivers drivers drivers
echo "" echo ""
...@@ -154,3 +166,11 @@ echo "=== Checking valid goals ===" ...@@ -154,3 +166,11 @@ echo "=== Checking valid goals ==="
valid_goals bench/valid valid_goals bench/valid
echo "" echo ""
echo "=== Checking --list-* ==="
list_stuff --list-transforms
list_stuff --list-printers
list_stuff --list-provers
list_stuff --list-formats
list_stuff --list-metas
list_stuff --list-debug-flags
echo ""
...@@ -131,3 +131,9 @@ let read_channel env path filename cin = ...@@ -131,3 +131,9 @@ let read_channel env path filename cin =
(), Mstr.singleton "EqLin" (close_theory th_uc) (), Mstr.singleton "EqLin" (close_theory th_uc)
let library_of_env = Env.register_format "EquLin" ["equlin"] read_channel let library_of_env = Env.register_format "EquLin" ["equlin"] read_channel
~desc:"@[Generate rendomly linear arithmetic problems:@\n \
@[The first line give the seed to use. Each other lines corresond to one goal@\n \
@[- @[the first number give the number of variables@]@\n\
- @[the second the number of equation@]@\n\
- @[the third the absolute maximun of the constants used@]\
...@@ -256,6 +256,7 @@ and comment_line = parse ...@@ -256,6 +256,7 @@ and comment_line = parse
(), Tptp_typing.typecheck env path ast (), Tptp_typing.typecheck env path ast
let library_of_env = Env.register_format "tptp" ["p";"ax"] read_channel let library_of_env = Env.register_format "tptp" ["p";"ax"] read_channel
~desc:"TFF1 TPTP format."
...@@ -235,4 +235,6 @@ let print_task fof _env pr thpr ?old:_ fmt task = ...@@ -235,4 +235,6 @@ let print_task fof _env pr thpr ?old:_ fmt task =
(print_list nothing (print_decl info)) (Task.task_decls task) (print_list nothing (print_decl info)) (Task.task_decls task)
let () = register_printer "tptp-tff" (print_task false) let () = register_printer "tptp-tff" (print_task false)
~desc:"Printer for the TPTP-TFF format."
let () = register_printer "tptp-fof" (print_task true) let () = register_printer "tptp-fof" (print_task true)
~desc:"Printer for the TPTP-FOF format."
...@@ -39,12 +39,12 @@ _why3() ...@@ -39,12 +39,12 @@ _why3()
return 0 return 0
-P|--prover) -P|--prover)
provers=$($1 --list-provers | grep -v '^Known ' | cut -d ' ' -f 3) provers=$($1 --list-provers | grep '^ [^ ]' | cut -d ' ' -f 3)
COMPREPLY=( $( compgen -W "$provers" -- "$cur" ) ) COMPREPLY=( $( compgen -W "$provers" -- "$cur" ) )
return 0 return 0
-F|--format) -F|--format)
formats=$($1 --list-formats | grep -v '^Known ' | cut -d ' ' -f 3) formats=$($1 --list-formats | grep '^ [^ ]' | cut -d ' ' -f 3)
COMPREPLY=( $( compgen -W "$formats" -- "$cur" ) ) COMPREPLY=( $( compgen -W "$formats" -- "$cur" ) )
return 0 return 0
...@@ -52,12 +52,12 @@ _why3() ...@@ -52,12 +52,12 @@ _why3()
return 0 return 0
-a|--apply-transform) -a|--apply-transform)
transforms=$($1 --list-transforms | grep -v '^Known ') transforms=$($1 --list-transforms | grep '^ [^ ]')
COMPREPLY=( $( compgen -W "$transforms" -- "$cur" ) ) COMPREPLY=( $( compgen -W "$transforms" -- "$cur" ) )
return 0 return 0
-M|--meta) -M|--meta)
metas=$($1 --list-metas | grep -v '^Known ' | metas=$($1 --list-metas | grep '^ [^ ]' |
grep -v '\[\(function/predicate\|type\) symbol\]' | grep -v '\[\(function/predicate\|type\) symbol\]' |
grep -v '\[\(type\|proposition\|integer\)\]' | grep -v '\[\(type\|proposition\|integer\)\]' |
grep -v '\] \[' | sed -e 's/(flag) //' | grep -v '\] \[' | sed -e 's/(flag) //' |
...@@ -87,12 +87,12 @@ _why3() ...@@ -87,12 +87,12 @@ _why3()
return 0 return 0
--debug) --debug)
flags=$($1 --list-debug-flags | grep -v '^Known ' | cut -d ' ' -f 3) flags=$($1 --list-debug-flags | grep '^ [^ ]' | cut -d ' ' -f 3)
COMPREPLY=( $( compgen -W "$flags" -- "$cur" ) ) COMPREPLY=( $( compgen -W "$flags" -- "$cur" ) )
return 0 return 0
--filter-prover) --filter-prover)
provers=$(${1/session/} --list-provers | grep -v '^Known ' | cut -d ' ' -f 3) provers=$(${1/session/} --list-provers | grep '^ [^ ]' | cut -d ' ' -f 3)
return 0 return 0
...@@ -84,7 +84,9 @@ type callback = tool_id -> prob_id -> ...@@ -84,7 +84,9 @@ type callback = tool_id -> prob_id ->
task -> int -> proof_attempt_status -> unit task -> int -> proof_attempt_status -> unit
let debug_call = Debug.register_flag "call" let debug_call = Debug.register_flag "call"
~desc:"Show when call to provers are done"
let debug = Debug.register_flag "bench_core" let debug = Debug.register_flag "bench_core"
~desc:"About the scheduling"
module BenchUtil = module BenchUtil =
...@@ -29,6 +29,7 @@ let load_driver = Env.Wenv.memoize 2 (fun env -> ...@@ -29,6 +29,7 @@ let load_driver = Env.Wenv.memoize 2 (fun env ->
memo_string 10 (Driver.load_driver env)) memo_string 10 (Driver.load_driver env))
let debug = Debug.register_flag "benchdb" let debug = Debug.register_flag "benchdb"
~desc:"About the communication from the database"
type path = type path =
| Pgoal of string | Pgoal of string
...@@ -30,9 +30,10 @@ module B = Bench ...@@ -30,9 +30,10 @@ module B = Bench
module C = Call_provers module C = Call_provers
let debug = Debug.register_flag "main" let debug = Debug.register_flag "main"
~desc:"About initialization of the bench"
let usage_msg = sprintf let usage_msg = sprintf
"Usage: %s [options] [[file|-] [-T <theory> [-G <goal>]...]...]... "Usage: %s [options] [[file|-] [-T <theory> [-G <goal>]...]...]...\
[-P <prover> ]..." [-P <prover> ]..."
(Filename.basename Sys.argv.(0)) (Filename.basename Sys.argv.(0))
...@@ -219,52 +220,51 @@ let () = ...@@ -219,52 +220,51 @@ let () =
(** listings*) (** listings*)
let sort_pair (x,_) (y,_) = String.compare x y in
let opt_list = ref false in let opt_list = ref false in
if !opt_version then begin
opt_list := true;
printf "%s@." version_msg
end;
if !opt_list_transforms then begin if !opt_list_transforms then begin
opt_list := true; opt_list := true;
printf "@[<hov 2>Known non-splitting transformations:@\n%a@]@\n@." printf "@[<hov 2>Known non-splitting transformations:@\n%a@]@\n@."
(Pp.print_list Pp.newline Pp.string) (Pp.print_list Pp.newline Trans.print_trans_desc)
(List.sort String.compare (Trans.list_transforms ())); (List.sort sort_pair (Trans.list_transforms ()));
printf "@[<hov 2>Known splitting transformations:@\n%a@]@\n@." printf "@[<hov 2>Known splitting transformations:@\n%a@]@\n@."
(List.sort String.compare (Trans.list_transforms_l ())) (List.sort sort_pair (Trans.list_transforms_l ()))
end; end;
if !opt_list_printers then begin if !opt_list_printers then begin
printf "@[<hov 2>Known printers:@\n%a@]@\n@." printf "@[<hov 2>Known printers:@\n%a@]@\n@."
(Pp.print_list Pp.newline Pp.string) (Pp.print_list Pp.newline Printer.print_printer_desc)
(List.sort String.compare (Printer.list_printers ())) (List.sort sort_pair (Printer.list_printers ()))
end; end;
if !opt_list_formats then begin if !opt_list_formats then begin
let print1 fmt s = fprintf fmt "%S" s in let print1 fmt s = fprintf fmt "%S" s in
let print fmt (p, l) = let print fmt (p, l, f) =
fprintf fmt "%s [%a]" p (Pp.print_list Pp.comma print1) l fprintf fmt "@[%s [%a]@\n @[%a@]@]"
Pp.formatted f
in in
printf "@[<hov 2>Known input formats:@\n%a@]@." printf "@[Known input formats:@\n @[%a@]@]@."
(Pp.print_list Pp.newline print) (Pp.print_list Pp.newline print)
(List.sort Pervasives.compare (Env.list_formats ())) (List.sort Pervasives.compare (Env.list_formats ()))
end; end;
if !opt_list_provers then begin if !opt_list_provers then begin
let config = read_config !opt_config in let config = read_config !opt_config in
let print fmt prover pc = fprintf fmt "%a (%a)@\n" let print = Pp.print_iter2 Mprover.iter Pp.newline Pp.nothing
print_prover_parsable_format pc.prover print_prover prover in print_prover Pp.nothing in
let print fmt m = Mprover.iter (print fmt) m in
let provers = get_provers config in let provers = get_provers config in
printf "@[<hov 2>Known provers:@\n%a@]@." print provers printf "@[<hov 2>Known provers:@\n%a@]@." print provers
end; end;
if !opt_list_metas then begin if !opt_list_metas then begin
let print fmt m = fprintf fmt "@[%s %s%a@]" let print fmt m = fprintf fmt "@[<h 2>%s %s%a@\n@[<hov>%a@]@]"
(let s = m.meta_name in (let s = m.meta_name in
if String.contains s ' ' then "\"" ^ s ^ "\"" else s) if String.contains s ' ' then "\"" ^ s ^ "\"" else s)
(if m.meta_excl then "* " else "") (if m.meta_excl then "(flag) " else "")
(Pp.print_list Pp.space Pretty.print_meta_arg_type) m.meta_type (Pp.print_list Pp.space Pretty.print_meta_arg_type) m.meta_type
Pp.formatted m.meta_desc
in in
let cmp m1 m2 = Pervasives.compare m1.meta_name m2.meta_name in let cmp m1 m2 = Pervasives.compare m1.meta_name m2.meta_name in
printf "@[<hov 2>Known metas:@\n%a@]@\n@." printf "@[<hov 2>Known metas:@\n%a@]@\n@."
...@@ -311,7 +311,7 @@ let () = ...@@ -311,7 +311,7 @@ let () =
&& (not !opt_redo) && (not !opt_redo)
then then
begin begin
eprintf "At least one bench is required or one prover and one file or eprintf "At least one bench is required or one prover and one file or\n\
the verification of a database .@."; the verification of a database .@.";
Arg.usage option_list usage_msg; Arg.usage option_list usage_msg;
exit 1 exit 1
...@@ -24,8 +24,8 @@ open Util ...@@ -24,8 +24,8 @@ open Util
open Whyconf open Whyconf
let usage_msg = let usage_msg =
sprintf "Usage: %s [options]\n sprintf "Usage: %s [options]\n\
Environment variables WHY3LIB, WHY3DATA, and WHY3CONFIG Environment variables WHY3LIB, WHY3DATA, and WHY3CONFIG\n\
can be set to change the default paths.@." can be set to change the default paths.@."
...@@ -64,7 +64,7 @@ let lookup_format name = ...@@ -64,7 +64,7 @@ let lookup_format name =
with Not_found -> raise (UnknownFormat name) with Not_found -> raise (UnknownFormat name)
let list_formats () = let list_formats () =
let add n (_,_,l) acc = (n,l)::acc in let add n (_,_,l,desc) acc = (n,l,desc)::acc in
Hashtbl.fold add read_format_table [] Hashtbl.fold add read_format_table []
let get_extension file = let get_extension file =
...@@ -82,7 +82,7 @@ let read_channel ?format env file ic = ...@@ -82,7 +82,7 @@ let read_channel ?format env file ic =
let name = match format with let name = match format with
| Some name -> name | Some name -> name
| None -> get_format file in | None -> get_format file in
let rc,_,_ = lookup_format name in let rc,_,_,_ = lookup_format name in
rc env file ic rc env file ic
let read_file ?format env file = let read_file ?format env file =
...@@ -94,7 +94,7 @@ let read_file ?format env file = ...@@ -94,7 +94,7 @@ let read_file ?format env file =
with e -> close_in ic; raise e with e -> close_in ic; raise e
let read_theory ~format env path th = let read_theory ~format env path th =
let _,rl,_ = lookup_format format in let _,rl,_,_ = lookup_format format in
rl env path th rl env path th
let find_theory = read_theory ~format:"why" let find_theory = read_theory ~format:"why"
...@@ -180,17 +180,17 @@ let read_lib_theory lib path th = ...@@ -180,17 +180,17 @@ let read_lib_theory lib path th =
try Mstr.find th mth with Not_found -> try Mstr.find th mth with Not_found ->
raise (TheoryNotFound (path,th)) raise (TheoryNotFound (path,th))
let register_format name exts read = let register_format ~(desc:Pp.formatted) name exts read =
if Hashtbl.mem read_format_table name then raise (KnownFormat name); if Hashtbl.mem read_format_table name then raise (KnownFormat name);
let getlib = Wenv.memoize 5 (mk_library read exts) in let getlib = Wenv.memoize 5 (mk_library read exts) in
let rc env file ic = snd (read (getlib env) [] file ic) in let rc env file ic = snd (read (getlib env) [] file ic) in
let rl env path th = read_lib_theory (getlib env) path th in let rl env path th = read_lib_theory (getlib env) path th in
Hashtbl.add read_format_table name (rc,rl,exts); Hashtbl.add read_format_table name (rc,rl,exts,desc);
List.iter (fun s -> Hashtbl.replace extensions_table s name) exts; List.iter (fun s -> Hashtbl.replace extensions_table s name) exts;
getlib getlib
let locate_lib_file env format path = let locate_lib_file env format path =
let _,_,exts = lookup_format format in let _,_,exts,_ = lookup_format format in
locate_lib_file env path exts locate_lib_file env path exts
(* Exception reporting *) (* Exception reporting *)
...@@ -70,7 +70,7 @@ val read_file : ?format:fformat -> env -> filename -> theory Mstr.t ...@@ -70,7 +70,7 @@ val read_file : ?format:fformat -> env -> filename -> theory Mstr.t
val read_theory : format:fformat -> env -> pathname -> string -> theory val read_theory : format:fformat -> env -> pathname -> string -> theory
(** [read_theory ~format env path th] returns the theory [path.th] (** [read_theory ~format env path th] returns the theory [path.th]
from the library. The parameter [format] speicifies the format from the library. The parameter [format] specifies the format
of the library file to look for. of the library file to look for.
@raise UnknownFormat [format] if the format is not registered @raise UnknownFormat [format] if the format is not registered
...@@ -100,6 +100,7 @@ type 'a read_format = ...@@ -100,6 +100,7 @@ type 'a read_format =
(e.g. file name) to be used in error messages. *) (e.g. file name) to be used in error messages. *)
val register_format : val register_format :
desc:Pp.formatted ->
fformat -> extension list -> 'a read_format -> (env -> 'a library) fformat -> extension list -> 'a read_format -> (env -> 'a library)
(** [register_format fname exts read] registers a new format [fname] (** [register_format fname exts read] registers a new format [fname]
for files with extensions from the string list [exts] (without for files with extensions from the string list [exts] (without
...@@ -112,7 +113,7 @@ val register_format : ...@@ -112,7 +113,7 @@ val register_format :
val env_of_library : 'a library -> env val env_of_library : 'a library -> env
(** [env_of_library lib] returns the environment of [lib] *) (** [env_of_library lib] returns the environment of [lib] *)
val list_formats : unit -> (fformat * extension list) list val list_formats : unit -> (fformat * extension list * Pp.formatted) list
(** [list_formats ()] returns the list of registered formats *) (** [list_formats ()] returns the list of registered formats *)
val read_lib_file : 'a library -> pathname -> 'a * theory Mstr.t val read_lib_file : 'a library -> pathname -> 'a * theory Mstr.t
...@@ -169,6 +169,7 @@ let forget_all printer = ...@@ -169,6 +169,7 @@ let forget_all printer =
(** Sanitizers *) (** Sanitizers *)
let unsanitizable = Debug.register_flag "unsanitizable" let unsanitizable = Debug.register_flag "unsanitizable"
~desc:"About@ the@ sanitazing@ during@ the@ pretty-printing."
let char_to_alpha c = match c with let char_to_alpha c = match c with
| 'a'..'z' | 'A'..'Z' -> String.make 1 c | 'a'..'z' | 'A'..'Z' -> String.make 1 c
...@@ -28,8 +28,12 @@ open Decl ...@@ -28,8 +28,12 @@ open Decl
open Theory open Theory
open Task open Task
(* TODO: Is it not an example of register_stop_flag? *)
let debug_print_labels = Debug.register_flag "print_labels" let debug_print_labels = Debug.register_flag "print_labels"
~desc:"Control if ident labels are printed."
let debug_print_locs = Debug.register_flag "print_locs" let debug_print_locs = Debug.register_flag "print_locs"
~desc:"Control if ident location are printed."
let iprinter,aprinter,tprinter,pprinter = let iprinter,aprinter,tprinter,pprinter =
let bl = ["theory"; "type"; "constant"; "function"; "predicate"; "inductive"; let bl = ["theory"; "type"; "constant"; "function"; "predicate"; "inductive";
...@@ -36,22 +36,33 @@ type 'a pp = formatter -> 'a -> unit ...@@ -36,22 +36,33 @@ type 'a pp = formatter -> 'a -> unit
type printer = Env.env -> prelude -> prelude_map -> ?old:in_channel -> task pp type printer = Env.env -> prelude -> prelude_map -> ?old:in_channel -> task pp
let printers : (string, printer) Hashtbl.t = Hashtbl.create 17 type reg_printer =
{ reg_desc : formatted;
reg_printer : printer;
let printers : (string, reg_printer) Hashtbl.t = Hashtbl.create 17
exception KnownPrinter of string exception KnownPrinter of string
exception UnknownPrinter of string exception UnknownPrinter of string
let register_printer s p = let register_printer ~desc s p =
if Hashtbl.mem printers s then raise (KnownPrinter s); if Hashtbl.mem printers s then raise (KnownPrinter s);
Hashtbl.replace printers s p Hashtbl.replace printers s {reg_desc = desc; reg_printer = p}
let lookup_printer s = let lookup_printer s =
try Hashtbl.find printers s try (Hashtbl.find printers s).reg_printer
with Not_found -> raise (UnknownPrinter s) with Not_found -> raise (UnknownPrinter s)
let list_printers () = Hashtbl.fold (fun k _ acc -> k::acc) printers [] let list_printers () = Hashtbl.fold (fun k p acc ->
(k,p.reg_desc)::acc) printers []
let print_printer_desc fmt (s,f) =
fprintf fmt "@[<hov 2>%s@\n@[<hov>%a@]@]"
s Pp.formatted f
let () = register_printer "(null)" (fun _ _ _ ?old:_ _ _ -> ()) let () = register_printer ~desc:"Print nothing" "(null)"
(** Syntax substitutions *) (** Syntax substitutions *)
...@@ -193,9 +204,20 @@ exception KnownTypeSyntax of tysymbol ...@@ -193,9 +204,20 @@ exception KnownTypeSyntax of tysymbol
exception KnownLogicSyntax of lsymbol exception KnownLogicSyntax of lsymbol
let meta_syntax_type = register_meta "syntax_type" [MTtysymbol; MTstring] let meta_syntax_type = register_meta "syntax_type" [MTtysymbol; MTstring]
~desc:"Specify@ the@ syntax@ used@ to@ pretty-print@ the@ type@ symbols.@ \
Can@ be@ specified@ in@ the@ driver@ with@ the@ 'syntax type'@ rule."
let meta_syntax_logic = register_meta "syntax_logic" [MTlsymbol; MTstring] let meta_syntax_logic = register_meta "syntax_logic" [MTlsymbol; MTstring]
~desc:"Specify@ the@ syntax@ used@ to@ pretty-print@ the@ logic@ symbols.@ \
Can@ be@ specified@ in@ the@ driver@ with@ the@ 'syntax function'@ \
rule."
let meta_remove_prop = register_meta "remove_prop" [MTprsymbol] let meta_remove_prop = register_meta "remove_prop" [MTprsymbol]
~desc:"Specify@ the@ logical@ propositions@ to@ remove.@ \
Can@ be@ specified@ in@ the@ driver@ with@ the@ remove@ prop@ rule."
let meta_realized = register_meta "realized" [MTstring; MTstring] let meta_realized = register_meta "realized" [MTstring; MTstring]
~desc:"TODO??"
let syntax_type ts s = let syntax_type ts s =
check_syntax s (List.length ts.ts_args); check_syntax s (List.length ts.ts_args);
...@@ -34,11 +34,12 @@ type 'a pp = Format.formatter -> 'a -> unit ...@@ -34,11 +34,12 @@ type 'a pp = Format.formatter -> 'a -> unit
val register_printer : string -> printer -> unit val register_printer : desc:Pp.formatted -> string -> printer -> unit
val lookup_printer : string -> printer val lookup_printer : string -> printer
val list_printers : unit -> string list val list_printers : unit -> (string * Pp.formatted) list
val print_printer_desc : Pp.formatter -> (string * Pp.formatted) -> unit
(** {2 use printers} *) (** {2 use printers} *)
...@@ -103,8 +103,13 @@ type meta = { ...@@ -103,8 +103,13 @@ type meta = {
meta_type : meta_arg_type list; meta_type : meta_arg_type list;
meta_excl : bool; meta_excl : bool;
meta_tag : int; meta_tag : int;
mutable meta_desc : Pp.formatted;
let print_meta_desc fmt m =
fprintf fmt "@[%s@\n @[%a@]@]"
m.meta_name Pp.formatted m.meta_desc
module SMmeta = StructMake(struct type t = meta let tag m = m.meta_tag end) module SMmeta = StructMake(struct type t = meta let tag m = m.meta_tag end)
module Smeta = SMmeta.S module Smeta = SMmeta.S
...@@ -124,24 +129,26 @@ let meta_table = Hashtbl.create 17 ...@@ -124,24 +129,26 @@ let meta_table = Hashtbl.create 17
let mk_meta = let mk_meta =
let c = ref (-1) in let c = ref (-1) in
fun s al excl -> { fun desc s al excl -> {
meta_name = s; meta_name = s;
meta_type = al; meta_type = al;
meta_excl = excl; meta_excl = excl;
meta_tag = (incr c; !c) } meta_tag = (incr c; !c);
meta_desc = desc;
let register_meta s al excl = let register_meta ~desc s al excl =
try try
let m = Hashtbl.find meta_table s in let m = Hashtbl.find meta_table s in
if al = m.meta_type && excl = m.meta_excl then m if al = m.meta_type && excl = m.meta_excl then m
